Arduino Termostat + Lcd Nokia 3310
Karya
Reputace: 1
Nový příspěvek od Karya »
Caute
Uz aj ja som hrdim vlastnnikom Arduina.Obraciam sa na vas.Nevedel by mi niekdo pomoct spravit podmienku?Moja predstava je ak v bojleru 1 bude teplota 60 c nezapinaj rele ak bude viac ako 60 zapny.Pripojene mam 2x DS18B20.Dakujem
Kód: Vybrat vše
#include <OneWire.h>
#include <DallasTemperature.h>
#include <PCD8544.h>
// Data wire is plugged into pin 2 on the Arduino
#define ONE_WIRE_BUS 2
// Setup a oneWire instance to communicate with any OneWire devices
OneWire oneWire(ONE_WIRE_BUS);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
// Assign the addresses of your 1-Wire temp sensors.
// See the tutorial on how to obtain these addresses:
// http://www.hacktronics.com/Tutorials/arduino-1-wire-address-finder.html
DeviceAddress insideThermometer = { 0x28, 0x6C, 0x2B, 0x24, 0x03, 0x00, 0x00, 0xB2 };
DeviceAddress outsideThermometer = { 0x28, 0x48, 0x24, 0x24, 0x03, 0x00, 0x00, 0xB7 };
// The dimensions of the LCD (in pixels)...
static const byte LCD_WIDTH = 84;
static const byte LCD_HEIGHT = 48;
static PCD8544 lcd;
const int LED = 13;
// A bitmap graphic (10x2) of a thermometer...
static const byte THERMO_WIDTH = 10;
static const byte THERMO_HEIGHT = 2;
static const byte thermometer[] = { 0x00, 0x00, 0x48, 0xfe, 0x01, 0xfe, 0x00, 0x02, 0x05, 0x02,
                                    0x00, 0x00, 0x62, 0xff, 0xfe, 0xff, 0x60, 0x00, 0x00, 0x00};
void setup(void)
  lcd.clear();
  pinMode(LED, OUTPUT);
  // Start up the library
  sensors.begin();
  // set the resolution to 10 bit (good enough?)
  sensors.setResolution(insideThermometer, 10);
  sensors.setResolution(outsideThermometer, 10);
   lcd.begin(LCD_WIDTH, LCD_HEIGHT);
void printTemperature(DeviceAddress deviceAddress)
  float tempC = sensors.getTempC(deviceAddress);
  lcd.print(tempC);
  lcd.print(" ");
  if (tempC > 22.00 )  // podmienka na zopnutie rele
   digitalWrite(LED, HIGH);
  else
  digitalWrite(LED, LOW);
void loop(void)
  delay(500);
 sensors.requestTemperatures();
 lcd.setCursor(10,1);
 lcd.print("Bojler (1): ");
 printTemperature(insideThermometer);
 lcd.setCursor(10,5);
 lcd.print("Bojler (2): ");
 printTemperature(outsideThermometer);
  // Draw the thermometer bitmap at the bottom left corner...
 lcd.setCursor(0,0);
 lcd.drawBitmap(thermometer, THERMO_WIDTH, THERMO_HEIGHT);
 lcd.setCursor(0,4);
lwq
Reputace: 14
Lokalita: Mělník
Výkon panelů [Wp]: 8550
Kapacita baterie [kWh]: 32
Re: Arduino Termostat + Lcd Nokia 3310
Nový příspěvek od lwq »
V cem je problem ? Pouzij google :comp:
... nahore pridat ...
Kód: Vybrat vše
const int LED = 13;
const int RELE = 10;
v setupu pridat ...
Kód: Vybrat vše
pinMode(RELE, OUTPUT);
A kod by mel byt ...
Kód: Vybrat vše
if ((tempC > 60.00) && (deviceAddress == "insideThermometer"))  // podmienka na zopnutie rele
digitalWrite(RELE, HIGH);
else
digitalWrite(RELE, LOW);
... s tim, ze na PINu 13 tezko neco das, je tam natvrdo LEDka (vetsinou) ... takze pouzit 13 jako indikaci sepnuti rele ... a na sepnuti rele pouzit jiny pin, napsano je to pro pin 10.
A pro uplnost tady mas navod jak pripojit 5V rele k arduinu ... Tim rele muzes ovladat treba stykac a tak ...
http://www.glacialwanderer.com/hobbyrobotics/?p=9
Rele - napriklad ...
http://sk.farnell.com/omron-electronic- ... dp/1231978
(na civce chce cca. < 200mA)
... ja bych tedy pouzil napriklad nize uvedene pro ovladani hned 4 rele ...
http://sk.farnell.com/national-semicond ... dp/1468983
... snad sem pomohl ... :repair:
Karya
Reputace: 1
Dakujem.Preberal som to aj na inom fore a spravil som to takto.Teraz riesim grafiku na lcd.Nechce mi to zobrazit na cely lcd aj ked mam nastavene 84x48 rozlisenie.Vedel by mi niekdo poradit?
Kód: Vybrat vše
delay(500);
  if (sensors.getTempC(insideThermometer)>70.0 && sensors.getTempC(outsideThermometer)<75.0) digitalWrite(cerpadlo, HIGH);
  if (sensors.getTempC(insideThermometer)<60.0 || sensors.getTempC(outsideThermometer)>75.0) digitalWrite(cerpadlo, LOW);
vanous
Nový příspěvek od vanous »
Karya píše:
neznám ten nokia LCD, ale někdy je potřeba buďto v parametru volání knihovny zadat ty, nebo rozlišení, nebo to případně upravit v knihovně (já si musím upravovat nastavení z 2x16 na 4x20 display...)
Karya
Reputace: 1
Tu je ta knihovna.Hladal som co by sa v nej malo zmenit ale nenasiel som.Vedel by si sa mi nato pozriet?Ked som skusal tento program tak to fungovalo na celom.Pridavam odkaz.
http://www.roboti.4fan.cz/vyuka/profesi ... 10-z-nokie
http://www.ulozto.cz/x8zt5AS/lcd-7z
