Arduino + EPSolar Tracer + AJAX
Arduino kód umožňuje čtení dat z regulátoru EPSolar Tracer přes sériovou komunikaci. Data lze zobrazit pomocí AJAX na webu nebo uložit do databáze přes Raspberry Pi s PHP a MySQL. Kód využívá knihovny SoftwareSerial, Ethernet a SD pro komunikaci a správu dat.
- Lokalita:SO, SK
Ak by ste potrebovali vyčítavať dáta z nejakého Ep. Tracera, tak tu je na to kód do Arduina.
MOžete si potom napr. urobiť zobrazovanie cez AJAX, alebo to dať do databázy cez Rasp. Pi
+ PHP + MySQL. https://github.com/xxv/tracer/blob/master/README.md
https://github.com/xxv/tracer/blob/mast ... Tracer.ino
https://github.com/xxv/tracer/blob/mast ... r-MT-5.pdf
http://randomsporadicprojects.blogspot. ... -to_9.html
https://www.youtube.com/watch?v=RnJiKDCugoY Ak potrebujete HTML kód k tým budíkom, napíšte PM alebo mail, lebo tu sa to nedá pridať.
Kód: Vybrat vše
Software serial multple serial test
Receives from the two software serial ports,
sends to the hardware serial port.
In order to listen on a software port, you call port.listen().
When using two software serial ports, you have to switch ports
by listen()ing on each one in turn. Pick a logical time to switch
ports, like the end of an expected transmission, or when the
buffer is empty. This example switches ports when there is nothing
more to read from a port
The circuit:
Two devices which communicate serially are needed.
* First serial device's TX attached to digital pin 2, RX to pin 3
* Second serial device's TX attached to digital pin 4, RX to pin 5
Note:
Not all pins on the Mega and Mega 2560 support change interrupts,
so only the following can be used for RX:
10, 11, 12, 13, 50, 51, 52, 53, 62, 63, 64, 65, 66, 67, 68, 69
Not all pins on the Leonardo support change interrupts,
8, 9, 10, 11, 14 (MISO), 15 (SCK), 16 (MOSI).
created 18 Apr. 2011
modified 25 May 2012
by Tom Igoe
based on Mikal Hart's twoPortRXExample
This example code is in the public domain.
#include <SD.h>
#include <Ethernet.h>
#include <EthernetUdp.h>
#include <SoftwareSerial.h>---------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------
#include <EEPROM.h>
// software serial #1: TX = digital pin 10, RX = digital pin 11
//SoftwareSerial portOne(13, 12);
// software serial #2: TX = digital pin 8, RX = digital pin 9
// on the Mega, use other pins instead, since 8 and 9 don't work on the Mega
//SoftwareSerial portTwo(63, 62);
SoftwareSerial myserial(12, 13); // RX, TX
uint8_t start[] = { 0xAA, 0x55, 0xAA, 0x55, 0xAA, 0x55,
0xEB, 0x90, 0xEB, 0x90, 0xEB, 0x90 };
uint8_t id = 0x16;
uint8_t cmd[] = { 0xA0, 0x00, 0xB1, 0xA7, 0x7F };
uint8_t buff[128];
#define REQ_BUF_SZ 100
File webFile;
char HTTP_req [REQ_BUF_SZ] = {0};
char req_index = 0;
const int chipSelect = 4;
const float ref_a = 1.238;
const float ref_b = 1.238;
const float ref_c = 1.238;
const float ref_d = 1.231;
boolean LED_state[4] = {0}; // stores the states of the LEDs
EthernetServer server(80);
byte mac[] = {
0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xEC
IPAddress ip(192, 168, 1, 20);
boolean pass_OK = 0;
int ee_addr = 0;
const int max_bf = 70;
const int bfln = 17;
char buffer_in [max_bf] = "a98765432109876540987654321098765409876543210987654098765432109876540";
const int v_index_max = 4;
int voltage [v_index_max] = {3};
float battery;
float pv;
//13-14 reserved
float load_current;
float over_discharge;
float battery_max;
// 21 load on/off
// 22 overload yes/no
// 23 load short yes/no
// 24 reserved
// 25 battery overload
// 26 over discharge yes/no
uint8_t full;
uint8_t charging;
int8_t battery_temp;
float charge_current;
void setup() {
// Open serial communications and wait for port to open:
Serial.begin(9600);
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
pinMode(10, OUTPUT);
digitalWrite(10,HIGH);
pinMode(53, OUTPUT);
digitalWrite(53,HIGH);
myserial.begin(9600);
// see if the card is present and can be initialized:
if (!SD.begin(chipSelect)) {
Serial.println("Card failed, or not present");
// don't do anything more:
return;
Serial.println("card initialized.");
Ethernet.begin(mac, ip);
server.begin();
Serial.print("server is at ");
Serial.println(Ethernet.localIP());
// start Ethernet and UDP
if (Ethernet.begin(mac) == 0) {
Serial.println("Failed to configure Ethernet using DHCP");
// no point in carrying on, so do nothing forevermore:
//for (;;) ;
// Start each software serial port
//portOne.begin(9600);
//portTwo.begin(9600);
float to_float(uint8_t* buffer, int offset){
unsigned short full = buffer[offset+1] << 8 | buff[offset];
return full / 100.0;
void loop() {
// By default, the last intialized port is listening.
