HomeAssistant - Workshop 1 - 16.1.2022 8.30
Diskuze, rady a návody ohledně HomeAssistant
Informacie o planovanom zoom workshope ohladom instalacie HOME ASSISTANT
Termin: 16.1.2022 8.30-10.00
Zoom mam profesionalnu verziu, takze je to bez limitu (pocet ludi + cas). Na sledovanie Vam staci webovy prehliadac.
Zaznam potom hodim na youtube a moj web.
Prihlasenim na zoom session suhlasite s tym, ze sa to bude nahravat a pouzije sa to/zverejni na YT. Nie je v mojich silach vystrihovat a editovat .
Podrobny postup a pokec hodim tiez na YT+do fora. Vyhoda pripojit sa je, ze sa mozete spytat otazky, pripadne vyriesime rovno problemy s instalaciou (ak nastanu).
Predbezny termin: 16.1 (nedela) 8.30-10.00 cez zoom
otestovat si mozete pripojenie a zoom cez: https://zoom.us/test treba kliknut na tlacitko Join, Launch a Meeting a
Zoom
Zoom Conference Details:
Invitation from: Mgx
Topic: HOME ASSISTANT workshop 1
Time: Jan 16, 2022 08:30 AM Warsaw
Single click URL to join Zoom: https://oracle.zoom.us/j/94782187985?pw ... E2ME1WUT09
Meeting ID: 947 8218 7985
Password: 76438956
One tap mobile
+13126266799,,94782187985# US (Chicago)
+13462487799,,94782187985# US (Houston)
Dial by your location
+1 312 626 6799 US (Chicago)
+1 346 248 7799 US (Houston)
+1 646 558 8656 US (New York)
+1 669 900 6833 US (San Jose)
+1 720 928 9299 US (Denver)
+1 206 337 9723 US (Seattle)
+1 213 338 8477 US (Los Angeles)
+1 253 215 8782 US (Tacoma)
+1 301 715 8592 US (Washington DC)
Password: 76438956
Find your local number: https://oracle.zoom.us/u/adPjroD4bA
Join by SIP
94782187985@zoomcrc.com
Join by H.323
162.255.37.11 (US West)
162.255.36.11 (US East)
115.114.131.7 (India Mumbai)
115.114.115.7 (India Hyderabad)
213.19.144.110 (Amsterdam Netherlands)
213.244.140.110 (Germany)
103.122.166.55 (Australia Sydney)
103.122.167.55 (Australia Melbourne)
209.9.211.110 (Hong Kong SAR)
149.137.40.110 (Singapore)
64.211.144.160 (Brazil)
149.137.68.253 (Mexico)
69.174.57.160 (Canada Toronto)
65.39.152.160 (Canada Vancouver)
207.226.132.110 (Japan Tokyo)
149.137.24.110 (Japan Osaka)
Password: 76438956
Priprava: Ak si chcete nachystat vlastny HW s OS, je to VELMI doporucene. V podstate budete potrebovat len 2 veci:
0) HW a SD kartu. doporucujem 32GB a vacsiu.
1) funkcny operacny system debian bullseye (32bit alebo 64bit) na Vasom HW
ak mate malinu (ja mam RPI4B) (raspberry pi 2,3,4) tak napr.
maly image
https://downloads.raspberrypi.org/raspi ... 4-lite.zip
velky image pre malinu: 2021-10-30-raspios-bullseye-arm64.zip
https://downloads.raspberrypi.org/raspi ... 021-11-08/
toto si stiahnite a cez program etcher (stiahnut tu: https://www.balena.io/etcher/ ) rozbalite na sd kartu a nainstalujete si na raspberry cisty debian bullseye (raspios) alebo plnu instalaciu s
Xwindows, je to na Vas. Inspiracne video: https://www.youtube.com/watch?v=PijX8GD ... aspberryPi. Cielovy OS treba mat nainstalovany a funkcny.
Tu je oficialna stranka pre BULLSEYE na Raspberry Pi:
https://www.raspberrypi.com/software/op ... -os-32-bit
Pozor,image su 32 bitove. Je lepsie pouzit linky hore, ale nevadi to.
