Tepelne cerpadlo-zkusenost
PetrDubi
Reputace: 320
Výkon panelů [Wp]: 10790
Kapacita baterie [kWh]: 13
Nový příspěvek od PetrDubi »
androfx píše: úte zář 24, 2024 3:29 pm
Mohl by jsi sdílet, kde na githubu jsi to našel? Popřípadě i tu dokumentaci k modbusu? Díky!
Kde to bylo na githubu už nevím, zkopíroval jsem si to do texťáku pro inspiraci.
Kód: Vybrat vše
]esphome:
esp32:
  board: esp32dev
  framework:
    type: arduino
uart:
  tx_pin: 17
  rx_pin: 16
  baud_rate: 9600
  stop_bits: 1
modbus:
  flow_control_pin: 4
modbus_controller:
  - id: heatpump
    ## the Modbus device addr
    address: 0x1
    modbus_id: modbus1
    setup_priority: -10
sensor:
  - platform: modbus_controller
    modbus_controller_id: heatpump
    register_type: holding
    address: 10
    unit_of_measurement: "°C"
    value_type: U_WORD
    address: 13
    value_type: U_WORD
    address: 118
    value_type: U_WORD
    accuracy_decimals: 1
    filters:
    - multiply: 0.1
    address: 119
    value_type: U_WORD
    filters:
    - multiply: 0.1
    address: 120
    value_type: U_WORD
    filters:
    - multiply: 0.1
    address: 121
    value_type: U_WORD
    filters:
    - multiply: 0.1
    address: 122
    value_type: U_WORD
    filters:
    - multiply: 0.1
    address: 123
    value_type: U_WORD
    filters:
    - multiply: 0.1
    name: "T-discharge pressure"
    address: 124
    value_type: U_WORD
    filters:
    - multiply: 0.1
    name: "T-water out PE"
    address: 125
    value_type: U_WORD
    filters:
    - multiply: 0.1
    name: "T-water in PE"
    address: 127
    value_type: U_WORD
    filters:
    - multiply: 0.1
    address: 130
    value_type: U_WORD
    filters:
    - multiply: 0.1
    address: 131
    value_type: U_WORD
    filters:
    - multiply: 0.1
    name: "S-setting frequency"
    address: 142
    unit_of_measurement: "Hz"
    value_type: U_WORD
    #filters:
    #- multiply: 0.1
    name: "S-running frequency"
    address: 143
    value_type: U_WORD
    #filters:
    #- multiply: 0.1
#  - platform: modbus_controller
#    modbus_controller_id: heatpump
#    name: "On/Off"
#    id: heatpump_test_reg042
#    register_type: holding
#    address: 42
#    #unit_of_measurement: "AH"
#    value_type: U_WORD
  - platform: wifi_signal
    update_interval: 30s
text_sensor:
    bitmask: 0
    address: 42
    raw_encode: HEXBYTES
    lambda: |-
      uint16_t value = modbus_controller::word_from_hex_str(x, 0);
      switch (value) {
        case 0xAA: return std::string("On");
        case 0X55: return std::string("Off");
        default: return std::string("Unknown");
      return x;
    bitmask: 0
    address: 117
    lambda: |-
      switch (value) {
        case 0x01: return std::string("Cool");
        case 0X02: return std::string("Heat");
        case 0X06: return std::string("Hot water");
        case 0X08: return std::string("Off");
      return x;
    bitmask: 0
    address: 132
    lambda: |-
      switch (value) {
        case 0X03: return std::string("Off");
      return x;
switch:
  - platform: gpio
    pin: 12
  - platform: gpio
    pin: 14
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "n/slrTFPpVshbVi92+8OPc6Pr/zu21FVqG4aF1G0WH4="
ota:
  password: "57a830c12becea926f64c474bebdb25b"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Esp-Kotelna Fallback Hotspot"
    password: "FALLBACK"
captive_portal:
R32_Versati Modbus V1.5.pdf
(1.03 MiB) Staženo 232 x
soami
Reputace: 102
Lokalita: Posázaví
Nový příspěvek od soami »
Pro Sinclair je třeba hledat Gree.
