Tepelne cerpadlo-zkusenost
- Výkon panelů [Wp]: 7100
Kde to bylo na githubu už nevím, zkopíroval jsem si to do texťáku pro inspiraci.
Kód: Vybrat vše
]esphome:
esp32:
board: esp32dev
framework:
type: arduino
uart:
tx_pin: 17
rx_pin: 16
baud_rate: 9600
stop_bits: 1
modbus:
flow_control_pin: 4
modbus_controller:
- id: heatpump
## the Modbus device addr
address: 0x1
modbus_id: modbus1
setup_priority: -10
sensor:
- platform: modbus_controller
modbus_controller_id: heatpump
register_type: holding
address: 10
unit_of_measurement: "°C"
value_type: U_WORD
address: 13
value_type: U_WORD
address: 118
value_type: U_WORD
accuracy_decimals: 1
filters:
- multiply: 0.1
address: 119
value_type: U_WORD
filters:
- multiply: 0.1
address: 120
value_type: U_WORD
filters:
- multiply: 0.1
address: 121
value_type: U_WORD
filters:
- multiply: 0.1
address: 122
value_type: U_WORD
filters:
- multiply: 0.1
address: 123
value_type: U_WORD
filters:
- multiply: 0.1
name: "T-discharge pressure"
address: 124
value_type: U_WORD
filters:
- multiply: 0.1
name: "T-water out PE"
address: 125
value_type: U_WORD
filters:
- multiply: 0.1
name: "T-water in PE"
address: 127
value_type: U_WORD
filters:
- multiply: 0.1
address: 130
value_type: U_WORD
filters:
- multiply: 0.1
address: 131
value_type: U_WORD
filters:
- multiply: 0.1
name: "S-setting frequency"
address: 142
unit_of_measurement: "Hz"
value_type: U_WORD
#filters:
#- multiply: 0.1
name: "S-running frequency"
address: 143
value_type: U_WORD
#filters:
#- multiply: 0.1
# - platform: modbus_controller
# modbus_controller_id: heatpump
# name: "On/Off"
# id: heatpump_test_reg042
# register_type: holding
# address: 42
# #unit_of_measurement: "AH"
# value_type: U_WORD
- platform: wifi_signal
update_interval: 30s
text_sensor:
bitmask: 0
address: 42
raw_encode: HEXBYTES
lambda: |-
uint16_t value = modbus_controller::word_from_hex_str(x, 0);
switch (value) {
case 0xAA: return std::string("On");
case 0X55: return std::string("Off");
default: return std::string("Unknown");
return x;
bitmask: 0
address: 117
lambda: |-
switch (value) {
case 0x01: return std::string("Cool");
case 0X02: return std::string("Heat");
case 0X06: return std::string("Hot water");
case 0X08: return std::string("Off");
return x;
bitmask: 0
address: 132
lambda: |-
switch (value) {
case 0X03: return std::string("Off");
return x;
switch:
- platform: gpio
pin: 12
- platform: gpio
pin: 14
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "n/slrTFPpVshbVi92+8OPc6Pr/zu21FVqG4aF1G0WH4="
ota:
password: "57a830c12becea926f64c474bebdb25b"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Esp-Kotelna Fallback Hotspot"
password: "FALLBACK"
captive_portal:
- R32_Versati Modbus V1.5.pdf
- (1.03 MiB) Staženo 26 x
- Lokalita: Posázaví
Pro Sinclair je třeba hledat Gree.
