Homeassistatnt - měření Easun
Diskuze, rady a návody ohledně HomeAssistant
nějak jsem se zamotal do tvorby senzorů pro měření energie na mém EASUN 8kW
našla by se dobrá duše co by mi pomohla rozklíčovat co mám špatně napsané?
celková spotřeba mi funguje, u energie do a z baterie to tam nejsem schopen dostat
jednotlivé senzory se mi zobrazují, ale do Energy panelu je nedostanu - vždy nějaká chyba
sensor:
- platform: integration
source: sensor.pipsolar_ac_output_active_power_2
method: left
unit_prefix: k
source: sensor.battery_charge_power_actual
method: left
unit_prefix: k
source: sensor.battery_discharge_power_actual
method: left
unit_prefix: k
template:
- sensor:
############Součet obou PV vstupu#######################
- name: "PV input total"
state: >-
{{ states('sensor.pipsolar_pv1_charging_power') | int + states('sensor.pipsolar_pv2_charging_power') | int }}
unit_of_measurement: "W"
device_class: energy
#############Nabíjecí výkon okamžitý####################
- name: "Battery charge power actual"
state: >-
{{ (states('sensor.pipsolar_battery_charging_current') | float * states('sensor.pipsolar_battery_voltage') | float) | round(2)}}
#device_class: energy
#state_class: total_increasing
#############Vybíjecí výkon okamžitý###################
- name: "Battery discharge power actual"
state: >-
{{ (states('sensor.pipsolar_battery_discharge_current') | float * states('sensor.pipsolar_battery_voltage') | float) | round(2)}}
- name: "Battery charge power total"
state: >-
{{ (states('sensor.pipsolar_battery_charging_current') | float * states('sensor.pipsolar_battery_voltage') | float) / 1000 | round (1) }}
unit_of_measurement: "kWh"
- name: "Battery discharge power total"
state: >-
{{ (states('sensor.pipsolar_battery_discharge_current') | float * states('sensor.pipsolar_battery_voltage') | float) / 1000 | round(1)}}
utility_meter:
pipsolar_ac_output_active_power_2_consumption_hourly:
cycle: hourly
battery_charge_power_total_consumption_hourly:
cycle: hourly
battery_discharge_power_total_consumption_hourly:
cycle: hourly
sensor:
method: left
unit_prefix: k
method: left
unit_prefix: k
method: left
unit_prefix: k
template:
- sensor:
state: >-
state: >-
state: >-
state: >-
state: >-
utility_meter:
cycle: hourly
cycle: hourly
cycle: hourly
měnič Easun 8kW, Baterie Lifepo 16S280A 15kW x 2 = 30kW, 7200kWp Amerisolar 450 8S2P J/Z + 3900kWp Leapton650 V,
Jinak jsem Robert - nick používám už dlouho a jsem na něj zvyklý
- Výkon panelů [Wp]: 7100
Re: Homeassistatnt - měření Easun
Já vidím hlavní problém v tom, že tak jak se jmenují senzory přiřazený k baterce, tak takhle přesně se nejmenuje žádný senzor ani v Dashboardu ani v configu. Nevím jestli jsi třeba nepřidal ty senzory do baterky a potom nedělal změnu v názvu v configu? Jo a restartoval jsi HA po tom nastavení v configu nebo dal znovu načíst konfiguraci?
Já bych když tak odebrat senzory z baterky, restartoval HA a potom znovu přidal ty senzory.
no to vidím docela taky, jenže když chci integrovat senzor v panelu energie tak mi nic jiného nenabízí
hodně jsem to překonbinoval to asi jo
jinak vždy udělám kontrolu konfigurace, ruční načtení a restart HA
ty jsi Petře někde psal, že to máš hotovo
nemohl bych se v tvém yaml inspirovat??
tak jsem si ještě jednou (asi po 1000 ) přečetl manuál k senzorům
upravil a světe div se najednou je tam změna
stejně ještě musím dodělat nový total energy protože doteď jsem používal jen senzor výstupní spotřeby
to si tak člověk sám dobře pokecá
sensor:
method: left
unit_prefix: k
method: left
unit_prefix: k
method: left
unit_prefix: k
template:
- sensor:
state: >-
state: >-
device_class: power
state_class: measurement
state: >-
device_class: power
state: >-
state: >-
utility_meter:
cycle: hourly
cycle: hourly
cycle: hourly
sensor:
method: left
unit_prefix: k
method: left
unit_prefix: k
method: left
unit_prefix: k
template:
- sensor:
state: >-
state: >-
device_class: power
state: >-
device_class: power
state: >-
state: >-
utility_meter:
cycle: hourly
cycle: hourly
cycle: hourly
No já abych to nemusel řešit v hlavním configu, tak jsem si všechny tyhle denní počítadla (co máš v configu) udělal rovnou v ESPhome, takže mi to hlásí do HA rovnou to, co potřebuje a tomuhle jsem se vyhnul
Ale jak ty počítadla udělat v ESPhome jsem ti posílal přeci v PM, když jsme něco řešili. Takže jsem si dodělal ESPhome, tím se mi objevily ty počítadla i v HA a potom jsem je už jenom přidal do panelu energie.