ElektroEzs
Reputace: 83
Lokalita: okolí Teplic
Výkon panelů [Wp]: 8340
Kapacita baterie [kWh]: 14,4
Udajne to prave umi ekviterm s vlivem vnitrni teploty. Ja se spis bojim ze tepelko bude slabe😂 Zkusim sezonu a uvidim jak pujde regulovat ruco blby je ze teplota zpatecky jde nastavit 25 a pri deltaT 3 je vystup 28 stupnu a min neudelam. Stejne budu muset pouzit pro rizeni prostorovy termostat aby to netopilo jenom na teplotu zpatecky. Nastesti remote control vstup funguje kdyz nejde aktivovat tim obyc ovladacem funkce termostatu takze pripojim termostat na remote control. Ten modbus by byl fajn i kdyz pro me je to vyssi divci😂
soami píše: úte zář 24, 2024 5:10 pm
ElektroEzs píše: úte zář 24, 2024 12:50 pm
Na Sinclair jsem koukal puvodne nez jsem koupil Grundiga. Ja porad vaham zda investovat 8tis a vymenit display a ziskat ekviterm a nebo se na to vykaslat😂
Ekviterm je v těch levných TČ poměrně o ničem. Je to pouze 1 přímka ve 2 teplotních bodech. Když pominu, že by to měla být křivka, tak 2 body jsou málo. Navíc ty máš TČ předimenzované a tam by byla třeba vyšší úroveň regulace - minimálně tedy ekviterm s vlivem vnitřní teploty, což nevím, jestli by ten upgrade řešil. Vyzkoušej sezonu a uvidíš - spíš bych popřemýšlel o modbusu, pokud se podaří někomu plně zprovoznit.
ElektroEzs
Reputace: 83
Ja mam pres ventily udelany ze muzu jet primo do podlahy nebo pres akumulaci. Ale pro tepelko vsichni tvrdi ze lepsi bez akumulace tak uvidim. Takze LOGO pridava teplotu topne vody na tepelku podle venkovni teploty?
PetrDubi píše: úte zář 24, 2024 2:52 pm
Tak tohle mě naštěstí nemusí trápit, protože mám ekviterm řešený v tom LOGO a teď jsem ho tam nechal taky, takže jenom zapínám a vypínám přes kontakt pro termostat TČ podle toho, jak je nahřátá AKU nádrž, ze které se krmí topení a teplotu na jakou se nahřívá mi řeší právě to LOGO podle venkovní teploty.
Reputace: 689
Výkon panelů [Wp]: 8820
Nový příspěvek od TomHC »
ElektroEzs: ja som zvedavý na COP po sezóne... Plyn ide u nás hore o 50% a bude asi horšie. Tam kde Ukrajina obsadila ruské územie, je plynová stanica plynovodu Bratstvo, ktorý prepravuje plyn na Slovensko.
Na povale mám ešte pár balíkov sklenej vaty, pôjdem to rozbaliť na existujúcu izoláciu. A ešte kúpim na zvyšok kde mi to nevystačí.
ElektroEzs
Reputace: 83
COP me taky zajima do konce tydne chci namontovat meric tepla a jeste musim udelat hadice EPDM mezi tepelko a alpex. Ja si budu muset pucit masinu a dofoukat vatu po tom co jsem tahal ty trubky a jeste me ceka zateplit pudu i kdyz neni obytna. Jinak mam v zaloze jeste 20m dreva.
TomHC píše: úte zář 24, 2024 8:10 pm
soami
Reputace: 102
Lokalita: Posázaví
Jak to má ElektroEZS, tak pokud bude mít ten Grundig alespoň standardní parametry TČ (teplosměnná plocha výparníku a hlavně kvalitní regulace), tak SCOP bude 4 a více - při TZ, podlahovém topení/teplotě vody a předimenzování TČ.