- Lokalita: okolí Teplic
- Výkon panelů [Wp]: 5460
Udajne to prave umi ekviterm s vlivem vnitrni teploty. Ja se spis bojim ze tepelko bude slabe Zkusim sezonu a uvidim jak pujde regulovat ruco blby je ze teplota zpatecky jde nastavit 25 a pri deltaT 3 je vystup 28 stupnu a min neudelam. Stejne budu muset pouzit pro rizeni prostorovy termostat aby to netopilo jenom na teplotu zpatecky. Nastesti remote control vstup funguje kdyz nejde aktivovat tim obyc ovladacem funkce termostatu takze pripojim termostat na remote control. Ten modbus by byl fajn i kdyz pro me je to vyssi divci
soami píše: ↑úte zář 24, 2024 5:10 pmEkviterm je v těch levných TČ poměrně o ničem. Je to pouze 1 přímka ve 2 teplotních bodech. Když pominu, že by to měla být křivka, tak 2 body jsou málo. Navíc ty máš TČ předimenzované a tam by byla třeba vyšší úroveň regulace - minimálně tedy ekviterm s vlivem vnitřní teploty, což nevím, jestli by ten upgrade řešil. Vyzkoušej sezonu a uvidíš - spíš bych popřemýšlel o modbusu, pokud se podaří někomu plně zprovoznit.ElektroEzs píše: ↑úte zář 24, 2024 12:50 pm Na Sinclair jsem koukal puvodne nez jsem koupil Grundiga. Ja porad vaham zda investovat 8tis a vymenit display a ziskat ekviterm a nebo se na to vykaslat
Ja mam pres ventily udelany ze muzu jet primo do podlahy nebo pres akumulaci. Ale pro tepelko vsichni tvrdi ze lepsi bez akumulace tak uvidim. Takze LOGO pridava teplotu topne vody na tepelku podle venkovni teploty?
PetrDubi píše: ↑úte zář 24, 2024 2:52 pm Tak tohle mě naštěstí nemusí trápit, protože mám ekviterm řešený v tom LOGO a teď jsem ho tam nechal taky, takže jenom zapínám a vypínám přes kontakt pro termostat TČ podle toho, jak je nahřátá AKU nádrž, ze které se krmí topení a teplotu na jakou se nahřívá mi řeší právě to LOGO podle venkovní teploty.
- Výkon panelů [Wp]: 5520
- Kapacita baterie [kWh]: 14
ElektroEzs: ja som zvedavý na COP po sezóne... Plyn ide u nás hore o 50% a bude asi horšie. Tam kde Ukrajina obsadila ruské územie, je plynová stanica plynovodu Bratstvo, ktorý prepravuje plyn na Slovensko.
Na povale mám ešte pár balíkov sklenej vaty, pôjdem to rozbaliť na existujúcu izoláciu. A ešte kúpim na zvyšok kde mi to nevystačí.
MUST PV1800 VHM 48V 5.5kW, 5.52kWp (12x TPL mono 460W, 2S2P východ, 2S4P juh), 16x 280 Ah LiFePO4 (14.3 kWh) BMS JBD-AP21S001-L21S-200A-B, SW: Home Assistant na Synology DS923+ ku tomu ESPHome, Tasmota, MariaDB, InfluxDB, Telegraf, Grafana, Zigbee2MQTT..., HW: ESPlan (ESP32 + LAN 8720 + RS485 + UART). Nejaké moje projekty: MUST-ESPhome, ELTEK Flatpack2 ESPhome, ESP32-EMON, PZEM-017@WiFi, diyBMS-CurrentShunt-ESPhome 01/2023 -> 10/2024 = 8.1 MWh AC
COP me taky zajima do konce tydne chci namontovat meric tepla a jeste musim udelat hadice EPDM mezi tepelko a alpex. Ja si budu muset pucit masinu a dofoukat vatu po tom co jsem tahal ty trubky a jeste me ceka zateplit pudu i kdyz neni obytna. Jinak mam v zaloze jeste 20m dreva.
TomHC píše: ↑úte zář 24, 2024 8:10 pm ElektroEzs: ja som zvedavý na COP po sezóne... Plyn ide u nás hore o 50% a bude asi horšie. Tam kde Ukrajina obsadila ruské územie, je plynová stanica plynovodu Bratstvo, ktorý prepravuje plyn na Slovensko.
Jak to má ElektroEZS, tak pokud bude mít ten Grundig alespoň standardní parametry TČ (teplosměnná plocha výparníku a hlavně kvalitní regulace), tak SCOP bude 4 a více - při TZ, podlahovém topení/teplotě vody a předimenzování TČ.
