FVE ostrov 1020 Wp - Sobrance
- Reputace: 287
Je mozne RTOS v ESP32 upravit na SafeRTOS ?
https://www.freertos.org/FreeRTOS-Plus/ ... eRTOS.html
Preco je ESP32 horsi ako ?
Atmel, Maxim, Microchip, Nordic Semiconductor, NXP, Silicon Labs, ST, TI ...
A dual core 240Mhz microprocessor, 520kb ram, RTC, ULP, 34 GPIOs, network connectivity and multiple UARTs,
I2Cs, I2Ss, SPIs, CANBUS, ADCs and DACs with external SPI EEPROM that can be from 1-16MB,
WiFi/BT/Ethernet conn,, lwIP TCP/IP Stack, Encryption acceleration instructions (AES (128, 192, 256) / SHA (1,256,384,512) Acceleration), Networking encryption, Flash encryption, Secure Boot and JTAG Disabling. As well as mbedtls lib, OpenSSL API translation and libsodium, FreeRTOS , object oriented development, RAII, smart pointers, collections, lambdas, dynamic casts and static casts, Crash Dump Analysis/Stack Overflow Detection,
OTA updates, versioning, certificate signing, queues, events, callbacks, exceptions, micro components, layers, inversion of control, control weaving, Watchdog , High CPU usage detection, Brownout detection .
Election to select the better device, failover to the redundant device, Master/Slave dev.
- Reputace: 287
- Reputace: 287
Marec je zanami, idem 100 % off-grid,
FVE - 48 V : 214 kWh
FVE - 24 V : 410 kWh,
priemer na den: 20.13 kWh.
Zistil som, ze rezat drevo off-grid, ide aj pri zamracenej oblohe:
https://www.youtube.com/watch?v=c-EoMbTpiTc&t=15s
- Reputace: 287
- Reputace: 287
- Reputace: 287
CHcel by som urobit plavajucu konstrukciu na 2 x 285 Wp , bezne 168 x 99 cm panely
aby plavala na ploche 5 x 6 m, rano to otocim na SV, potom V, a popoludni musim
posunut po vode dalej od susedovho domu, lebo by to na JZ, a Z a SZ nerobilo vecer nic.
Mam 2 x 20 l bandasky a niekolko stoviek pet flias.
Nemate niekto video, ako sa to ma urobit ? Cim to spojit a poviazat ?
Vody mam v potoku dost, tak ze ak sa nejake 4 vedra vyparia, tak nebude problem
tam dat studenu.
Neviem ci to nejako pomoze znizit teplotu panalov v lete.
tam dat studenu.
- Reputace: 287
Viete mi niekto povedat, co obsahuje voda v potoku, ak kamen z potoka vyzera takto ?
MOzu sa tym umyvat panely ?
- Reputace: 791
Podľa mňa môžeš, len to potom stiahni gumovou stierkou a je to.
- beethowen
- Reputace: 153
To jsou jenom řasy, ne?rottenkiwi píše:Viete mi niekto povedat, co obsahuje voda v potoku, ak kamen z potoka vyzera takto ?
viewtopic.php?t=5358#p103484
viewtopic.php?t=4136#p72550
- Reputace: 287
A nie je to sira ?
- beethowen
- Reputace: 153
Ono to z té fotky není úplně jasné. Máš menší detail? Tady ani nejde poznat jak je ten kámen velký, atd.
- Reputace: 287
NO lepsie to neviem, ale zlta je vacsinou sira, ci aj vo vode +2 *C rastu riasy ?
To vlavo dole je cin - 1 mm.
Nereaguje sira s hlinikovym ramom ponelov ?
- Reputace: 287
Z mojho reglu dnes islo 82 A, tak som to vyuzil a rezal Narexkou napojenou na Victron
hranoly, na upevnenie fotovoltickych panelov.
https://youtu.be/j1Q7jb7rHoo
- Reputace: 287
Dnes som nahradil 5 reglov na tej fotke, mojim 100 A reglom, vpravo dole na foto.
Regle stali 820 € a moj regl vysiel na 150 - 160 €, len treba cakat na suciastky.
Dnes som cely den testoval regl, od 9:30 do 16:15 daval od 75 - 86 A.
