MUST a CANBUS batérie
informace, návody, rady a diskuze ohledně sortimentu mivvy ENERGY
- Reputace: 14
Re: MUST a CANBUS batérie
Jak mas napsany kod pro vypis CAN frame? (pro cteni z CANBUSu)
- Reputace: 535
Nechal som tam len výpis na konzolu, ale ani ťuk.tRp píše:Jak mas napsany kod pro vypis CAN frame? (pro cteni z CANBUSu)
Kód: Vybrat vše
canbus:
- platform: esp32_can
rx_pin: GPIO35
tx_pin: GPIO33
can_id: 0x1fff
use_extended_id: true
bit_rate: 100kbps
on_frame:
- can_id: 0x0cc20201
then:
- lambda: |-
ESP_LOGI("main", "CAN msg 0x0cc20201 received");
//float can_napatie_bat = ((int)(x[1]) << 8) + x[0];
//can_napatie_bat = can_napatie_bat / 10;
//id(napeti_baterie).publish_state(can_napatie_bat);
//ESP_LOGI("main", "CAN napatie baterie: can_napatie_bat");
- can_id: 0x0cc10201
then:
- lambda: |-
ESP_LOGI("main", "CAN msg 0x0cc10201 received");
//float can_napatie_pv = ((int)(x[1]) << 8) + x[0];
//can_napatie_pv = can_napatie_pv / 10;
//ESP_LOGI("main", "CAN napatie panelov: can_napatie_pv");
//float can_vykon_pv = ((int)(x[7]) << 8) + x[6];
//ESP_LOGI("main", "CAN vykon panelov: can_vykon_pv");
- Reputace: 535
Skúsim ešte druhý receiver, iný pin a potom napichnem na RX pin Saleae Logic
- Reputace: 14
TomHC píše:Nechal som tam len výpis na konzolu, ale ani ťuk.tRp píše:Jak mas napsany kod pro vypis CAN frame? (pro cteni z CANBUSu)Kód: Vybrat vše
canbus: - platform: esp32_can rx_pin: GPIO35 tx_pin: GPIO33 can_id: 0x1fff id: canbusmust use_extended_id: true bit_rate: 100kbps on_frame: - can_id: 0x0cc20201 use_extended_id: true then: - lambda: |- ESP_LOGI("main", "CAN msg 0x0cc20201 received"); //float can_napatie_bat = ((int)(x[1]) << 8) + x[0]; //can_napatie_bat = can_napatie_bat / 10; //id(napeti_baterie).publish_state(can_napatie_bat); //ESP_LOGI("main", "CAN napatie baterie: can_napatie_bat"); - can_id: 0x0cc10201 use_extended_id: true then: - lambda: |- ESP_LOGI("main", "CAN msg 0x0cc10201 received"); //float can_napatie_pv = ((int)(x[1]) << 8) + x[0]; //can_napatie_pv = can_napatie_pv / 10; //ESP_LOGI("main", "CAN napatie panelov: can_napatie_pv"); //float can_vykon_pv = ((int)(x[7]) << 8) + x[6]; //ESP_LOGI("main", "CAN vykon panelov: can_vykon_pv");
Zkopiroval jsem tento kousek kodu do meho:
Kód: Vybrat vše
then:
- lambda: |-
Kód: Vybrat vše
[20:30:57][D][canbus:067]: received can message (#1) extended can_id=0xcc20201 size=8
[20:30:57][I][main:476]: CAN msg 0x0cc20201 received
- Reputace: 535
Takže dnes nastal čas pre logický analyzátor, a na CAN zbernici nie je nič okrem packetov ktoré posielam ja z ESP32. Pekne vidieť, že idú v sekundových intervaloch, ale inak tam nie je nič. Možno by to chcelo odpojiť ESP8266 z RS485 zbernice, neviem či vedia fungovať paralelne. Alebo reštartovať menič, ale to je trochu problém, lebo je na ňom zavesený celý dom.
- Reputace: 14
Zkoušel jsi "pověsit" analyzátor přímo na měnič (bez připojeného ESP a CANBus modulu) ?
- Reputace: 535
Ešte nie, bol rodinný víkend, možno dnes - https://support.saleae.com/protocol-ana ... ltage-datatRp píše:Zkoušel jsi "pověsit" analyzátor přímo na měnič (bez připojeného ESP a CANBus modulu) ?
- Reputace: 535
Takže len takýto bordeltRp píše:Zkoušel jsi "pověsit" analyzátor přímo na měnič (bez připojeného ESP a CANBus modulu) ?
- Lokalita: Ukraine
- Výkon panelů [Wp]: 5.52kWp
- Kapacita baterie [kWh]: 5.0kW
Hezký den všem.
může někdo sdílet canbus.send
jaké parametry posíláte pro MUSÍ invertor
Aktuální SOC, SOH.
Skutečné volty, ampéry, tep
Aktuální SOC, SOH.
