Homeassistatnt - měření Easun
10055
Reputace: 8
Nový příspěvek od 10055 »
nějak jsem se zamotal do tvorby senzorů pro měření energie na mém EASUN 8kW
našla by se dobrá duše co by mi pomohla rozklíčovat co mám špatně napsané?
celková spotřeba mi funguje, u energie do a z baterie to tam nejsem schopen dostat
jednotlivé senzory se mi zobrazují, ale do Energy panelu je nedostanu - vždy nějaká chyba
sensor:
- platform: integration
source: sensor.pipsolar_ac_output_active_power_2
method: left
unit_prefix: k
source: sensor.battery_charge_power_actual
method: left
unit_prefix: k
source: sensor.battery_discharge_power_actual
method: left
unit_prefix: k
template:
- sensor:
############Součet obou PV vstupu#######################
- name: "PV input total"
state: >-
{{ states('sensor.pipsolar_pv1_charging_power') | int + states('sensor.pipsolar_pv2_charging_power') | int }}
unit_of_measurement: "W"
device_class: energy
#############Nabíjecí výkon okamžitý####################
- name: "Battery charge power actual"
state: >-
{{ (states('sensor.pipsolar_battery_charging_current') | float * states('sensor.pipsolar_battery_voltage') | float) | round(2)}}
#device_class: energy
#state_class: total_increasing
#############Vybíjecí výkon okamžitý###################
- name: "Battery discharge power actual"
state: >-
{{ (states('sensor.pipsolar_battery_discharge_current') | float * states('sensor.pipsolar_battery_voltage') | float) | round(2)}}
- name: "Battery charge power total"
state: >-
{{ (states('sensor.pipsolar_battery_charging_current') | float * states('sensor.pipsolar_battery_voltage') | float) / 1000 | round (1) }}
unit_of_measurement: "kWh"
- name: "Battery discharge power total"
state: >-
{{ (states('sensor.pipsolar_battery_discharge_current') | float * states('sensor.pipsolar_battery_voltage') | float) / 1000 | round(1)}}
utility_meter:
pipsolar_ac_output_active_power_2_consumption_hourly:
cycle: hourly
battery_charge_power_total_consumption_hourly:
cycle: hourly
battery_discharge_power_total_consumption_hourly:
cycle: hourly
měnič Easun 8kW, Baterie Lifepo 16S280A 15kW x 2 = 30kW, 7200kWp Amerisolar 450 8S2P J/Z + 3900kWp Leapton650 V,
Jinak jsem Robert - nick používám už dlouho a jsem na něj zvyklý
PetrDubi
Reputace: 314
Výkon panelů [Wp]: 10790
Kapacita baterie [kWh]: 13
Re: Homeassistatnt - měření Easun
Nový příspěvek od PetrDubi »
Já vidím hlavní problém v tom, že tak jak se jmenují senzory přiřazený k baterce, tak takhle přesně se nejmenuje žádný senzor ani v Dashboardu ani v configu. Nevím jestli jsi třeba nepřidal ty senzory do baterky a potom nedělal změnu v názvu v configu? Jo a restartoval jsi HA po tom nastavení v configu nebo dal znovu načíst konfiguraci?
Já bych když tak odebrat senzory z baterky, restartoval HA a potom znovu přidal ty senzory.
10055
Reputace: 8
no to vidím docela taky, jenže když chci integrovat senzor v panelu energie tak mi nic jiného nenabízí
hodně jsem to překonbinoval to asi jo
jinak vždy udělám kontrolu konfigurace, ruční načtení a restart HA
ty jsi Petře někde psal, že to máš hotovo
nemohl bych se v tvém yaml inspirovat??
10055
Reputace: 8
tak jsem si ještě jednou (asi po 1000 :wall: :wall: ) přečetl manuál k senzorům
upravil a světe div se :eek2: najednou je tam změna
stejně ještě musím dodělat nový total energy protože doteď jsem používal jen senzor výstupní spotřeby
to si tak člověk sám dobře pokecá
sensor:
method: left
unit_prefix: k
method: left
unit_prefix: k
method: left
unit_prefix: k
template:
- sensor:
state: >-
state: >-
device_class: power
state_class: measurement
state: >-
device_class: power
state: >-
state: >-
utility_meter:
cycle: hourly
cycle: hourly
cycle: hourly
PetrDubi
Reputace: 314
No já abych to nemusel řešit v hlavním configu, tak jsem si všechny tyhle denní počítadla (co máš v configu) udělal rovnou v ESPhome, takže mi to hlásí do HA rovnou to, co potřebuje a tomuhle jsem se vyhnul ;)
Ale jak ty počítadla udělat v ESPhome jsem ti posílal přeci v PM, když jsme něco řešili. Takže jsem si dodělal ESPhome, tím se mi objevily ty počítadla i v HA a potom jsem je už jenom přidal do panelu energie.