Za cely den regl vyrobil 16.322 kWh, dalsie dva regle 3.35 a 3.21 kWh,
v 48 V FVE sa vyrobilo 13.32 kWh dokopy za cely den: 36.202 kWh.
Na regl sa da pripojit 2700 Wp pri 24 V, 5400 Wp pri 48 V a 10800 Wp pri 96 V baterke.
Regl si vie odmezit max. prud na nastavenu hodnotu.
Robim komunikaciu s BMS a dalsimi reglami cez ESP NOW / MESH /.
SOm rad ze to regl prezil, teploty fetov isli na 44 - 45 *C pri 86 A.
A cez den som este rezal Narexkou tie hranoly na foto na tracker pre panely.
. . . Este dopeciem kvaskovy chleba a idem do lesa na smrcky.
Dagus
- Reputace: 227
Škoda že si nedáš větší práci se vzhledem, takhle i kdyby to bylo 3x lepší jak Victron, tak to bohužel je věc co si sice vyvineš, ale nikdy nikomu nepostavíš a do Victronu nezaintegruješ. Chápu, že z toho z čeho stavíš se to moc nedá, ale kdyby jsi to vzal jako investici pro to, aby jsi to mohl i někomu nabídnout, tak by se ti to mohlo někdy vrátit. Takhle sic dokážeš světu, že to zvládneš, ale nic ti to "nedá".
Jinak nikdy mě nenepadlo jak pomocí fošny udělat trám z kulatiny motorovkou
- Reputace: 287
SU tu mozno ludia, co su trochu zrucni a maju aj zdroj, aj osciloskop, aj skusenosti s PCB,
aj maju cas, a zvazia si, ze radasej ako dat 3 x 600 € za EPever alebo 3 x 1000 € za Victron
si postavia za 3 x 160 € vlastny MPPT, s vlastnym SW, vlastnym WEB serverom a MQTT
integruju si ho do systemu, kde maju vlastny BMS 5 - 15 A aktivny balancing
a tesia sa z toho, ze to 5 - 10 r. funguje.
Ani ja som nevedel rezat tramy, ale ked clovek nevie ako urobit MPPT alebo ako rezat tram,
treba si pozriet Ruske YT - videa.
ChlapeczDediny
- Reputace: 152
- Lokalita: Juh BBSK
- Výkon panelů [Wp]: 3100
Už som to raz písal. Ľudia neocenia, nezaplatia to, čo vieš, ale čo pre nich urobíš. Ak ti k životu stačí radost z dokázaného a múku na chleba si dopestuješ, tak som nič nepovedal.
- Reputace: 791
Ja ti poviem svoj názor, nemaj mi to za zlé. Aj keby som bol zručný, mal osciloskop aj skúsenosti s PCB, tak si radšej kúpim hotový produkt, lebo nemám ČAS, a veľa času, aby som vymýšľal koleso. Iks vývojových verzií, dlhé testovanie v rôznych podmienkach, nakoniec thermal design, skrinka, komunikácia (RS485, modbus, LAN), GUI (ovládanie, displej, web interface). Lebo nechcem mať na stene nejakú pavučinu, s hardcoded premennými, na uťahovačkách pripevnený starý ventilátor z PC a podobne. Odhadujem to na roky práce popri práci, rodine a koníčkoch. Lebo o tom je život. O rovnováhe.
Ja osobne som chcel postaviť FVE, navrhol som ju aby sa splatila v zmysluplnom čase (lebo áno, je to aj koníček, ale musí to dávať ekonomický zmysel), nemalo sa na nej moc čo pokaziť, aby to ideálne fungovalo samostatne, bez mojej asistencie, lebo manželky nezaujímajú grafy, predikcie počasia, katódy, anódy, separátory, elektrolyty, osciloskopy, termokamery ani nič také. Chcú aby to fungovalo, aby o tom nebolo vedieť (vidieť, počuť), aby to neobmedzovalo, aby to nezhorelo a ak sa to pokazí, aby po prepnutí jedného prepínača sietí to išlo ďalej...
- Reputace: 938
Technická k tomu řezání, katr z řetězovky je běžná věc, dokonce se to i prodává, takové jakože lešení. Dají se s tím nařezat nejen trámky, ale i fošny a desky.
knopis
- Reputace: 6
Uživatelé prohlížející si toto fórum: Claudebot [Bot], SiteExplorer [Bot] a 2 hosti