Ak mate iny HW, napr. toto
https://www.debian.org/releases/bullseye/
2) funkcny internet (tzn. na vasom raspberry, HW ) sa musi dat pingnut 8.8.8.8 alebo spustit apt-get update
Budeme instalovat HomeAssistant SUpervized, problem je ze aktualne su podporovane len tieto platformy:
generic-x86-64
odroid-c2
odroid-n2
odroid-xu
qemuarm
qemuarm-64
qemux86
qemux86-64
raspberrypi
raspberrypi2
raspberrypi3
raspberrypi4
raspberrypi3-64
raspberrypi4-64
tinker
khadas-vim3
Ak tam svoju nevidite, napiste mi. Asi budete musiet pouzit HASSOS .
Zoom
Password: 76438956
One tap mobile
Password: 76438956
Join by SIP
Join by H.323
Password: 76438956
maly image
generic-x86-64
odroid-c2
odroid-n2
odroid-xu
qemuarm
qemuarm-64
qemux86
qemux86-64
raspberrypi
raspberrypi2
raspberrypi3
raspberrypi4
raspberrypi3-64
raspberrypi4-64
tinker
khadas-vim3
Re: HomeAssistant - Workshop 1 - 16.1.2022 8.30
Ahoj, ještě jednou díky za dnešní online. Těším se na příště
Navržená témata:
1. Vyčítání dat ze střídače
2. Ukládání do db
3. Vizualizace
Třeba někdo pomůže s realizací.
Za sebe: Já vyčítám data z GoodWe ET řady, instaloval jsem tuhle integraci (inspiroval jsem se tady - velký dík autorovi, pokud to tu čte) a je to plug-and-play, kdyby byl zájem, můžu dát postup. Po napojení je možné zprovoznit Energy panel a hned jsou k dispozici hezké základní statistiky.
Navržená témata:
2. Ukládání do db
3. Vizualizace
Pridal som diel 2
Home Assistant Supervised 2022 #2 - SSH a HACS
Inštalácia SSH (terminal) a HACS (Home assistant comunity store)
https://youtu.be/paRPfuHf5wY
Pridal som diel 3
Home Assistant Supervised 2022 #3 - Zariadenia, Entity, Automatizácie, Pridanie zariadenia
https://www.youtube.com/watch?v=0CFYxmm5tWs
- Lokalita: Juh BBSK
- Výkon panelů [Wp]: 1700
Super videá, ďakujem za ne. Už mám vo Virtualboxe Debian 11 a v ňom v dockeri HA a moduly, čakám na regulátor nabíjania aj raspberry.
3s2p Amerisolar 285 1,7 kWp JJV, Epever 5420AN, 14s100p LiIon 18650 12 kWh + JK BMS 200A, Epever iPower 5 kW
To jsou super videa mgx, díky za ně!
Rád bych si postavil vlastní CC2530 router pro Zigbee podle návodu: https://www.zigbee2mqtt.io/advanced/zig ... outer.html
Chtěl bych se poradit, kde členové fóra nakupují komponenty atp. V českých eshopech jsem nic moc nenašel a odkazy v tom seznamu komponent na zigbee2mqtt.io už většinou nefungují nebo vedou na Aliexpressu na jiné/podobné produkty.
Díval jsem se na ebay.de a amazon.de kde nějaké komponenty sehnat jdou (Zigbee modul s anténou a emulátor CC debugger), ale přijde mi, že se něco takového přece musí dát sehnat i u nás. Nebo všichni místní bastliči nakupují mimo ČR a SR, protože to prostě jinak sehnat nejde?
Díky
Tomek
Díky
Tomek
Něco je i na www.Banggood.com a čidlo teploty a vlhkosti z českého skladu bylo na svk za tři dny. Rychle to je i z Polska.
tieto veci nema ziadny vyznam kupovat na SK/CZ. Aliexpress ti USB dongle za 5euro aj s postovnym pride cca za mesiac.
https://www.aliexpress.com/item/4000822 ... e870d480b7
samozrejme, ak chces, za 20e najdes aj na SK/CZ/EU skladom a mas do 2,3 dna. skladovost je treba si radsej overit, alebo platit len na dobierku.
ikea tradfri gateway mas v ikea skladom. kym nepride usb stick mozes sa hrat s nou, ak mas kartu mozes do 365 dni vratit
ZIgbee router je dobry SONOFF 3.0 Plus. ale stoji 30e na SK/CZ, ale ma aj ext.antenu. rozchodenie je zalezitostou chvilky, treba flashnut fw.
