MUST a CANBUS batérie
informace, návody, rady a diskuze ohledně sortimentu mivvy ENERGY
Re: MUST a CANBUS batérie
Jak mas napsany kod pro vypis CAN frame? (pro cteni z CANBUSu)
- Výkon panelů [Wp]: 5520
- Kapacita baterie [kWh]: 14
Nechal som tam len výpis na konzolu, ale ani ťuk.tRp píše:Jak mas napsany kod pro vypis CAN frame? (pro cteni z CANBUSu)
Kód: Vybrat vše
canbus:
- platform: esp32_can
rx_pin: GPIO35
tx_pin: GPIO33
can_id: 0x1fff
use_extended_id: true
bit_rate: 100kbps
on_frame:
- can_id: 0x0cc20201
then:
- lambda: |-
ESP_LOGI("main", "CAN msg 0x0cc20201 received");
//float can_napatie_bat = ((int)(x[1]) << 8) + x[0];
//can_napatie_bat = can_napatie_bat / 10;
//id(napeti_baterie).publish_state(can_napatie_bat);
//ESP_LOGI("main", "CAN napatie baterie: can_napatie_bat");
- can_id: 0x0cc10201
then:
- lambda: |-
ESP_LOGI("main", "CAN msg 0x0cc10201 received");
//float can_napatie_pv = ((int)(x[1]) << 8) + x[0];
//can_napatie_pv = can_napatie_pv / 10;
//ESP_LOGI("main", "CAN napatie panelov: can_napatie_pv");
//float can_vykon_pv = ((int)(x[7]) << 8) + x[6];
//ESP_LOGI("main", "CAN vykon panelov: can_vykon_pv");
MUST PV1800 VHM 48V 5.5kW, 5.52kWp (12x TPL mono 460W, 2S2P východ, 2S4P juh), 16x 280 Ah LiFePO4 (14.3 kWh) BMS JBD-AP21S001-L21S-200A-B, SW: Home Assistant na Synology DS923+ ku tomu ESPHome, Tasmota, MariaDB, InfluxDB, Telegraf, Grafana, Zigbee2MQTT..., HW: ESPlan (ESP32 + LAN 8720 + RS485 + UART). Nejaké moje projekty: MUST-ESPhome, ELTEK Flatpack2 ESPhome, ESP32-EMON, PZEM-017@WiFi, diyBMS-CurrentShunt-ESPhome
Skúsim ešte druhý receiver, iný pin a potom napichnem na RX pin Saleae Logic
TomHC píše:Nechal som tam len výpis na konzolu, ale ani ťuk.tRp píše:Jak mas napsany kod pro vypis CAN frame? (pro cteni z CANBUSu)Kód: Vybrat vše
canbus: - platform: esp32_can rx_pin: GPIO35 tx_pin: GPIO33 can_id: 0x1fff id: canbusmust use_extended_id: true bit_rate: 100kbps on_frame: - can_id: 0x0cc20201 use_extended_id: true then: - lambda: |- ESP_LOGI("main", "CAN msg 0x0cc20201 received"); //float can_napatie_bat = ((int)(x[1]) << 8) + x[0]; //can_napatie_bat = can_napatie_bat / 10; //id(napeti_baterie).publish_state(can_napatie_bat); //ESP_LOGI("main", "CAN napatie baterie: can_napatie_bat"); - can_id: 0x0cc10201 use_extended_id: true then: - lambda: |- ESP_LOGI("main", "CAN msg 0x0cc10201 received"); //float can_napatie_pv = ((int)(x[1]) << 8) + x[0]; //can_napatie_pv = can_napatie_pv / 10; //ESP_LOGI("main", "CAN napatie panelov: can_napatie_pv"); //float can_vykon_pv = ((int)(x[7]) << 8) + x[6]; //ESP_LOGI("main", "CAN vykon panelov: can_vykon_pv");
Zkopiroval jsem tento kousek kodu do meho:
Kód: Vybrat vše
then:
- lambda: |-
Kód: Vybrat vše
[20:30:57][D][canbus:067]: received can message (#1) extended can_id=0xcc20201 size=8
[20:30:57][I][main:476]: CAN msg 0x0cc20201 received
Takže dnes nastal čas pre logický analyzátor, a na CAN zbernici nie je nič okrem packetov ktoré posielam ja z ESP32. Pekne vidieť, že idú v sekundových intervaloch, ale inak tam nie je nič. Možno by to chcelo odpojiť ESP8266 z RS485 zbernice, neviem či vedia fungovať paralelne. Alebo reštartovať menič, ale to je trochu problém, lebo je na ňom zavesený celý dom.
Zkoušel jsi "pověsit" analyzátor přímo na měnič (bez připojeného ESP a CANBus modulu) ?
Ešte nie, bol rodinný víkend, možno dnes - https://support.saleae.com/protocol-ana ... ltage-datatRp píše:Zkoušel jsi "pověsit" analyzátor přímo na měnič (bez připojeného ESP a CANBus modulu) ?
Takže len takýto bordeltRp píše:Zkoušel jsi "pověsit" analyzátor přímo na měnič (bez připojeného ESP a CANBus modulu) ?
Prepojenie JK BMS a Sorotec REVO VM-II cez CANBUS
od DUGi » » v Regulátory
- 2 Odpovědi
- 542 Zobrazení
Poslední příspěvek od DUGi
PWM jako nabíječ 12v baterie z 24v baterie?
od diablo007 » » v Regulátory
- 22 Odpovědi
- 1737 Zobrazení
Poslední příspěvek od JonasPP
- 5 Odpovědi
- 747 Zobrazení
Poslední příspěvek od tomas
- 36 Odpovědi
- 2027 Zobrazení
Poslední příspěvek od Nezmar
- 2 Odpovědi
- 651 Zobrazení
Poslední příspěvek od laco76