Já mám v configu vlastně jenom systémový nastavení (připojení do databáze MariaDB, InfluxDB, nastavení recorderu a podobně) a ještě teda nastavení časů zapínání a vypínání pro zásuvky, které se přenáší do ESPhome (to jsem dělal v začátcích). Jinak tyhle věci jako součet stringů FV nebo měření fakt řeším přímo v ESPhome.
kkristian
Reputace: 16
Lokalita: Galanta
Výkon panelů [Wp]: 5730
Kapacita baterie [kWh]: 14,3
Nový příspěvek od kkristian »
ake senzory presne pouzivate na HA-Easun? Je niekde nejaky navod/popis?
PetrDubi
Reputace: 314
Měnič je připojený sériovým kabelem přes převodník RS232/TTL k ESP nebo ESP32 ve kterém je nahraný program v ESPhome a tem načítá data z měniče a posílá je do HA.
10055
Reputace: 8
PetrDubi píše:
Aha tak to jsem z toho nepochopil, že to děláš přímo v ESP
i tak moc díky
10055
Reputace: 8
kkristian píše:
zkus hledat ESP pipsolar
tam bys běl vše potřebné najít, na doplnění detailů později přijď a budeme kutit spolu
případně když se někdo přidá
10055
Reputace: 8
akorát to teď zase musím předělat aby mi seděly data a netvářilo se to jako prodej
PetrDubi
Reputace: 314
Mě dělala baterka problém, že mi jí to přičítalo k tomu, co vylezlo z měniče, tak jsem jí odebral z baterie a dal jenom do sledování dalších spotřeb v panelu energie.
Ona ta baterka holt bude asi myšlena jako třeba Tesla wallbox nebo AC coupling baterie a to by potom sedělo.
10055
Reputace: 8
tak teď mi ty data konečně dávají ucelený přehled
sice jsem přišel o krásnou dosavadní statistiku, ale co už mám ji zaznačenou
10055
Reputace: 8
A teď jak jsem k tomu dospěl
instalace HA (mám na klasickém PC jako nádstavbu nad linuxem)
instalace doplňku ESPHOME -> mnoho návodů na netu
pořídil jsem ESP32 Light a k tomu TTL převodník RS232 - zapojil dle dohledatelné dokumentace (UTP z měniče)
https://github.com/syssi/esphome-pipsolar/tree/pip8048 z odkazu použil vzorovou konfiguraci pro ESP32 ->vložil svoje údaje jako: WIFI, IP Serveru, změna portu pro RS232 na port 18 a 19, ořezání o údaje co mně nezajímají
tvorba vlastních měřáku - viz příspěvek víše
pro celkový pohled je třeba si uvědomit že je potřba brát v potaz né spotřebu za měničem ale to co vyrobí panely
prozatím asi všechno, pokud se někdo někde zaseknete dejte vědět a snad budu schopen pomoci
Lubik
Reputace: 31
Nový příspěvek od Lubik »
:yes: obdivuji všechny kteří se v tom vyznání.
Rád bych se s tím také seznámil. Zatím předělávat na 48V a 5kVA
kkristian
Reputace: 16
Lokalita: Galanta
PetrDubi píše:
Mohol by si prosim nazdielat kod z esp pre inspiraciu?
PetrDubi
Reputace: 314
Kód: Vybrat vše
esphome:
  platform: ESP8266
  board: d1_mini
external_components:
  - source: github://syssi/esphome-pipsolar@pip8048
    refresh: 0s
time:
  - platform: homeassistant
# Enable logging
logger:
  baud_rate: 0
# Enable Home Assistant API
api:
ota:
  password: "OTA_heslo"
wifi:
  ssid: !secret wifi_ssid
  manual_ip:
    static_ip: IP_ESP
    gateway: IP_GATEWAY
    subnet: 255.255.255.0
    dns1: IP_DNS1
    dns2: IP_DNS2
  ap:
    ssid: "Fv-Menic Fallback Hotspot"
web_server:
  port: 80
uart:
  - id: uart_bus
    tx_pin: GPIO1
    rx_pin: GPIO3
    # most devices use 2400 as baud_rate
    baud_rate: 2400
pipsolar:
  - uart_id: uart_bus
sensor:
  - platform: pipsolar
    pipsolar_id: easun8k
    ac_output_apparent_power:
      name: "Měnič-výkon zdánlivý"
      accuracy_decimals: 0
    ac_output_active_power:
      name: "Měnič-výkon skutečný"
    output_load_percent :
      name: "Měnič-výstup zatížení"
    battery_voltage:
    battery_charging_current:
      name: "Měnič-baterie nabíjení"
    battery_discharge_current:
      name: "Měnič-baterie vybíjení"
    pv1_input_voltage:
      name: "Měnič-panely JV napětí"
    pv1_input_current:
      name: "Měnič-panely JV proud"
    pv1_charging_power:
      name: "Měnič-panely JV výkon"
    pv2_input_voltage:
      name: "Měnič-panely JZ napětí"
    pv2_input_current:
      name: "Měnič-panely JZ proud"
    pv2_charging_power:
      name: "Měnič-panely JZ výkon"
    inverter_heat_sink_temperature:
  - platform: total_daily_energy
    power_id: easun8k_ac_output_active_power
    min_save_interval: 5s
    device_class: "energy"
    state_class: "total_increasing"
    filters:
      - multiply: 0.001
  - platform: template
    name: "Měnič-panely celkový výkon"
    icon: mdi:flash
    name: "Měnič-panely vyrobená energie"
    power_id: easun8k_pv_charging_power_complete
    icon: mdi:lightning-bolt
    filters:
      - multiply: 0.001
binary_sensor:
    internal: true
    lambda: |-
      if (id(easun8k_pv_charging_power_complete_start).state == true) {
        id(easun8k_pv_charging_power_complete).publish_state(id(easun8k_pv1_charging_power).state + id(easun8k_pv2_charging_power).state);
        id(easun8k_pv_charging_power_complete_start).turn_off();
        return true;
      } else {
        return true;
switch:
    internal: true
    optimistic: true
text_sensor:
    device_mode:
select:
    output_source_priority:
      name: "Měnič-výběr priorit výstupu"
      optionsmap:
        "Utility first": "POP00"
        "Solar only": "POP01"
        "Solar Battery Utility": "POP02"
      statusmap:
        "0": "Utility first"
        "1": "Solar only"
        "2": "Solar Battery Utility"
interval:
  - interval: 5sec
    then:
      - switch.turn_on: easun8k_pv_charging_power_complete_start
Akorát pozor na to, že na začátku je v sekci external_components odkaz na kód pro MAXe a na normálním měniči nebudou některý věci fungovat (například informace ze vstupů PV1 a PV2). Pro normální měnič (5 kW) by tam mělo být:
Kód: Vybrat vše
  - source: github://syssi/esphome-pipsolar@main
    refresh: 0s
A nemám tam samozřejmě všechny hodnoty které je možné monitorovat, mám tam jenom to, co mě zajímá.
kkristian
Reputace: 16
Lokalita: Galanta
Dakujem,
Sml ii 3.5kw uz monitorujem,akurat som sa nedopatral ku custom senzorom.
bahora
Reputace: 7
Lokalita: Ostrava
Nový příspěvek od bahora »
10055 píše:
Bacha HA neudržuje historii dat dlouhodobě, jedině "Energy dashboard" to drží ve své režii.
Ostatní je jen tuším týden, posouval jsem si to na 30 dnů
recorder:
purge_keep_days: 30
Kony.cz
Reputace: 1
Lokalita: Znojmo
Kapacita baterie [kWh]: 3.43 kW
Nový příspěvek od Kony.cz »
Muzu poprosit o presne namalovane to zapojeni? Nejak jsem to nepochopil..
Mam wemos d1 a na menici easun 3kW mam rj45 jako serial
Nyni jsem to zkousel pres toto https://github.com/daromer2/InverterOfThings
Ale vycetlo to jen ze tam jde 230V :) ale to bude tim, ze je to na jiny menic
Tak zapojeno to mam urcite dobre co jsem se dival, jen se chci zeptat. Jak to dostanu do HA, kdyz to mam na jine siti, tzn potrebuji v HA nekde nasmerovat na IP adresu toho zarizeni.
Kony.cz
Reputace: 1
Lokalita: Znojmo
Tak uz me to funguje, ale nevycita to teda to co bych nejak potreboval :D
https://pastebin.com/PKj2gSaa
Když zadam :
Kód: Vybrat vše
tak mi to při kompilaci hodí chybu
Kód: Vybrat vše
INFO ESPHome 2023.6.4
INFO Reading configuration /config/esphome/fv-menic.yaml...
INFO Updating https://github.com/syssi/esphome-pipsolar.git@main
Failed config
external_components: [source /config/esphome/fv-menic.yaml:18]
    Could not find components folder for source. Please check the source contains a 'components' or 'esphome/components' folder.
    refresh: 0s
tak jsem řádek s external_component odebral a to vzalo taky, ale pise mi to ze mam treba teplotu regulatoru 391° :D
Tak dalsi pokrok, vycetl jsem nastaveni komplet menice, ale ani zaboha nemuzu vycist aktualni info o aktualni spotrebe atd
-- Tak další, už asi mám, ukazuje mi to asi spotřebu správně, ale hrozně tam skáčou hodnoty... 90W(správně) a pak to padne na 0W.. to chvilku drží a po chvilce zase 90W