// when you want to listen on a port, explicitly select it:
portOne.listen();
Serial.println("Data from port one:");
// while there is data coming in, read it
// and send to the hardware serial port:
byte ii = 0;
while (portOne.available() > 0) {
char inByte = portOne.read();
buffer_in [ii++] = inByte;
Serial.write(inByte);
if ( StrContains(buffer_in, "FEFD") )
int i = 0;
i = StrIndex (buffer_in, "FEFD");
i = i + 3;
Serial.print(" i: ");
Serial.println(i);
Serial.write (buffer_in [i]);
Serial.write (buffer_in [i+1]);
voltage [0]= (int)( buffer_in [i]-'0' ) * 16 + (int) ( buffer_in [i+1] - '0' );
voltage [0]= voltage [0] * 4;
Serial.print("Voltage 1. is : ");
Serial.println(voltage [0]);
Serial.print ("float : ");
Serial.println (1024.0*ref_a/(float)voltage [0]);
if ( StrContains(buffer_in, "FDFC") )
int i = 0;
i = StrIndex (buffer_in, "FDFC");
i = i + 3;
Serial.println(i);
voltage [1]= (int)( buffer_in [i]-'0' ) * 16 + (int) ( buffer_in [i+1] - '0' );
voltage [1]= voltage [1] * 4;
Serial.print("Voltage 2. is : ");
Serial.println(voltage [1]);
Serial.println (1024.0*ref_b/(float)voltage [1]);
if ( StrContains(buffer_in, "FEFB") )
int i = 0;
i = StrIndex (buffer_in, "FEFB");
i = i + 3;
Serial.println(i);
voltage [2]= (int)( buffer_in [i]-'0' ) * 16 + (int) ( buffer_in [i+1] - '0' );
voltage [2]= voltage [2] * 4;
Serial.print("Voltage 3. is : ");
Serial.println(voltage [2]);
Serial.println (1024.0*ref_c/(float)voltage [2]);
if ( StrContains(buffer_in, "FDFA") )
int i = 0;
i = StrIndex (buffer_in, "FDFA");
i = i + 3;
Serial.println(i);
voltage [3]= (int)( buffer_in [i]-'0' ) * 16 + (int) ( buffer_in [i+1] - '0' );
voltage [3]= voltage [3] * 4;
Serial.println(voltage [3]);
Serial.println (1024.0*ref_d/(float)voltage [3]);
// blank line to separate data from the two ports:
Serial.println("Reading Tracer");
myserial.write(start, sizeof(start));
myserial.write(id);
myserial.write(cmd, sizeof(cmd));
int read = 0;
for (int i = 0; i < 255; i++){
if (myserial.available()) {
buff[read] = myserial.read();
read++;
Serial.print("Read "); Serial.print(read); Serial.println(" bytes");
for (int i = 0; i < read; i++){
Serial.print(buff[i], HEX);
Serial.print(" ");
Serial.println();
battery = to_float(buff, 9);
pv = to_float(buff, 11);
//13-14 reserved
load_current = to_float(buff, 15);
over_discharge = to_float(buff, 17);
battery_max = to_float(buff, 19);
// 21 load on/off // 22 overload yes/no // 23 load short yes/no // 24 reserved // 25 battery overload
full = buff[27];
charging = buff[28];
battery_temp = buff[29] - 30;
charge_current = to_float(buff, 30);
Serial.print("Load is ");
Serial.println(buff[21] ? "on" : "off");
Serial.print("Load current: ");
Serial.println(load_current);
Serial.print("Battery level: ");
Serial.print(battery);
Serial.print("/");
Serial.println(battery_max);
Serial.print("Battery full: ");
Serial.println(full ? "yes " : "no" );
Serial.print("Battery temperature: ");
Serial.println(battery_temp);
Serial.print("PV voltage: ");
Serial.println(pv);
Serial.print("Charging: ");
Serial.println(charging ? "yes" : "no" );
Serial.print("Charge current: ");
Serial.println(charge_current);
//voltage = 404.00;
EthernetClient client = server.available();
if (client) {
Serial.println("new client");
