HomeAssistant - Workshop 1 - 16.1.2022 8.30
Diskuze, rady a návody ohledně HomeAssistant
mgx
Reputace: 109
Nový příspěvek od mgx »
Informacie o planovanom zoom workshope ohladom instalacie HOME ASSISTANT
Termin: 16.1.2022 8.30-10.00
Zoom mam profesionalnu verziu, takze je to bez limitu (pocet ludi + cas). Na sledovanie Vam staci webovy prehliadac.
Zaznam potom hodim na youtube a moj web.
Prihlasenim na zoom session suhlasite s tym, ze sa to bude nahravat a pouzije sa to/zverejni na YT. Nie je v mojich silach vystrihovat a editovat :).
Podrobny postup a pokec hodim tiez na YT+do fora. Vyhoda pripojit sa je, ze sa mozete spytat otazky, pripadne vyriesime rovno problemy s instalaciou (ak nastanu).
Predbezny termin: 16.1 (nedela) 8.30-10.00 cez zoom
otestovat si mozete pripojenie a zoom cez: https://zoom.us/test treba kliknut na tlacitko Join, Launch a Meeting a
Zoom
Zoom Conference Details:
Invitation from: Mgx
Topic: HOME ASSISTANT workshop 1
Time: Jan 16, 2022 08:30 AM Warsaw
Single click URL to join Zoom: https://oracle.zoom.us/j/94782187985?pw ... E2ME1WUT09
Meeting ID: 947 8218 7985
Password: 76438956
One tap mobile
+13126266799,,94782187985# US (Chicago)
+13462487799,,94782187985# US (Houston)
Dial by your location
+1 312 626 6799 US (Chicago)
+1 346 248 7799 US (Houston)
+1 646 558 8656 US (New York)
+1 669 900 6833 US (San Jose)
+1 720 928 9299 US (Denver)
+1 206 337 9723 US (Seattle)
+1 213 338 8477 US (Los Angeles)
+1 253 215 8782 US (Tacoma)
+1 301 715 8592 US (Washington DC)
Password: 76438956
Find your local number: https://oracle.zoom.us/u/adPjroD4bA
Join by SIP
94782187985@zoomcrc.com
Join by H.323
162.255.37.11 (US West)
162.255.36.11 (US East)
115.114.131.7 (India Mumbai)
115.114.115.7 (India Hyderabad)
213.19.144.110 (Amsterdam Netherlands)
213.244.140.110 (Germany)
103.122.166.55 (Australia Sydney)
103.122.167.55 (Australia Melbourne)
209.9.211.110 (Hong Kong SAR)
149.137.40.110 (Singapore)
64.211.144.160 (Brazil)
149.137.68.253 (Mexico)
69.174.57.160 (Canada Toronto)
65.39.152.160 (Canada Vancouver)
207.226.132.110 (Japan Tokyo)
149.137.24.110 (Japan Osaka)
Password: 76438956
Priprava: Ak si chcete nachystat vlastny HW s OS, je to VELMI doporucene. V podstate budete potrebovat len 2 veci:
0) HW a SD kartu. doporucujem 32GB a vacsiu.
1) funkcny operacny system debian bullseye (32bit alebo 64bit) na Vasom HW
ak mate malinu (ja mam RPI4B) (raspberry pi 2,3,4) tak napr.
maly image
https://downloads.raspberrypi.org/raspi ... 4-lite.zip
velky image pre malinu: 2021-10-30-raspios-bullseye-arm64.zip
https://downloads.raspberrypi.org/raspi ... 021-11-08/
toto si stiahnite a cez program etcher (stiahnut tu: https://www.balena.io/etcher/ ) rozbalite na sd kartu a nainstalujete si na raspberry cisty debian bullseye (raspios) alebo plnu instalaciu s
Xwindows, je to na Vas. Inspiracne video: https://www.youtube.com/watch?v=PijX8GD ... aspberryPi. Cielovy OS treba mat nainstalovany a funkcny.
Tu je oficialna stranka pre BULLSEYE na Raspberry Pi:
https://www.raspberrypi.com/software/op ... -os-32-bit
Pozor,image su 32 bitove. Je lepsie pouzit linky hore, ale nevadi to.