Realitu poznam v zime
Zná někdo Sinclaira S-Therm Yukon? Konkrétně mě zajímá, zda by nějak bylo možné provozovat vnější jednotku víceméně samostatně, jen s jednoduchým výměníkem uvnitř. Nebo jak moc sofistikovaná je komunikace mezi (samostatně prodávanou) vnější a (samostatně prodávanou) vnitřní jednotkou...
Yukon přímo nevím, ale Ontario/GSH takto provozuji - ale je to starší S-Therm 2. Starší S-Therm (GSH) měly možnost SCMI převodníku, který nahrazoval vnitřní hydrobox. Já mám vlastní ekvi regulaci přes 0-10V. Nové už nemají SCMI a mají pouze modbus. Nicméně v registrech není přímo řízení příkonu nebo frekvence kompresoru. Jediné "použitelné" je delta vody - přes požadovanou a deklarovanou. Nenašel jsem nic vhodnějšího. A prozatím jsem nezkoušel - dojíždím starý S-Therm a nové TČ nemám instalované.
- ModbusV15_2_S_Therm4.pdf
- (1.34 MiB) Staženo 21 x
To SHM má uvnitř vnější i vnitřní desku - obě propojený přes RS485. Prostě do monobloku nastěhovali i to, co je ve vnitřní jednotce.
Předpokládám, že dotaz byl k venkovní jednotce splitu, tj. MSH.
- Lokalita: Ostrava
- Výkon panelů [Wp]: 0
- Kapacita baterie [kWh]: 0
- Chci/Mám dotaci: ANO
tak ovladac grundigu prijima write prikazy i na tu oblast nastaveni, takze holding registry na pozici 2000 muzete prepsat (kdyz se na prasaka vecpete do sbernice) a menit nastaveni pomoci modbusu (z ovladace si to pak precte TC)
treba takhle:
treba takhle:
Kód: Vybrat vše
mbpoll -m rtu -b 9600 -a 240 -r 2000 -0 -P none -v /dev/USB0 -1 8 0 0 21 26 43 27
BTW: zkousel jsem, jestli se modbus na H1,H2 nerozbehne po nastaveni "76 Adresa skupinového řízení" na 1 (jak to maji nektera jina TC), tak nerozbehnea1bert píše: ↑ned zář 22, 2024 9:55 pm
-jednotka pravidelne cte stav ovladace (addr pozice 2000): GHP/3/240/2000: [8, 1, 16, 20, 26, 43, 27]:
8 - zvoleny mod na ovladaci
1 - ovladac je zapnuty (0 - vypnuty)
16 - nejaka bitova maska 16 = 00001000 5. bit zapnuty nocni rezim
20 - teplota chlazeni
26 - teplota topeni
43 - teplota TUV
27 - teplota modu AUTO
Ma Shelly modul ke kteremu by sel pripojit meric tepla s pulznim vystupem? Hledal jsem ale nemuzu najit. Chtel jsem mit mereni tepla v aplikaci stejne jako Shelly EM pro tepelko abych mohl porovnavat. Diky
Diky moc jdu objednat. Super ze k tomu muzu pripojit 5 cidel tak muzu online sledovat 5teplot.
Jeste budu muset otevrit ten meric de-16-mi004-ptb025 a podivat se jestli to ma pripraveny pulzni vystup na desce, kabel ven vyvedeny neni
1pulz je 1kwh cekal jsem ze bude 1pulz mensi. Takhle se bude blbe pocitat COP za 1den kdyz to bere na cele kwh
Je to měřák spotřeby, ne výkonu. Pro monitoring TČ docela nepoužitelné. Ale nějaká roční data na tom uvidíš. Vodoměr, 2 dallasy a PLC by udělalo mnohem víc práce.
Tohle umi zobrazit i aktualni vykon. Ten Qundis DN15 co jsme mel meril na desetiny
- 19 Odpovědi
- 2374 Zobrazení
Poslední příspěvek od Elmelund
- 4 Odpovědi
- 2000 Zobrazení
Poslední příspěvek od ringo
- 0 Odpovědi
- 611 Zobrazení
Poslední příspěvek od netko
- 25 Odpovědi
- 2541 Zobrazení
Poslední příspěvek od Damned
- 20 Odpovědi
- 3542 Zobrazení
Poslední příspěvek od Kostěj