// an http request ends with a blank line
boolean currentLineIsBlank = true;
while (client.connected()) {
if (client.available()) { // client data available to read
char c = client.read();
//read char by char HTTP request
// buffer first part of HTTP request in HTTP_req array (string)
// leave last element in array as 0 to null terminate string (REQ_BUF_SZ - 1)
if (req_index < (REQ_BUF_SZ - 1)) {
HTTP_req[req_index] = c; // save HTTP request character
req_index++;
// last line of client request is blank and ends with \n
// respond to client only after last line received
Serial.write(c);
// if you've gotten to the end of the line (received a newline
// character) and the line is blank, the http request has ended,
// so you can send a reply
if (c == '\n' && currentLineIsBlank) {
// send a standard http response header
client.println("HTTP/1.1 200 OK");
client.println("Access-Control-Allow-Origin: http://rottenkiwi.no-ip.biz");
// remainder of header follows below, depending on if
// web page or XML page is requested
// Ajax request - send XML file
if (StrContains(HTTP_req, "GET")
&& StrContains(HTTP_req, "ajax_inputs")) {
// send rest of HTTP header
client.println("Content-Type: text/xml");
client.println("Connection: keep-alive");
client.println();
SetLEDs ();
// send XML file containing input states
XML_response(client);
else
if (StrContains(HTTP_req, "POST")
&& StrContains(HTTP_req, "ajax_inputs=1")) {
client.println();
SetLEDs ();
else { // web page request
client.println("Content-Type: text/html");
client.println("Connection: close");
client.println();
if (StrContains(HTTP_req, "GET / ")
|| StrContains(HTTP_req, "GET /index.htm")) {
webFile = SD.open("index.htm"); // open web page file
if (StrContains(HTTP_req, "GET /favicon.ico")
|| StrContains(HTTP_req, "GET /favicon.ico")) {
webFile = SD.open("favicon.ico"); // open web page file
else if (StrContains(HTTP_req, "GET /logtr.htm")) {
webFile = SD.open("logtr.htm"); // open web page file
else if (StrContains(HTTP_req, "GET /page0.htm")) {
webFile = SD.open("page0.htm"); // open web page file
else if (StrContains(HTTP_req, "GET /page1.htm")) {
webFile = SD.open("page1.htm"); // open web page file
else if (StrContains(HTTP_req, "GET /lifelog.txt")) {
webFile = SD.open("lifelog.txt"); // open web page file
else if (StrContains(HTTP_req, "GET /datalog.txt")) {
webFile = SD.open("datalog.txt"); // open web page file
if (webFile) {
while(webFile.available()) {
client.write(webFile.read()); // send web page to client
webFile.close();
// display received HTTP request on serial port
Serial.print(HTTP_req);
// reset buffer index and all buffer elements to 0
req_index = 0;
StrClear(HTTP_req, REQ_BUF_SZ);
break;
client.println("Connection: close"); // the connection will be closed after completion of the response
client.println("Refresh: 5"); // refresh the page automatically every 5 sec
client.println();
client.println("<!DOCTYPE HTML>");
client.println("<html>");
// output the value of each analog input pin
int analogChannel = Amp_1_pin;
client.print("<p style=""color:blue"">");
int sensorReadingA = analogRead(analogChannel);
client.print("A: ");
//client.println("<br />");
//client.print(analogChannel);
//client.print(" = ");
//client.print( ( Amp_min - A_offset ) / A_call );