Já mám v configu vlastně jenom systémový nastavení (připojení do databáze MariaDB, InfluxDB, nastavení recorderu a podobně) a ještě teda nastavení časů zapínání a vypínání pro zásuvky, které se přenáší do ESPhome (to jsem dělal v začátcích). Jinak tyhle věci jako součet stringů FV nebo měření fakt řeším přímo v ESPhome.
- Lokalita: Galanta
- Výkon panelů [Wp]: 4440
ake senzory presne pouzivate na HA-Easun? Je niekde nejaky navod/popis?
6x Longi 370 JV+ 6x Longi 370 JZ 4440 Wp | Must PV1800 Pro 5,2 kW | 16x LiFePo4 280Ah
Měnič je připojený sériovým kabelem přes převodník RS232/TTL k ESP nebo ESP32 ve kterém je nahraný program v ESPhome a tem načítá data z měniče a posílá je do HA.
Aha tak to jsem z toho nepochopil, že to děláš přímo v ESPPetrDubi píše:No já abych to nemusel řešit v hlavním configu, tak jsem si všechny tyhle denní počítadla (co máš v configu) udělal rovnou v ESPhome, takže mi to hlásí do HA rovnou to, co potřebuje a tomuhle jsem se vyhnul
i tak moc díky
zkus hledat ESP pipsolarkkristian píše:ake senzory presne pouzivate na HA-Easun? Je niekde nejaky navod/popis?
tam bys běl vše potřebné najít, na doplnění detailů později přijď a budeme kutit spolu
případně když se někdo přidá
akorát to teď zase musím předělat aby mi seděly data a netvářilo se to jako prodej
Mě dělala baterka problém, že mi jí to přičítalo k tomu, co vylezlo z měniče, tak jsem jí odebral z baterie a dal jenom do sledování dalších spotřeb v panelu energie.
Ona ta baterka holt bude asi myšlena jako třeba Tesla wallbox nebo AC coupling baterie a to by potom sedělo.
tak teď mi ty data konečně dávají ucelený přehled
sice jsem přišel o krásnou dosavadní statistiku, ale co už mám ji zaznačenou
A teď jak jsem k tomu dospěl
instalace HA (mám na klasickém PC jako nádstavbu nad linuxem)
instalace doplňku ESPHOME -> mnoho návodů na netu
pořídil jsem ESP32 Light a k tomu TTL převodník RS232 - zapojil dle dohledatelné dokumentace (UTP z měniče)
https://github.com/syssi/esphome-pipsolar/tree/pip8048 z odkazu použil vzorovou konfiguraci pro ESP32 ->vložil svoje údaje jako: WIFI, IP Serveru, změna portu pro RS232 na port 18 a 19, ořezání o údaje co mně nezajímají
tvorba vlastních měřáku - viz příspěvek víše
pro celkový pohled je třeba si uvědomit že je potřba brát v potaz né spotřebu za měničem ale to co vyrobí panely
prozatím asi všechno, pokud se někdo někde zaseknete dejte vědět a snad budu schopen pomoci
obdivuji všechny kteří se v tom vyznání.
Rád bych se s tím také seznámil. Zatím předělávat na 48V a 5kVA
Panely 4x 280W , 4x330W Isolar 5kVA,48V 230 Ah
- Lokalita: Galanta
Mohol by si prosim nazdielat kod z esp pre inspiraciu?PetrDubi píše:Měnič je připojený sériovým kabelem přes převodník RS232/TTL k ESP nebo ESP32 ve kterém je nahraný program v ESPhome a tem načítá data z měniče a posílá je do HA.