ElektroEzs
Reputace: 83
Realitu poznam v zime😂
soami píše: úte zář 24, 2024 8:27 pm
Reputace: 399
Lokalita: JV od pekla :)
Výkon panelů [Wp]: 5100
Kapacita baterie [kWh]: 33
Nový příspěvek od unicast »
Zná někdo Sinclaira S-Therm Yukon? Konkrétně mě zajímá, zda by nějak bylo možné provozovat vnější jednotku víceméně samostatně, jen s jednoduchým výměníkem uvnitř. Nebo jak moc sofistikovaná je komunikace mezi (samostatně prodávanou) vnější a (samostatně prodávanou) vnitřní jednotkou...
soami
Reputace: 102
Lokalita: Posázaví
Yukon přímo nevím, ale Ontario/GSH takto provozuji - ale je to starší S-Therm 2. Starší S-Therm (GSH) měly možnost SCMI převodníku, který nahrazoval vnitřní hydrobox. Já mám vlastní ekvi regulaci přes 0-10V. Nové už nemají SCMI a mají pouze modbus. Nicméně v registrech není přímo řízení příkonu nebo frekvence kompresoru. Jediné "použitelné" je delta vody - přes požadovanou a deklarovanou. Nenašel jsem nic vhodnějšího. A prozatím jsem nezkoušel - dojíždím starý S-Therm a nové TČ nemám instalované.
ModbusV15_2_S_Therm4.pdf
(1.34 MiB) Staženo 105 x
PetrDubi
Reputace: 320
To SHM má uvnitř vnější i vnitřní desku - obě propojený přes RS485. Prostě do monobloku nastěhovali i to, co je ve vnitřní jednotce.
soami
Reputace: 102
Lokalita: Posázaví
Předpokládám, že dotaz byl k venkovní jednotce splitu, tj. MSH.
a1bert
Reputace: 13
Lokalita: Ostrava
Výkon panelů [Wp]: 0
Kapacita baterie [kWh]: 0
Chci/Mám dotaci: ANO
Nový příspěvek od a1bert »
tak ovladac grundigu prijima write prikazy i na tu oblast nastaveni, takze holding registry na pozici 2000 muzete prepsat (kdyz se na prasaka vecpete do sbernice) a menit nastaveni pomoci modbusu (z ovladace si to pak precte TC)
treba takhle:
Kód: Vybrat vše
mbpoll -m rtu -b 9600 -a 240 -r 2000 -0  -P none -v  /dev/USB0 -1  8 0 0 21 26 43 27
a1bert píše: ned zář 22, 2024 9:55 pm
-jednotka pravidelne cte stav ovladace (addr pozice 2000): GHP/3/240/2000: [8, 1, 16, 20, 26, 43, 27]:
8 - zvoleny mod na ovladaci
1 - ovladac je zapnuty (0 - vypnuty)
16 - nejaka bitova maska 16 = 00001000 5. bit zapnuty nocni rezim
20 - teplota chlazeni
26 - teplota topeni
43 - teplota TUV
27 - teplota modu AUTO
BTW: zkousel jsem, jestli se modbus na H1,H2 nerozbehne po nastaveni "76 Adresa skupinového řízení" na 1 (jak to maji nektera jina TC), tak nerozbehne :(
ElektroEzs
Reputace: 83
Ma Shelly modul ke kteremu by sel pripojit meric tepla s pulznim vystupem? Hledal jsem ale nemuzu najit. Chtel jsem mit mereni tepla v aplikaci stejne jako Shelly EM pro tepelko abych mohl porovnavat. Diky
mgx
Reputace: 113
Nový příspěvek od mgx »
ElektroEzs
Reputace: 83
Diky moc jdu objednat. Super ze k tomu muzu pripojit 5 cidel tak muzu online sledovat 5teplot.
ElektroEzs
Reputace: 83
Jeste budu muset otevrit ten meric de-16-mi004-ptb025 a podivat se jestli to ma pripraveny pulzni vystup na desce, kabel ven vyvedeny neni😂
ElektroEzs
Reputace: 83
1pulz je 1kwh cekal jsem ze bude 1pulz mensi. Takhle se bude blbe pocitat COP za 1den kdyz to bere na cele kwh
soami
Reputace: 102
Lokalita: Posázaví
Je to měřák spotřeby, ne výkonu. Pro monitoring TČ docela nepoužitelné. Ale nějaká roční data na tom uvidíš. Vodoměr, 2 dallasy a PLC by udělalo mnohem víc práce.
ElektroEzs
Reputace: 83
Tohle umi zobrazit i aktualni vykon. Ten Qundis DN15 co jsme mel meril na desetiny
soami píše: čtv zář 26, 2024 11:31 am
