Solar Assistant
tosik
Lokalita: Rychvald
Výkon panelů [Wp]: 7480
Kapacita baterie [kWh]: 32
Re: Solar Assistant
Nový příspěvek od tosik »
Už jsem se na to koukal, je to asi to, co by se mi líbilo, jen v seznamu není typ BMS, kterou mám (JK-PB2A16S20P v15). Bude to fungovat i s touto BMS?
Reputace: 843
Re: Solar Assistant
Nevím, ale neočekávám, že by výrobce změnil způsob komunikace a sám si komplikoval život.
konikv
Lokalita: okr. Levice
Výkon panelů [Wp]: 5000
Kapacita baterie [kWh]: 20
Re: Solar Assistant
Nový příspěvek od konikv »
root@solar-assistant:~# usbreset 001/006
Resetting USB Serial ... ok
log:
Jul 15 14:20:15 solar-assistant influx-bridge[651]: [Tue Jul 15 16:20:15] [inverter:voltronic:driver] Scheduled inverter query qdop failed: rejected: (NAK
Jul 15 14:20:29 solar-assistant kernel: ch341-uart ttyUSB1: ch341-uart converter now disconnected from ttyUSB1
Jul 15 14:20:29 solar-assistant kernel: ch341 1-1.3:1.0: device disconnected
Jul 15 14:20:29 solar-assistant influx-bridge[651]: [Tue Jul 15 16:20:29] [bms:serial:connection] Closing serial port.
Jul 15 14:20:29 solar-assistant influx-bridge[651]: [Tue Jul 15 16:20:29] GenServer SolarAssistant.BMS.Serial.Driver.Connection terminating
Jul 15 14:20:29 solar-assistant influx-bridge[651]: ** (MatchError) no match of right hand side value: {:error, :ebadf}
Jul 15 14:20:29 solar-assistant influx-bridge[651]: (solar_assistant 1.9.15) lib/solar_assistant/bms/serial/driver/connection.ex:36: SolarAssistant.BMS.Serial.Driver.Connection.handle_call/3
Jul 15 14:20:29 solar-assistant influx-bridge[651]: (stdlib 4.2) gen_server.erl:1149: :gen_server.try_handle_call/4
Jul 15 14:20:29 solar-assistant influx-bridge[651]: (stdlib 4.2) gen_server.erl:1178: :gen_server.handle_msg/6
Jul 15 14:20:29 solar-assistant influx-bridge[651]: (stdlib 4.2) proc_lib.erl:240: :proc_lib.init_p_do_apply/3
Jul 15 14:20:29 solar-assistant influx-bridge[651]: Last message (from SolarAssistant.BMS.Serial.Driver): {:submit, %SolarAssistant.BMS.Serial.Driver.Command{header: %{adr: 2, cid1: 70, cid2: 66, info: [1], ver: 34}, metrics: nil, raw: "~22024642E00201FD32\r"}}
Jul 15 14:20:29 solar-assistant kernel: usb 1-1.3: reset full-speed USB device number 6 using dwc_otg
Jul 15 14:20:29 solar-assistant influx-bridge[651]: [Tue Jul 15 16:20:29] [bms:serial] [error] Failed to open ttyUSB1: enoent. Retrying in 15s
Jul 15 14:20:29 solar-assistant kernel: ch341 1-1.3:1.0: ch341-uart converter detected
Jul 15 14:20:29 solar-assistant kernel: usb 1-1.3: ch341-uart converter now attached to ttyUSB0
Jul 15 14:20:32 solar-assistant ModemManager[464]: <info> [base-manager] couldn't check support for device '/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3': not supported by any plugin
Jul 15 14:20:38 solar-assistant influx-bridge[651]: [Tue Jul 15 16:20:38] GET /grafana/api/datasources/proxy/1/query
Po nejakom case proste musim stlacit web tlacitka Disconect ... Connect. :?
potom to ide OK.
Soban píše: stř črc 09, 2025 1:41 pm
Nevypadává ten USB převodník?
Skus ho restartovat ....
petr@HP-Olomouc:~$ usbreset
Usage:
usbreset PPPP:VVVV - reset by product and vendor id
usbreset BBB/DDD - reset by bus and device number
usbreset "Product" - reset by product name
FV:5kWp, Voltronic AXPERT VM IV 5.6kW, 4x LiFePo4 5kWh, ostrovny system. SolarAssistant
konikv
Re: Solar Assistant
Zda sa ze problem vypadavania USB je vyrieseny.
Odsledovane uz dlhsiu dobu.
Chyba bola pravdepodobne na poskodenom filesysteme.
Po oprave fsck -fy -C0 /dev/sda1 to slape ako ma.
Cely adresar /var je teraz primontovany na usb kluc.
Takze na flash pameti je len system , ziaden zapis.
Zatial sa mi nestalo ze by zber dat vypadol.
FS za vzdy poskodil ked sa vypol RP. Spravne musi byt najskor shutdown.
Lenze pri vypadku elektriny to jednoducho vypadlo.
Preto som zacal napajat RP priamo z bateriek. Treba k tomu menic na DC-DC 60V->5V.
