Ostrovní FVE - výzkumná "chytrá" chata Štramberk
- Reputace: 186
Re: Ostrovní FVE - výzkumná "chytrá" chata Štramberk
Ještě upravený Flow do NodeRED pro jeden String. Stačí naimportovat a pak nakopírovat kolikrát je třeba a jen upravit id dle jednotlivých MPPT regulátorů.
Musí být nainstalovany tyto node:
node-red-dashboard
node-red-contrib-modbus
node-red-contrib-influxdb
node-red-contrib-moment
Vyčítám jen pro mne zajímavé údaje (P, I, U) panelů a jejich výrobu (denní, měsíční, roční a celkovou). Ale jinak Epever MPPT poskytuje těch údajú opravdu hodně.
NodeRED flow pro jeden MPPT:
Tenhle Flow je i se zápisem Power a SOC do InfluxDB (to lze samozřejmě vynechat-smazat) ...
node-red-dashboard
Kód: Vybrat vše
"id": "8770ff6aec685e39",
"type": "split",
"z": "8c5f2b0a20d352cf",
"name": "",
"splt": "\\n",
"spltType": "str",
"arraySplt": 1,
"arraySpltType": "len",
"stream": false,
"addname": "topic",
"x": 190,
"y": 1120,
"wires": [
"4356455901813e9c"
"id": "4356455901813e9c",
"type": "switch",
"name": "",
"property": "parts.index",
"propertyType": "msg",
"rules": [
"t": "eq",
"v": "0",
"vt": "num"
"t": "eq",
"v": "1",
"vt": "num"
"t": "eq",
"v": "2",
"vt": "num"
"t": "eq",
"v": "3",
"vt": "str"
"t": "eq",
"v": "4",
"vt": "str"
"t": "eq",
"v": "5",
"vt": "str"
"t": "eq",
"v": "6",
"vt": "str"
"t": "eq",
"v": "7",
"vt": "str"
"t": "eq",
"v": "8",
"vt": "str"
"t": "eq",
"v": "9",
"vt": "str"
"t": "eq",
"v": "10",
"vt": "str"
"t": "eq",
"v": "11",
"vt": "str"
"t": "eq",
"v": "12",
"vt": "str"
"t": "eq",
"v": "13",
"vt": "str"
"t": "eq",
"v": "14",
"vt": "str"
"t": "eq",
"v": "15",
"vt": "str"
"t": "eq",
"v": "16",
"vt": "str"
"t": "eq",
"v": "17",
"vt": "str"
"checkall": "false",
"repair": false,
"outputs": 18,
"x": 410,
"y": 1000,
"wires": [
"054ff6258985faf1"
"4019de50b85d0566"
"aed6f9a438cfeb78"
"id": "054ff6258985faf1",
"type": "change",
"name": "Vsolar",
"rules": [
"t": "set",
"p": "topic",
"pt": "msg",
"to": "Vsolar",
"tot": "str"
"t": "set",
"p": "Vsolar",
"pt": "flow",
"to": "payload",
"tot": "msg"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 550,
"y": 880,
"wires": [
"3e5a6e5c0b331077"
"id": "4019de50b85d0566",
"type": "change",
"name": "Isolar",
"rules": [
"t": "set",
"p": "topic",
"pt": "msg",
"to": "Isolar",
"tot": "str"
"t": "set",
"p": "Isolar",
"pt": "flow",
"to": "payload",
"tot": "msg"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 550,
"y": 920,
"wires": [
"08793d4a431f7871"
"id": "3e5a6e5c0b331077",
"type": "range",
"minin": "0",
"maxin": "10000",
"minout": "0",
"maxout": "100",
"action": "scale",
"round": false,
"property": "payload",
"name": "/100",
"x": 690,
"y": 880,
"wires": [
"e68e55fa9742731d"
"id": "08793d4a431f7871",
"type": "range",
"minin": "0",
"maxin": "10000",
"minout": "0",
"maxout": "100",