Ak mate iny HW, napr. toto
https://www.debian.org/releases/bullseye/
2) funkcny internet (tzn. na vasom raspberry, HW ) sa musi dat pingnut 8.8.8.8 alebo spustit apt-get update
Budeme instalovat HomeAssistant SUpervized, problem je ze aktualne su podporovane len tieto platformy:
generic-x86-64
odroid-c2
odroid-n2
odroid-xu
qemuarm
qemuarm-64
qemux86
qemux86-64
raspberrypi
raspberrypi2
raspberrypi3
raspberrypi4
raspberrypi3-64
raspberrypi4-64
tinker
khadas-vim3
Ak tam svoju nevidite, napiste mi. Asi budete musiet pouzit HASSOS :(.
danidani
Reputace: 7
Re: HomeAssistant - Workshop 1 - 16.1.2022 8.30
Nový příspěvek od danidani »
Ahoj, ještě jednou díky za dnešní online. Těším se na příště :-)
Navržená témata:
1. Vyčítání dat ze střídače
2. Ukládání do db
3. Vizualizace
Třeba někdo pomůže s realizací.
Za sebe: Já vyčítám data z GoodWe ET řady, instaloval jsem tuhle integraci (inspiroval jsem se tady - velký dík autorovi, pokud to tu čte) a je to plug-and-play, kdyby byl zájem, můžu dát postup. Po napojení je možné zprovoznit Energy panel a hned jsou k dispozici hezké základní statistiky.
mgx
Reputace: 109
Dakujem za ucast,
zaznam s workshopu a postup instalacie najdete na
https://youtu.be/pNW3xVf9GKQ
mgx
Reputace: 109
Pridal som diel 2
Home Assistant Supervised 2022 #2 - SSH a HACS
Inštalácia SSH (terminal) a HACS (Home assistant comunity store)
https://youtu.be/paRPfuHf5wY
mgx
Reputace: 109
Pridal som diel 3
Home Assistant Supervised 2022 #3 - Zariadenia, Entity, Automatizácie, Pridanie zariadenia
https://www.youtube.com/watch?v=0CFYxmm5tWs
ChlapeczDediny
Reputace: 82
Lokalita: Juh BBSK
Výkon panelů [Wp]: 3100
Super videá, ďakujem za ne. Už mám vo Virtualboxe Debian 11 a v ňom v dockeri HA a moduly, čakám na regulátor nabíjania aj raspberry.
3s2p Amerisolar 285 = 1,7 kWp JJV + 3s2p 240 = 1,4 kWp ZJZ, Epever 5420AN, Epever 6420AN, 12 kWh 14s100p LiIon 18650 + JK BMS 200A, 18 kWh CATL 14s3p LiIon 115Ah +JBD BMS 60A, Epever iPower 5 kW
mgx
Reputace: 109
Pridany diel 4
Home Assistant Supervised 2022 #4 - InfluxDB, Grafana
https://youtu.be/_uDzCWpGJBI
tomekson
Nový příspěvek od tomekson »
To jsou super videa mgx, díky za ně!
Rád bych si postavil vlastní CC2530 router pro Zigbee podle návodu: https://www.zigbee2mqtt.io/advanced/zig ... outer.html
Chtěl bych se poradit, kde členové fóra nakupují komponenty atp. V českých eshopech jsem nic moc nenašel a odkazy v tom seznamu komponent na zigbee2mqtt.io už většinou nefungují nebo vedou na Aliexpressu na jiné/podobné produkty.
Díval jsem se na ebay.de a amazon.de kde nějaké komponenty sehnat jdou (Zigbee modul s anténou a emulátor CC debugger), ale přijde mi, že se něco takového přece musí dát sehnat i u nás. Nebo všichni místní bastliči nakupují mimo ČR a SR, protože to prostě jinak sehnat nejde? :|
Díky
Tomek
ChlapeczDediny
Reputace: 82
Lokalita: Juh BBSK
Něco je i na www.Banggood.com a čidlo teploty a vlhkosti z českého skladu bylo na svk za tři dny. Rychle to je i z Polska.
mgx
Reputace: 109
tieto veci nema ziadny vyznam kupovat na SK/CZ. Aliexpress ti USB dongle za 5euro aj s postovnym pride cca za mesiac.
https://www.aliexpress.com/item/4000822 ... e870d480b7
samozrejme, ak chces, za 20e najdes aj na SK/CZ/EU skladom a mas do 2,3 dna. skladovost je treba si radsej overit, alebo platit len na dobierku.
ikea tradfri gateway mas v ikea skladom. kym nepride usb stick mozes sa hrat s nou, ak mas kartu mozes do 365 dni vratit :)
mgx
Reputace: 109
ZIgbee router je dobry SONOFF 3.0 Plus. ale stoji 30e na SK/CZ, ale ma aj ext.antenu. rozchodenie je zalezitostou chvilky, treba flashnut fw.