//client.print(", ");
//client.print( ( Amp_max - A_offset ) / A_call );
//client.print( ( Amp_avg - A_offset ) / A_call );
client.print( ( Amp_med - A_offset ) / A_call );
client.print(", ");
client.print( ( sensorReadingA - A_offset ) / A_call );
//client.print("</p>");
analogChannel = U_1_pin;
int sensorReadingU = analogRead(analogChannel);
client.print("<p style=""color:red"">");
client.print(" V: ");
//client.print( U_min*5.0/1023*U_call );
//client.print( U_max*5.0/1023*U_call );
//client.print( U_avg*5.0/1023*U_call );
client.print( U_med*5.0/1023*U_call );
client.print(", ");
client.print( sensorReadingU*5.0/1023*U_call );
for ( analogChannel = 6; analogChannel < 8; analogChannel++) {
int sensorReading = analogRead(analogChannel);
client.print("Voltage ");
client.print(sensorReading*5.0/1023*U_call);
client.print("<p style=""color:black"">");
client.print("W: ");
//client.print( ( ( Amp_min - A_offset ) / A_call ) * ( U_min*5.0/1023*U_call ) );
//client.print( ( ( Amp_max - A_offset ) / A_call ) * ( U_max*5.0/1023*U_call ) );
//client.print( ( ( Amp_avg - A_offset ) / A_call ) * ( U_avg*5.0/1023*U_call ) );
client.print( ( ( Amp_med - A_offset ) / A_call ) * ( U_med*5.0/1023*U_call ) );
client.print(", ");
client.print( ( ( sensorReadingA - A_offset ) / A_call ) * ( sensorReadingU*5.0/1023*U_call ) );
client.print(" Wh: ");
client.print( P_day );
client.print(" DC Wh: ");
client.print( P_Dc );
client.print("<p style=""color:green"">");
client.print("C: ");
client.print(celsius);
//client.print(" Celsius, ");
client.println("<a href=\"/?r2on\"\">+L2</a>");
client.println("<a href=\"/?r2off\"\">-L2</a><br />");
client.println("<br>");
client.println("<a href=\"/?r3on\"\">+L3</a>");
client.println("<a href=\"/?r3off\"\">-L3</a><br />");
client.println("<a href=\"/?r5on\"\">+L5</a>");
client.println("<a href=\"/?r5off\"\">-L5</a><br />");
client.println("<a href=\"/?r6on\"\">+L6</a>");
client.println("<a href=\"/?r6off\"\">-L6</a><br />");
client.println("<a href=\"/?r7on\"\">+L7</a>");
client.println("<a href=\"/?r7off\"\">-L7</a><br />");
client.println("<a href=\"/?r8on\"\">+L8</a>");
client.println("<a href=\"/?r8off\"\">-L8</a><br />");
client.println("</html>");
break;
if (c == '\n') {
// you're starting a new line
else if (c != '\r') {
// you've gotten a character on the current line
currentLineIsBlank = false;
// give the web browser time to receive the data
delay(1);
// close the connection:
client.stop();
if(readString.indexOf("?r2on") > 0)//checks for on
digitalWrite(2, HIGH); // set pin 2 high
Serial.println("Led On");
client.println("L2 On");
if(readString.indexOf("?r2off") >0)//checks for off
digitalWrite(2, LOW); // set pin 2 low
Serial.println("Led Off");
client.println("L2 Off");
if(readString.indexOf("?r3on") >0)//checks for on
digitalWrite(3, HIGH); // set pin 4 high
client.println("L3 On");
if(readString.indexOf("?r3off") >0)//checks for off
digitalWrite(3, LOW); // set pin 4 low
client.println("L3 Off");
if(readString.indexOf("?r5on") >0)//checks for on
digitalWrite(5, HIGH); // set pin 6 high
client.println("L5 On");
if(readString.indexOf("?r5off") >0)//checks for off
digitalWrite(5, LOW); // set pin 6 low
client.println("L5 Off");
if(readString.indexOf("?r6on") >0)//checks for on