"action": "scale",
"round": false,
"name": "/100",
"x": 690,
"y": 920,
"wires": [
"c543044c307cfab0"
"id": "3d5f768dee14f938",
"type": "modbus-flex-getter",
"name": "Modbus Get",
"showStatusActivities": false,
"showErrors": false,
"showWarnings": false,
"logIOActivities": false,
"server": "b7312c82.e12fe",
"useIOFile": false,
"ioFile": "",
"useIOForPayload": false,
"emptyMsgOnFail": false,
"keepMsgProperties": false,
"delayOnStart": false,
"startDelayTime": "",
"x": 510,
"y": 1580,
"wires": [
"9b43871d503f0897",
"3bfd81b05894e550"
"32e1384c14a078a8"
"id": "be69bcb888b7f4f0",
"type": "function",
"name": "FC4 0x3100 [18]",
"func": "msg.payload = { \n 'fc': 4, \n 'unitid': 6, \n 'address': 0x3100, \n 'quantity': 18\n}\n\nmsg.topic = \"livestats\";\n\nreturn msg;",
"outputs": 1,
"timeout": "",
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 280,
"y": 1540,
"wires": [
"3d5f768dee14f938"
"id": "32e1384c14a078a8",
"type": "modbus-response",
"name": "",
"registerShowMax": 20,
"x": 710,
"y": 1600,
"wires": []
"id": "ad48d1b54f9ad3fd",
"type": "inject",
"name": "10s",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "10",
"crontab": "",
"once": true,
"onceDelay": "1",
"topic": "",
"payload": "1",
"payloadType": "str",
"x": 130,
"y": 1540,
"wires": [
"be69bcb888b7f4f0"
"id": "5c6f621444c8e872",
"type": "inject",
"name": "30s",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "30",
"crontab": "",
"once": true,
"onceDelay": "2",
"topic": "historicalstats",
"payload": "1",
"x": 130,
"y": 1580,
"wires": [
"31a88616278c676a"
"id": "9b43871d503f0897",
"type": "switch",
"name": "",
"property": "topic",
"rules": [
"t": "eq",
"v": "livestats",
"vt": "str"
"t": "eq",
"v": "historicalstats",
"vt": "str"
"t": "eq",
"v": "bsoc",
"vt": "str"
"checkall": "true",
"repair": false,
"outputs": 3,
"x": 130,
"y": 1320,
"wires": [
"8770ff6aec685e39"
"87562ae844d48134"
"4882ca36ca3b9861"
"id": "aed6f9a438cfeb78",
"type": "change",
"name": "Psolar",
"rules": [
"t": "set",
"p": "topic",
"pt": "msg",
"to": "Psolar",
"tot": "str"
"t": "set",
"p": "Psolar",
"pt": "flow",
"to": "payload",
"tot": "str"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 550,
"y": 960,
"wires": [
"65f55542649a1df0"
"id": "65f55542649a1df0",
"type": "range",
"minin": "0",
"maxin": "10000",
"minout": "0",
"maxout": "100",
"action": "scale",
"round": false,
"name": "/100",
"x": 690,
"y": 960,
"wires": [
"e71378fe9454109d",
"005c711cf8db14a9",
"3618c4e068337d9d"
"id": "7dd652b4f6af5745",
"type": "function",
"name": "FC4 0x311A [1]",
"func": "msg.payload = { \n 'fc': 4, \n 'unitid': 6, \n 'address': 0x311A, \n 'quantity': 1\n}\n\nmsg.topic = \"bsoc\";\n\nreturn msg;",
"outputs": 1,
"timeout": "",
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 280,
"y": 1620,
"wires": [
"3d5f768dee14f938"