Co je tazke zohnat , pretoze nie kazdy vyhovuje.
mirekcafa
Reputace: 31
Lokalita: českotřebovsko
Re: Solar Assistant
Nový příspěvek od mirekcafa »
Zdravím, SA zprovoznil předpověď slunečního svitu. Jaký máte nastavený azimut?
PetrDubi
Reputace: 316
Výkon panelů [Wp]: 10790
Kapacita baterie [kWh]: 13
Re: Solar Assistant
Nový příspěvek od PetrDubi »
Azimut by měl odpovídat tomu, na jakou stranu jsou otočené panely.
mirekcafa
Reputace: 31
Re: Solar Assistant
mám je jihovýchodně, ale plavu v těch stupních, někde to počítají na 360 stupňů, (sever 0, jih 180)někde zase je na jih 180 a pak buď do plusu nebo do mínusu. Kdyby to bylo 360 tak je mám tak na 160 stupňů, anebo druhá verze -20, ale zas mi to nesedí se SA vs. Solcast
PetrDubi
Reputace: 316
Re: Solar Assistant
mirekcafa
Reputace: 31
Re: Solar Assistant
Petře díky , na to jsem koukal včera. Zkusím to nastavit podle tohodle
https://mapy.com/cs/zakladni?mereni-vzd ... YGB3hS1h2N
153 stupnů
iencv
Lokalita: Skalice u ČL
Kapacita baterie [kWh]: 32 kwh
Re: Solar Assistant
Nový příspěvek od iencv »
Zdravím vás.
Chci provozovat solar assistenta na rpi4 a mám dotaz, jakou verzi vzít (1, 2 nebo 4 G), když na něm pojede jen SA a bude sledovat 4 x baterku 16 kwh s JK BMS a 1 možná 2 x Axpert twin 11 kw.
Díky za radu.
Reputace: 296
Re: Solar Assistant
Osobně když jsem kupoval RPI tak neberu nic co nemá aspoň ty 4G.
https://rpishop.cz/raspberry-pi-4/1598- ... b-ram.html 1459,- kč
https://rpishop.cz/raspberry-pi-4/1599- ... b-ram.html 1209,- kč
Rozdíl 250,- kč chceš řešit.......
Daleko důležitější je k tomu pořídit SSD místo SD karty které nevydrží - nejsou dělané na tak časté zápisy.
Taky to chce k tomu pořídit chladič https://rpishop.cz/raspberry-pi-4/1901- ... cerna.html
bahora
Reputace: 7
Lokalita: Ostrava
Re: Solar Assistant
Nový příspěvek od bahora »
Soban píše: ned zář 07, 2025 7:23 pm
Chladič chválím, mám ho taky a je super, k tomu přes stahovací elektrikářské pásky kovový držák na DIN lištu ....
Místo SSD jsem řešil odolnost SD karty použitím 16GB eMMC paměť pro Raspberry Pi, prozatím druhým rokem v pohodě, klepu do dřeva ať to je pravda i za deset let :) https://rpishop.cz/emmc-micro-sd/2095-u ... ry-pi.html
Reputace: 296
Re: Solar Assistant
Byl tu na mě dotaz jaké USB -> SATA převodníky k RPI já používám a mám vyskoušené tyto modely:
AXAGON ADSA-FP2, USB3.0 - SATA 6G 2.5" adaptér akorát koukám že už se neprodává, ale určitě bude náhrada k dohledání. 😢
A pak taky AXAGON ADSA-1S6 SLIMport6 box, černý ten pořád mají 😃
mirekcafa
Reputace: 31
Re: Solar Assistant
mirekcafa píše: sob srp 30, 2025 3:14 pm
153 stupnů
Tak nakonec nejlepší nastavení azimutu mám v Solar assistantu - 30 stupňů
sindyk
Reputace: 69
Re: Solar Assistant
Nový příspěvek od sindyk »
Huh, SA zpoplatnil updaty😡
blaskoi
Reputace: 3
Re: Solar Assistant
Nový příspěvek od blaskoi »
Ja si myslím, že to spoplatnenie je úplne v poriadku, nie je to ani cena jedného piva mesačne 😃.
sindyk
Reputace: 69
Re: Solar Assistant
Jasně, počty nových instalací se snižují a pokud lidi chtějí vývoj, support a provoz proxy, musí se to zaplatit. Jen jsem už nechtěl čekat na stable verzi a kouknout na nový fičury, přepnu na betu, kliknu na update a ono toto :shock: :D
Reputace: 863
Kapacita baterie [kWh]: 40+15
Re: Solar Assistant
600 na dva roky řešíš? To zvládneš prodrbat během chvilky v akci v kdejakém hyper/super :D
sindyk
Reputace: 69
Re: Solar Assistant
Neřeším, já mám předplaceno kdejakých chujovin... Je to prostě informace. Pro někoho možná podstatná, že po 2 letech od zakoupení SA se platí za update. A líbí se mi predikce výroby podle počasí, můžu si automaticky přepnout režim, abych stihl do konce dne včas dotlačit olovo :)
Reputace: 863
Re: Solar Assistant
Tak proč jsi tam dal ten smajlík, co jsi dal? To ten příspěvek vyznívá úplně jinak, jako by tě to naštvalo ...