- Reputace: 535
Kód: Vybrat vše
- canbus.send:
can_id: 0x00030500
canbus_id: canbusmust
data: !lambda |-
uint8_t can_mesg[8];
can_mesg[0] = uint16_t(id(ha_batt_soc).state) & 0xff;
can_mesg[1] = uint16_t(id(ha_batt_soc).state) >> 8 & 0xff;
can_mesg[2] = 0x00;
can_mesg[3] = 0x64; // SoH = 100%
can_mesg[4] = uint16_t(id(ha_batt_soc).state * 100) & 0xff;
can_mesg[5] = uint16_t(id(ha_batt_soc).state * 100) >> 8 & 0xff;
ESP_LOGI("main", "Sending CAN ID: 0x00030500 hex: %02X %02X %02X %02X %02X %02X %02X %02X", can_mesg[0], can_mesg[1], can_mesg[2], can_mesg[3], can_mesg[4], can_mesg[5], can_mesg[6], can_mesg[7]);
return {can_mesg[0], can_mesg[1], can_mesg[2], can_mesg[3], can_mesg[4], can_mesg[5], can_mesg[6], can_mesg[7]};
# SOC 80 SOH 95 HiRes SOC reserved
# {0x00, 0x50, 0x00, 0x5F, 0x00, 0x00, 0x00, 0x00};
# HiRes SOC 0.01%
- Lokalita: Ukraine
předáte pouze 0x00030500
a jako 0x00030400 (odeslání BMS, 0x00030400 (odeslání BMS)
Kód: Vybrat vše
interval:
- interval: 1000ms
then:
- lambda: |-
ESP_LOGI("main", "capacity_remaining: %f, charging_cycles: %f, total_voltage: %f, current: %f, temperature_sensor_1: %f, temperature_sensor_2: %f",
id(capacity_remaining).state, id(charging_cycles).state, id(total_voltage).state, id(current).state, id(temperature_sensor_1).state, id(temperature_sensor_2).state);
- canbus.send: # Actual SOC, SOH
can_id: 0x00030500
data: !lambda |-
int soh = round(((id(charging_cycles).state/${max_cycles})-1)*-100);
uint8_t can_mesg[8] = {0};
can_mesg[0] = uint16_t(id(capacity_remaining).state) & 0xff;
can_mesg[1] = uint16_t(id(capacity_remaining).state) >> 8 & 0xff;
can_mesg[2] = soh & 0xff;
can_mesg[3] = soh >> 8 & 0xff;
ESP_LOGI("main", "send can id: 0x00030500 hex: %x %x %x %x", can_mesg[0], can_mesg[1], can_mesg[2], can_mesg[3]);
- delay: 10ms
- canbus.send: # Actual Volts, Amps, Temp
can_id: 0x00030400
data: !lambda |-
// Запис Battery Voltage (байти 1 та 2), масштаб 0.1V
can_mesg[0] = uint16_t(id(total_voltage).state * 10) & 0xff; // Молодший байт напруги
can_mesg[1] = uint16_t(id(total_voltage).state * 10) >> 8 & 0xff; // Старший байт напруги
// Запис Battery Current (байти 3 та 4), масштаб 0.1A
can_mesg[2] = int16_t(id(current).state * 10) & 0xff; // Молодший байт струму
can_mesg[3] = int16_t(id(current).state * 10) >> 8 & 0xff; // Старший байт струму
// Запис Battery Temperature (байти 5 та 6), масштаб 1°C
int temperature = max(id(temperature_sensor_1).state, id(temperature_sensor_2).state);
can_mesg[4] = int16_t(temperature) & 0xff; // Молодший байт температури
can_mesg[5] = int16_t(temperature) >> 8 & 0xff; // Старший байт температури
// Запис Error and Warning (байти 7 та 8) - залишаємо як 0, якщо немає помилок
can_mesg[6] = 0x00;
can_mesg[7] = 0x00;
// Лог для перевірки перед відправкою
ESP_LOGI("main", "send can id: 0x00030400 hex: %x %x %x %x %x %x %x %x", can_mesg[0], can_mesg[1], can_mesg[2], can_mesg[3], can_mesg[4], can_mesg[5], can_mesg[6], can_mesg[7]);
// Відправлення повідомлення
- delay: 10ms
- lambda: |- # Detect no CAN reply
if (id(can_305_rx) > 30) {
ESP_LOGI("main", "No rx can 0x305 reply, Inverter not connected/responding, Rebooting...");
id(restart_button).press();
} else {
id(can_305_rx) ++;
- Lokalita: Ukraine
četl jsem zde https://github.com/Sleeper85/esphome-yambms
vypadá to, že se provádí nějaká automatizace
ale nepodporují MUST protokol
to je v podstatě to, co se snažím udělat pro MUST
- Reputace: 535
Obávam sa, že ti vôbec nerozumiem...
- Lokalita: Ukraine
Můžete sdílet
k čemu využíváte celý canbus.send
all config yaml?
all config yaml?
- Reputace: 535
Celý yaml sem určite nedám. Canbus.send je predsa na odoslanie CAN packetu, komentáre a názvy premenných sú dosť popisné.