"id": "d0aeecdda4d0de5a",
"type": "inject",
"name": "60s",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "60",
"crontab": "",
"once": true,
"onceDelay": "3",
"topic": "bsoc",
"payload": "1",
"x": 130,
"y": 1620,
"wires": [
"7dd652b4f6af5745"
"id": "c543044c307cfab0",
"type": "ui_gauge",
"name": "",
"group": "1f1737ea5b365089",
"order": 3,
"width": "3",
"height": "3",
"gtype": "gage",
"title": "Current",
"label": "A",
"format": "{{value | number: 2}}",
"min": 0,
"max": "20",
"colors": [
"#ca3838",
"#e6e600",
"#00b500"
"seg1": "",
"seg2": "",
"className": "",
"x": 1040,
"y": 960,
"wires": []
"id": "e68e55fa9742731d",
"type": "ui_gauge",
"name": "",
"order": 2,
"width": "3",
"height": "3",
"gtype": "gage",
"title": "Voltage",
"label": "V",
"min": 0,
"max": "120",
"colors": [
"#ca3838",
"#e6e600",
"#00b500"
"seg1": "",
"seg2": "",
"className": "",
"x": 1040,
"y": 880,
"wires": []
"id": "e71378fe9454109d",
"type": "ui_gauge",
"name": "",
"order": 1,
"width": 0,
"height": 0,
"gtype": "gage",
"title": "Power",
"label": "W",
"format": "{{value | number: 0}}",
"min": 0,
"max": "1000",
"colors": [
"#ca3838",
"#e6e600",
"#00b500"
"seg1": "",
"seg2": "",
"className": "",
"x": 1030,
"y": 1040,
"wires": []
"id": "31a88616278c676a",
"type": "function",
"name": "FC4 0x3304 [16]",
"func": "msg.payload = { \n 'fc': 4, \n 'unitid': 6, \n 'address': 0x3304, \n 'quantity': 16\n}\n\nmsg.topic = \"historicalstats\";\n\nreturn msg;",
"outputs": 1,
"timeout": "",
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 280,
"y": 1580,
"wires": [
"3d5f768dee14f938"
"id": "0158f6109490ab7d",
"type": "switch",
"name": "",
"rules": [
"t": "eq",
"v": "0",
"vt": "num"
"t": "eq",
"v": "1",
"vt": "num"
"t": "eq",
"v": "2",
"vt": "num"
"t": "eq",
"v": "3",
"vt": "str"
"t": "eq",
"v": "4",
"vt": "str"
"t": "eq",
"v": "5",
"vt": "str"
"t": "eq",
"v": "6",
"vt": "str"
"t": "eq",
"v": "7",
"vt": "str"
"t": "eq",
"v": "8",
"vt": "str"
"t": "eq",
"v": "9",
"vt": "str"
"t": "eq",
"v": "10",
"vt": "str"
"t": "eq",
"v": "11",
"vt": "str"
"t": "eq",
"v": "12",
"vt": "str"
"t": "eq",
"v": "13",
"vt": "str"
"t": "eq",
"v": "14",
"vt": "str"
"t": "eq",
"v": "15",
"vt": "str"
"repair": false,
"outputs": 16,
"x": 410,
"y": 1280,
"wires": [
"686bb994182ce550"
"5d9b2011f4daf706"
"14f6865ce6037070"
"4cabeb8554e509d9"
"id": "87562ae844d48134",
"type": "split",
"name": "",
"splt": "\\n",
"spltType": "str",
"arraySplt": 1,
"stream": false,
"addname": "topic",
"x": 270,
"y": 1320,
"wires": [
"0158f6109490ab7d"
"id": "7961fd2892900135",
"type": "ui_text",
"order": 4,
"width": 0,
"height": 0,
"name": "",
"label": "Energy of Day",
"layout": "row-spread",
"className": "",
"x": 1060,
"y": 1220,
"wires": []
"id": "1dc407d42fab8302",
"type": "ui_text",
"order": 5,
"width": 0,
"height": 0,