Dalsi diel workshopu
Home Assistant Supervised 2022 #5.1 - Vzdialeny pristup, DuckDNS s NAT a HTTPS s LetsEncrypt
https://youtu.be/raTIBrp2V8Y
Reputace: 701
Koukám, že od dubna 2022 je v rpi automatický uživatel pi (z bezpečnostních důvodů) zrušen https://www.tomshardware.com/news/raspb ... me-removed. Takže první připojení muselo být lokálně a vytvořit si uživatele. Pak se jako tento uživatel dá přes ssh připojit.
mgx
Reputace: 109
Pridany diel
Home Assistant Supervised 2022 #5.2 - Vzdialeny pristup cez VPN
https://youtu.be/mxZNZRVZi9Y
lzahradil
Site Admin
Reputace: 310
Lokalita: blízko Plzně
Výkon panelů [Wp]: 5840
Nový příspěvek od lzahradil »
nešlo by tomu povolit vyšší rozlišení než těch 360p? U předchozích dílů je 1080p a to už koukatelné je. Toto jsem zavřel hned na začátku protože nejsem schopen rozeznat ani 1.1.1.1.
EDIT: už je to OK a v HD.
mgx
Reputace: 109
nahrava sa to, musis chvilku vydrzat :)
mgx
Reputace: 109
Dalsi diel
Home Assistant Supervised 2022 #5.3 - Cloudflare
https://www.youtube.com/watch?v=8csM81k ... e=youtu.be
skybor
Reputace: 146
Lokalita: Lašská brána Beskyd
Výkon panelů [Wp]: 6kWp
Kapacita baterie [kWh]: 18kWh
Nový příspěvek od skybor »
Klobouk dolů a palec nahoru za tuhle záslužnou činnost. Když jsem poprve spustil HA, tak jsem si připadal jako by mne někdo vysadil v džungli s indiány. Tahle videa mi dost otevřela oči ...
SkyFVE 6 kWp (ve výstavbě) na výzkumné "chytré" chatě. 4x MPPT Epever XTRA4415N 4x40A, 1x AC Charger WATE 42V/10A, Li-Ion 3x 12s 156Ah (18 kWh/44V), SkyPowerBox LF 4810 1kVA, Victron Atlas 48/1600, REVO VM II 5.5kW, APC SmartUPS 5kVA + PLC Siemens Logo! + Dell Optiplex 3040 Micro (Proxmox: HA, Node-RED, InfluxDB, Grafana, Mqtt, Zigbee2Mqtt, Samba, Tailscale)
ElektroEzs
Reputace: 51
Lokalita: okolí Teplic
Výkon panelů [Wp]: 5460
Kapacita baterie [kWh]: 14,4
Reputace: 385
Výkon panelů [Wp]: 8820
Nový příspěvek od TomHC »
2x MUST PH1800 5.5kW, 9kWp V+J+Z, 600 Ah LiFePO4 s BMS JBD 200A, SW: Home Assistant na Synology DS923+ ku tomu ESPHome, Tasmota, MariaDB, InfluxDB, Telegraf, Grafana, Zigbee2MQTT..., HW: ESPlan (ESP32 + LAN 8720 + RS485). Nejaké moje projekty: MUST-ESPhome, ELTEK Flatpack2 ESPhome, ESP32-EMON, PZEM-017@WiFi, diyBMS-CurrentShunt-ESPhome 01/2023 -> 04/2025 = 10 MWh AC
mgx
Reputace: 109
tato sranda ta vo verzii M900 (Lenovo) na i3 proce vyjde na bazosi.sk 79euro. Za mna osobne je lepsie si kupit i7 verziu s hyperthreadingom a mat plnokrvny proxmox virtualizacny stroj. Dakedy v zime nahram video o mojom setup-e.
  • Podobná témata
    Odpovědi
    Zobrazení
    Poslední příspěvek
Uživatelé prohlížející si toto fórum: c25land, Claudebot [Bot] a 0 hostů