Kód: Vybrat vše
esphome:
platform: ESP8266
board: d1_mini
external_components:
- source: github://syssi/esphome-pipsolar@pip8048
refresh: 0s
time:
- platform: homeassistant
# Enable logging
logger:
baud_rate: 0
# Enable Home Assistant API
api:
ota:
password: "OTA_heslo"
wifi:
ssid: !secret wifi_ssid
manual_ip:
static_ip: IP_ESP
gateway: IP_GATEWAY
subnet: 255.255.255.0
dns1: IP_DNS1
dns2: IP_DNS2
ap:
ssid: "Fv-Menic Fallback Hotspot"
web_server:
port: 80
uart:
- id: uart_bus
tx_pin: GPIO1
rx_pin: GPIO3
# most devices use 2400 as baud_rate
baud_rate: 2400
pipsolar:
- uart_id: uart_bus
sensor:
- platform: pipsolar
pipsolar_id: easun8k
ac_output_apparent_power:
name: "Měnič-výkon zdánlivý"
accuracy_decimals: 0
ac_output_active_power:
name: "Měnič-výkon skutečný"
output_load_percent :
name: "Měnič-výstup zatížení"
battery_voltage:
battery_charging_current:
name: "Měnič-baterie nabíjení"
battery_discharge_current:
name: "Měnič-baterie vybíjení"
pv1_input_voltage:
name: "Měnič-panely JV napětí"
pv1_input_current:
name: "Měnič-panely JV proud"
pv1_charging_power:
name: "Měnič-panely JV výkon"
pv2_input_voltage:
name: "Měnič-panely JZ napětí"
pv2_input_current:
name: "Měnič-panely JZ proud"
pv2_charging_power:
name: "Měnič-panely JZ výkon"
inverter_heat_sink_temperature:
- platform: total_daily_energy
power_id: easun8k_ac_output_active_power
min_save_interval: 5s
device_class: "energy"
state_class: "total_increasing"
filters:
- multiply: 0.001
- platform: template
name: "Měnič-panely celkový výkon"
icon: mdi:flash
name: "Měnič-panely vyrobená energie"
power_id: easun8k_pv_charging_power_complete
icon: mdi:lightning-bolt
filters:
- multiply: 0.001
binary_sensor:
internal: true
lambda: |-
if (id(easun8k_pv_charging_power_complete_start).state == true) {
id(easun8k_pv_charging_power_complete).publish_state(id(easun8k_pv1_charging_power).state + id(easun8k_pv2_charging_power).state);
id(easun8k_pv_charging_power_complete_start).turn_off();
return true;
} else {
return true;
switch:
internal: true
optimistic: true
text_sensor:
device_mode:
select:
output_source_priority:
name: "Měnič-výběr priorit výstupu"
optionsmap:
"Utility first": "POP00"
"Solar only": "POP01"
"Solar Battery Utility": "POP02"
statusmap:
"0": "Utility first"
"1": "Solar only"
"2": "Solar Battery Utility"
interval:
- interval: 5sec
then:
- switch.turn_on: easun8k_pv_charging_power_complete_start
Kód: Vybrat vše
- source: github://syssi/esphome-pipsolar@main
refresh: 0s
- Lokalita: Galanta
Dakujem,
Sml ii 3.5kw uz monitorujem,akurat som sa nedopatral ku custom senzorom.
Bacha HA neudržuje historii dat dlouhodobě, jedině "Energy dashboard" to drží ve své režii.10055 píše:tak teď mi ty data konečně dávají ucelený přehled
Ostatní je jen tuším týden, posouval jsem si to na 30 dnů
recorder:
purge_keep_days: 30
- Lokalita: Znojmo
- Kapacita baterie [kWh]: 3.43 kW
Muzu poprosit o presne namalovane to zapojeni? Nejak jsem to nepochopil..
Mam wemos d1 a na menici easun 3kW mam rj45 jako serial
Nyni jsem to zkousel pres toto https://github.com/daromer2/InverterOfThings
Ale vycetlo to jen ze tam jde 230V ale to bude tim, ze je to na jiny menic
Tak zapojeno to mam urcite dobre co jsem se dival, jen se chci zeptat. Jak to dostanu do HA, kdyz to mam na jine siti, tzn potrebuji v HA nekde nasmerovat na IP adresu toho zarizeni.
- Lokalita: Znojmo
Tak uz me to funguje, ale nevycita to teda to co bych nejak potreboval
https://pastebin.com/PKj2gSaa
Když zadam :
tak mi to při kompilaci hodí chybu
tak jsem řádek s external_component odebral a to vzalo taky, ale pise mi to ze mam treba teplotu regulatoru 391°
Tak dalsi pokrok, vycetl jsem nastaveni komplet menice, ale ani zaboha nemuzu vycist aktualni info o aktualni spotrebe atd
-- Tak další, už asi mám, ukazuje mi to asi spotřebu správně, ale hrozně tam skáčou hodnoty... 90W(správně) a pak to padne na 0W.. to chvilku drží a po chvilce zase 90W
Když zadam :
Kód: Vybrat vše
Kód: Vybrat vše
INFO ESPHome 2023.6.4
INFO Reading configuration /config/esphome/fv-menic.yaml...
INFO Updating https://github.com/syssi/esphome-pipsolar.git@main
Failed config
external_components: [source /config/esphome/fv-menic.yaml:18]
Could not find components folder for source. Please check the source contains a 'components' or 'esphome/components' folder.
refresh: 0s
- 0 Odpovědi
- 499 Zobrazení
Poslední příspěvek od solarxxxxxxxxxxxxxxx
- 72 Odpovědi
- 4980 Zobrazení
Poslední příspěvek od cipis
- 2 Odpovědi
- 302 Zobrazení
Poslední příspěvek od mirekcafa
- 7 Odpovědi
- 980 Zobrazení
Poslední příspěvek od bokser01
- 4 Odpovědi
- 328 Zobrazení
Poslední příspěvek od mobilik