"name": "",
"label": "Energy of Month",
"className": "",
"x": 1060,
"y": 1260,
"wires": []
"id": "d8207cfa7ea24f58",
"type": "ui_text",
"order": 6,
"width": 0,
"height": 0,
"name": "",
"label": "Energy of Year",
"className": "",
"x": 1060,
"y": 1300,
"wires": []
"id": "69e0601fe1845355",
"type": "ui_text",
"order": 7,
"width": 0,
"height": 0,
"name": "",
"label": "Energy Total",
"className": "",
"x": 1050,
"y": 1340,
"wires": []
"id": "686bb994182ce550",
"type": "change",
"name": "Eday1",
"rules": [
"t": "set",
"p": "topic",
"pt": "msg",
"to": "eday1",
"tot": "str"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 710,
"y": 1200,
"wires": [
"6510fa646b2a2de1"
"id": "5d9b2011f4daf706",
"type": "change",
"name": "Emonth",
"rules": [
"t": "set",
"p": "topic",
"pt": "msg",
"to": "Emonth",
"tot": "str"
"t": "set",
"p": "Emonth",
"pt": "flow",
"to": "payload",
"tot": "msg"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 720,
"y": 1240,
"wires": [
"11ccf7343270ab7d"
"id": "6510fa646b2a2de1",
"type": "range",
"minin": "0",
"maxin": "10000",
"minout": "0",
"maxout": "100",
"action": "scale",
"round": false,
"name": "/100",
"x": 850,
"y": 1200,
"wires": [
"7961fd2892900135",
"3936daac8a534470",
"6be9bf6d8af8f44b"
"id": "11ccf7343270ab7d",
"type": "range",
"minin": "0",
"maxin": "10000",
"minout": "0",
"maxout": "100",
"action": "scale",
"round": false,
"name": "/100",
"x": 850,
"y": 1240,
"wires": [
"1dc407d42fab8302"
"id": "14f6865ce6037070",
"type": "change",
"name": "Eyear",
"rules": [
"t": "set",
"p": "topic",
"pt": "msg",
"to": "Eyear",
"tot": "str"
"t": "set",
"p": "Eyear",
"pt": "flow",
"to": "payload",
"tot": "str"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 710,
"y": 1280,
"wires": [
"115e71b1d1774a4f"
"id": "115e71b1d1774a4f",
"type": "range",
"minin": "0",
"maxin": "10000",
"minout": "0",
"maxout": "100",
"action": "scale",
"round": false,
"name": "/100",
"x": 850,
"y": 1280,
"wires": [
"d8207cfa7ea24f58"
"id": "4cabeb8554e509d9",
"type": "change",
"name": "Etotal",
"rules": [
"t": "set",
"p": "topic",
"pt": "msg",
"to": "Etotal",
"tot": "str"
"t": "set",
"p": "Etotal",
"pt": "flow",
"to": "payload",
"tot": "str"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 710,
"y": 1320,
"wires": [
"0f1d4d2ffbcc9b66"
"id": "0f1d4d2ffbcc9b66",
"type": "range",
"minin": "0",
"maxin": "10000",
"minout": "0",
"maxout": "100",
"action": "scale",
"round": false,
"name": "/100",
"x": 850,
"y": 1320,
"wires": [
"69e0601fe1845355"
"id": "005c711cf8db14a9",
"type": "influxdb out",
"influxdb": "ae2ac8adc287f20e",
"name": "powerFVE1",
"measurement": "powerFVE1",
"precision": "",
"retentionPolicy": "",
"database": "temp",
"precisionV18FluxV20": "s",
"retentionPolicyV18Flux": "",
"org": "organisation",
"bucket": "bucket",
"x": 1050,
"y": 1080,