digitalWrite(6, HIGH); // set pin 7 high
client.println("L6 On");
if(readString.indexOf("?r6off") >0)//checks for off
digitalWrite(6, LOW); // set pin 7 low
client.println("L6 Off");
if(readString.indexOf("?r7on") >0)//checks for on
digitalWrite(7, HIGH); // set pin 8 high
client.println("L7 On");
if(readString.indexOf("?r7off") >0)//checks for off
digitalWrite(7, LOW); // set pin 8 low
client.println("L7 Off");
if(readString.indexOf("?r8on") >0)//checks for on
digitalWrite(8, HIGH); // set pin 9 high
client.println("L8 On");
if(readString.indexOf("?r8off") >0)//checks for off
digitalWrite(8, LOW); // set pin 9 low
client.println("L8 Off");
//clearing string for next read
readString="";
Serial.println("client disconnected");
// checks if received HTTP request is switching on/off LEDs
// also saves the state of the LEDs
void SetLEDs(void)
if (StrContains(HTTP_req, "12345678")) {
pass_OK = 1;
// LED 1 (pin 5)
if (StrContains(HTTP_req, "LED1=1")) {
LED_state[0] = 1; // save LED state
else if (StrContains(HTTP_req, "LED1=0")) {
LED_state[0] = 0; // save LED state
// LED 2 (pin 6)
if (StrContains(HTTP_req, "LED2=1")) {
LED_state[1] = 1; // save LED state
else if (StrContains(HTTP_req, "LED2=0")) {
LED_state[1] = 0; // save LED state
// LED 3 (pin 7)
if (StrContains(HTTP_req, "LED3=1")) {
LED_state[2] = 1; // save LED state
else if (StrContains(HTTP_req, "LED3=0")) {
LED_state[2] = 0; // save LED state
// LED 4 (pin 8)
if (StrContains(HTTP_req, "LED4=1")) {
LED_state[3] = 1; // save LED state
else if (StrContains(HTTP_req, "LED4=0")) {
LED_state[3] = 0; // save LED state
else
// searches for the string sfind in the string str
// returns 1 if string found
// returns 0 if string not found
int StrContains(char *str, char *sfind)
int found = 0;
int index = 0;
int len;
len = strlen(str);
if (strlen(sfind) > len) {
return 0;
while (index < len) {
if (str[index] == sfind[found]) {
found++;
if (strlen(sfind) == found) {
return 1;
else {
found = 0;
index++;
return 0;
int StrIndex (char *str, char *sfind)
int found = 0;
int index = 0;
int len;
len = strlen(str);
return 0;
found++;
return index;
else {
found = 0;
index++;
return 0;
// send the XML file containing analog value
void XML_response(EthernetClient cl)
int analog_val;
int count; // used by 'for' loops
int sw_arr[] = {2, 3}; // pins interfaced to switches
cl.println("<?xml version=\"1.0\"?>");
cl.println("<inputs>");
cl.print("<analog>");
cl.print( pv );
cl.println("</analog>");
cl.print( charge_current );
cl.print( load_current );
cl.print( (battery/battery_max) );
cl.print((1024.0*1.24/(float)voltage[0]));
cl.print( (1024.0*1.24/(float)voltage[0]));
cl.print( (1024.0*1.24/(float)voltage[0]) );
cl.print("<LED>");
if (LED_state[0]) {
cl.print("checked");
else {
cl.print("unchecked");
cl.println("</LED>");
// LED2
cl.print("<LED>");
if (LED_state[1]) {
else {
// button LED states
// LED3
cl.print("<LED>");
if (LED_state[2]) {
cl.print("on");
else {
cl.print("off");
// LED4
cl.print("<LED>");
if (LED_state[3]) {
cl.print("on");
else {
cl.print("off");
cl.print(last_temp);
cl.print("</analog>");
cl.println("</inputs>");
// sets every element of str to 0 (clears array)
void StrClear(char *str, char length)
for (int i = 0; i < length; i++) {
str[i] = 0;