Dalsi diel workshopu
Home Assistant Supervised 2022 #5.1 - Vzdialeny pristup, DuckDNS s NAT a HTTPS s LetsEncrypt
https://youtu.be/raTIBrp2V8Y
Koukám, že od dubna 2022 je v rpi automatický uživatel pi (z bezpečnostních důvodů) zrušen https://www.tomshardware.com/news/raspb ... me-removed. Takže první připojení muselo být lokálně a vytvořit si uživatele. Pak se jako tento uživatel dá přes ssh připojit.
43 kWp, LiFePO4 46 kWh,
Pridany diel
Home Assistant Supervised 2022 #5.2 - Vzdialeny pristup cez VPN
https://youtu.be/mxZNZRVZi9Y
- Site Admin
- Lokalita: blízko Plzně
- Výkon panelů [Wp]: 5840
nešlo by tomu povolit vyšší rozlišení než těch 360p? U předchozích dílů je 1080p a to už koukatelné je. Toto jsem zavřel hned na začátku protože nejsem schopen rozeznat ani 1.1.1.1.
EDIT: už je to OK a v HD.
nahrava sa to, musis chvilku vydrzat
Dalsi diel
Home Assistant Supervised 2022 #5.3 - Cloudflare
https://www.youtube.com/watch?v=8csM81k ... e=youtu.be
- Výkon panelů [Wp]: 4000
Klobouk dolů a palec nahoru za tuhle záslužnou činnost. Když jsem poprve spustil HA, tak jsem si připadal jako by mne někdo vysadil v džungli s indiány. Tahle videa mi dost otevřela oči ...
SkyFVE 4 kWp (ve výstavbě) na výzkumné "chytré" chatě. 1x MPPT EASun 8048 80A, 2x MPPT EASun 6048 60A, Li-Ion 3x 12s 156Ah (20,6 kWh/44V), APC Smart-UPS 5kVA, SkyPowerBox LF 4810 1kVA + Siemens Logo! + RPi (Node-RED, Remote-RED, InfluxDB, Grafana)
- Lokalita: okolí Teplic
- Výkon panelů [Wp]: 5460
Tak nakonec jdu do HA taky co je lepsi koupit https://www.chytrevypinace.cz/Home-Assi ... escription nebo https://rpishop.cz/280603/raspberry-pi- ... rnwfBVVvSl ? Diky
- Výkon panelů [Wp]: 5520
- Kapacita baterie [kWh]: 14
https://pc.bazos.cz/inzerat/191054694/d ... -micro.phpElektroEzs píše: ↑pon zář 30, 2024 10:43 am Tak nakonec jdu do HA taky co je lepsi koupit https://www.chytrevypinace.cz/Home-Assi ... escription nebo https://rpishop.cz/280603/raspberry-pi- ... rnwfBVVvSl ? Diky
MUST PV1800 VHM 48V 5.5kW, 5.52kWp (12x TPL mono 460W, 2S2P východ, 2S4P juh), 16x 280 Ah LiFePO4 (14.3 kWh) BMS JBD-AP21S001-L21S-200A-B, SW: Home Assistant na Synology DS923+ ku tomu ESPHome, Tasmota, MariaDB, InfluxDB, Telegraf, Grafana, Zigbee2MQTT..., HW: ESPlan (ESP32 + LAN 8720 + RS485 + UART). Nejaké moje projekty: MUST-ESPhome, ELTEK Flatpack2 ESPhome, ESP32-EMON, PZEM-017@WiFi, diyBMS-CurrentShunt-ESPhome 01/2023 -> 09/2024 = 7.9 MWh AC
tato sranda ta vo verzii M900 (Lenovo) na i3 proce vyjde na bazosi.sk 79euro. Za mna osobne je lepsie si kupit i7 verziu s hyperthreadingom a mat plnokrvny proxmox virtualizacny stroj. Dakedy v zime nahram video o mojom setup-e.
- 0 Odpovědi
- 1128 Zobrazení
Poslední příspěvek od tomas
- 13 Odpovědi
- 2123 Zobrazení
- 6 Odpovědi
- 814 Zobrazení
Poslední příspěvek od xmasin
- 29 Odpovědi
- 3995 Zobrazení
Poslední příspěvek od LubosK
ceník čez od 1.1.2022 elektřina pro soláry
od misa84 » » v Hybridní elektrárny
- 21 Odpovědi
- 8425 Zobrazení
Poslední příspěvek od PetrDubi