"wires": []
"id": "3618c4e068337d9d",
"type": "link out",
"name": "PowerFVE1",
"mode": "link",
"links": [],
"x": 995,
"y": 1120,
"wires": []
"id": "3936daac8a534470",
"type": "link out",
"name": "eday1",
"mode": "link",
"links": [
"555693700e7ae41f"
"x": 1005,
"y": 1180,
"wires": []
"id": "4882ca36ca3b9861",
"type": "range",
"minin": "0",
"maxin": "100",
"minout": "0",
"maxout": "100",
"action": "scale",
"round": false,
"name": "100",
"x": 470,
"y": 1440,
"wires": [
"45bf6c1dab0a8c7f"
"id": "45bf6c1dab0a8c7f",
"name": "batterySOC",
"measurement": "batterySOC",
"precision": "",
"database": "temp",
"bucket": "bucket",
"x": 730,
"y": 1440,
"wires": []
"id": "6be9bf6d8af8f44b",
"type": "debug",
"name": "Eday1",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "payload",
"targetType": "msg",
"statusVal": "",
"statusType": "auto",
"x": 1070,
"y": 1140,
"wires": []
"id": "3bfd81b05894e550",
"type": "link out",
"name": "XTRA1out",
"mode": "link",
"links": [
"d128d7959b4925dd"
"x": 725,
"y": 1520,
"wires": []
"id": "b7312c82.e12fe",
"type": "modbus-client",
"name": "Tracer6",
"clienttype": "tcp",
"bufferCommands": true,
"stateLogEnabled": false,
"queueLogEnabled": false,
"failureLogEnabled": false,
"tcpHost": "10.0.0.90",
"tcpPort": "502",
"tcpType": "DEFAULT",
"serialPort": "/home/pi/ttyV0",
"serialType": "RTU-BUFFERD",
"serialBaudrate": "115200",
"serialDatabits": "8",
"serialStopbits": "1",
"serialParity": "none",
"serialConnectionDelay": "100",
"serialAsciiResponseStartDelimiter": "",
"unit_id": "6",
"commandDelay": "100",
"clientTimeout": "2000",
"reconnectOnTimeout": true,
"reconnectTimeout": "2000",
"parallelUnitIdsAllowed": false,
"showLogs": false
"id": "1f1737ea5b365089",
"type": "ui_group",
"name": "String1 (JJV)",
"tab": "ef8f2d5e272ee0a1",
"order": 2,
"disp": true,
"width": "6",
"collapse": false,
"className": ""
"id": "ae2ac8adc287f20e",
"type": "influxdb",
"hostname": "10.0.0.103",
"port": "8086",
"protocol": "http",
"database": "temp",
"name": "MyInflux",
"usetls": false,
"tls": "",
"influxdbVersion": "1.x",
"url": "http://10.0.0.20:8086",
"rejectUnauthorized": false
"id": "ef8f2d5e272ee0a1",
"type": "ui_tab",
"name": "MPPT",
"icon": "dashboard",
"order": 2,
"disabled": false,
"hidden": false
Naposledy upravil(a) skybor dne stř led 15, 2025 6:15 pm, celkem upraveno 1 x.
SkyFVE 8 kWp (ve výstavbě) na výzkumné "chytré" chatě. 4x MPPT Epever XTRA4415N 4x40A, 1x AC Charger WATE 42V/10A, Li-Ion 3x 12s 156Ah (20 kWh/44V), SkyPowerBox LF 4810 1kVA, Victron Atlas 48/1600, REVO VM II 5.5kW, APC SmartUPS 5kVA + PLC Siemens Logo! + Dell Optiplex 3040 Micro (Proxmox: HA, Node-RED, InfluxDB, Grafana, Mqtt, Zigbee2Mqtt, Samba, Tailscale)
- Reputace: 186
A jen tak pro zajímavost takhle nějak vypadá ten původní Epever Dashboard z Githubu ...
- Reputace: 186
Leden 2025
Leden u nás dopadl nad očekávání dobře a to hlavně díky jeho lepší druhé polovině. Řeči úderníků by se dalo říct, že plány jsou splněny na 200%. Původní plán totiž byl, dostat se se spotřebou v lednu pod 200kWh z DS. A nakonec se podařilo dostat pod 100kWh (i když o chlup)
Spotřeba EE z DS a FVE v lednu:
Meziroční srovnání spotřeby z DS:
- Reputace: 186
1.2.2025 - Spuštění plného provozu SkyFVE
Nabit optimizmem z druhé poloviny ledna jsem se rozhodl letos (zkusit) přepnout celou domácnost na FVE již ode dnešního dne.
Byly spuštěny všechny měniče a všechny přepínače přepnuty na FVE a budu doufat, že počasí bude o mém optimizmu náležitě informováno a nebude mi házet klacky pod nohy
Předpověď na únor:
Aktuální provoz měničů:
1. měnič: nonstop provoz (vše mimo náročné spotřebiče)
2. měnič: nonstop provoz (tepelné spotřebiče - bojler, žebřík, přímotopné podlahy, akumulační kamna)
3. měnič: provoz 8-18hod. (příkonově náročnější spotřebiče - trouba, pračka, myčka, MW, RV konvice ...)
Předpověď na únor:
- Reputace: 535
Nech sa teda darí! Ja som práve pozeral spotrebu el. rúry za posledné mesiace (Zigbee zásuvka) a zistil som, že to robí 8-11 kWh mesačne. Pri zapnutí začne odoberať až 3.5 kW napriek špecifikácii kde píšu "max 2.5 kW", čo robí jednému 5.5 kW meniču problém, ak je súbeh viacero spotrebičov (kanvica 2.4 kW, ohrev práčky... atď). Aby som sa tomu vyhol, asi ju nechám trvale na gride, nech má distribútor malé Vianoce
- Reputace: 186
Taky jsem trochu sledoval spotřeby výkonnějších spotřebičů a možná (pokud budou nějaké problémy) nechám nakonec trvale na gridu MW a RV konvicu. Je to za celý den pár Wh.
Jinak se u nás peče dopoledne a pere a myje nádobí odpoledne
(dobrý návyk hospodyňky z odpoledního provozu NT sazby)
- Reputace: 186
A když už to tak pěkně všechno měříme, tak ještě první statistika ohledně výroby ... No nebýt té druhé půlky ledna, tak jsou tam snad samé nuly
- Reputace: 186
Tak jsem se nechal inspirovat TomHC a nahodil jsem si do HA taky ty fešácké budíky. Byla to fuška (pro mne), ale jsou tam
- Reputace: 210
- Lokalita: Pod Karpatmi
Ja som zasa zistil ze v nodered ked aktualizujem dashboard tak mi tam pribudne nova paleta budikov, respektive moznost vacsieho nastavenia tych doterajsich co su tam..
Len nemam spravene na vsetko zalohy tak zatial sa tomu vyhybam i ked aktualizacia " ui " je uz stiahnuta.
a stále v štádiu budovania
(rozširovania)
- Reputace: 186
4.2.2025 - První opravdu slunečný den roku 2025
Dneska to byla prostě paráda. 15kWh vyrobeno. A protože přes den nikdo nebyl doma, tak všechno nabito. Baterky se krásně zbalancovaly a srovnalo se SOC. Bojler nabit na 80st a ještě zbylo pár kWh do akumulaček
Zajímavě se chová ten severní String4. Když je zamračeno tak vyrábí úplně stejně jako ostatní stringy. Ale když je jasno jako dnes, tak je úplně mrtvý. Což ale samozřejmě ničemu nevadí. Když je jasno, tak víc vyrábět nepotřebuju, ale když je zamračeno, tak se hodí každá Wh.
Jak se nám slunce pomalu zvedá, tak se i ten ranní start už posouvá (na východě máme totiž kopec) a tím se i prodlužuje FVE šichta.
- Reputace: 186
Malé Valentýnské srovnání SkyFVE v1 a SkyFVE v2:
Zatímco loni na Valentýna jsem se radoval z druhého vítězství FVE nad DS v období 30 dní před Valentýnem i celkově v roce 2024 (viewtopic.php?p=227075#p227075), letos za stejné období 30ti dní to byla už samá vítězství a jen jedna prohra.
Nějaký vliv počasí na výsledek tam určitě bude (konec ledna a začátek února se celkem povedl), ale i tak je to potěšující zjištění.
2024 2025
Nejhorší období solárního roku nám snad pomalu končí. I když včerejšek naznačil, že to zima ještě úplně nevzdala. Zlom u nás nastal 26.1. , kdy klouzavý součet spotřeby z DS za uplynulých 30 dní opět klesl pod součet spotřeby z FVE.
2024 2025
- Reputace: 186
A ještě jeden obrázek Valentýna 2025. Někdy když napadnre a pěkně se zatáhne, tak se ta větší baterka fakt hodí ...
- Reputace: 186
Včera již skoro ideál. K tomu ještě chybí obejít ráno ten kopec na východě, který ubírá z celodenní výroby. A taky aby konečně roztál sníh na té SSZ straně
. 20kWh ještě pořád nepadlo, ale i tak už je EE dost na to, aby polovina výroby šla do akumulaček (od 9:45 do 15:45) ...
- Reputace: 186
Únor 2025
Musím se přiznat, že pro mne byl letošní únor jedno velké příjemné překvapení v mé krátké historii solárníka. Loňský "malý" upgrade na SkyFVE v2 se celkem povedl a cíl minimalizovat spotřebu z DS za rozumných ekonomických nákladů se asi podařil.
Se sprovozněním MPPT regulátorů od Epever jsem konečně zavedl i rozumné sledování výroby FVE.
Další fáze vývoje pro letošní rok (i další roky) bude asi maximalizovat efektivitu výroby a spotřeby EE a s tím související navýšení komfortu života s FVE.
Vidím před sebou minimálně dva úkoly, které by mohly efektivitu využití EE z FVE zvýšit a vylepšit i komfort bydlení:
1) indukční varná deska (pravděpodobně se konečně splní někomu sen a já snad nebudu litovat)
2) klimatizace (TČ vzduch/vzduch) - chlazení v létě a přitápění v přechodném období
- Reputace: 790
U indukce mám dvouplotýnkovou (ELECTROLUX EHH3920BVK) a vedle plynovou (ELECTROLUX EGC3313NOK) na pb. Vaří se u nás dost, ale dvě plotýnky pokryjí potřeby. Ušetří se tím místo oproti klasice 4-plotýnce. Ředitelka kuchyně automaticky přechází na pb když je málo solární elektřiny. Aktuálně nám jedna pb 10 kg vydrží rok.
- Reputace: 186
SunSynk Power Flow Card
Tak jsem se konečně dostal ke zprovoznění "SunSynk Power Flow Card" v HA. No, přiznám se bez mučení, byla to pro mne fuška, ale dal jsem to
Teď už to jen nějak dostat na minitablety, které jsem zde koupil v bazárku a pověsit to na zeď ...
- Reputace: 210
Peknee!
Aj sa ti tam zobrazuje/pohybuje smer toku energie?
(rozširovania)
- Reputace: 186
JJ, kuličky běhají správným směrem a barvičky "drátů" (a některé symboly) se mění dle toho odkud se energie bere ... Mají to celkem vymakané. Zatím testuju.
- Reputace: 535
Ja tam za boha neviem zobraziť dve batérie...
- Reputace: 186
Ty, že něco nevíš, jak nastavit v HA? Tomu nevěřím. Ale počet baterií tam asi nastavit jde libovolné množství (předpokládám). Jen je pro mne horor vyplnit správně všechny ty paramatery ...
