Arduino Termostat + Lcd Nokia 3310
Caute
Uz aj ja som hrdim vlastnnikom Arduina.Obraciam sa na vas.Nevedel by mi niekdo pomoct spravit podmienku?Moja predstava je ak v bojleru 1 bude teplota 60 c nezapinaj rele ak bude viac ako 60 zapny.Pripojene mam 2x DS18B20.Dakujem
Kód: Vybrat vše
#include <OneWire.h>
#include <DallasTemperature.h>
#include <PCD8544.h>
// Data wire is plugged into pin 2 on the Arduino
#define ONE_WIRE_BUS 2
// Setup a oneWire instance to communicate with any OneWire devices
OneWire oneWire(ONE_WIRE_BUS);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
// Assign the addresses of your 1-Wire temp sensors.
// See the tutorial on how to obtain these addresses:
// http://www.hacktronics.com/Tutorials/arduino-1-wire-address-finder.html
DeviceAddress insideThermometer = { 0x28, 0x6C, 0x2B, 0x24, 0x03, 0x00, 0x00, 0xB2 };
DeviceAddress outsideThermometer = { 0x28, 0x48, 0x24, 0x24, 0x03, 0x00, 0x00, 0xB7 };
// The dimensions of the LCD (in pixels)...
static const byte LCD_WIDTH = 84;
static const byte LCD_HEIGHT = 48;
static PCD8544 lcd;
const int LED = 13;
// A bitmap graphic (10x2) of a thermometer...
static const byte THERMO_WIDTH = 10;
static const byte THERMO_HEIGHT = 2;
static const byte thermometer[] = { 0x00, 0x00, 0x48, 0xfe, 0x01, 0xfe, 0x00, 0x02, 0x05, 0x02,
0x00, 0x00, 0x62, 0xff, 0xfe, 0xff, 0x60, 0x00, 0x00, 0x00};
void setup(void)
lcd.clear();
pinMode(LED, OUTPUT);
// Start up the library
sensors.begin();
// set the resolution to 10 bit (good enough?)
sensors.setResolution(insideThermometer, 10);
sensors.setResolution(outsideThermometer, 10);
lcd.begin(LCD_WIDTH, LCD_HEIGHT);
void printTemperature(DeviceAddress deviceAddress)
float tempC = sensors.getTempC(deviceAddress);
lcd.print(tempC);
lcd.print(" ");
if (tempC > 22.00 ) // podmienka na zopnutie rele
digitalWrite(LED, HIGH);
else
digitalWrite(LED, LOW);
void loop(void)
delay(500);
sensors.requestTemperatures();
lcd.setCursor(10,1);
lcd.print("Bojler (1): ");
printTemperature(insideThermometer);
lcd.setCursor(10,5);
lcd.print("Bojler (2): ");
printTemperature(outsideThermometer);
// Draw the thermometer bitmap at the bottom left corner...
lcd.setCursor(0,0);
lcd.drawBitmap(thermometer, THERMO_WIDTH, THERMO_HEIGHT);
lcd.setCursor(0,4);
- Lokalita: Mělník
- Výkon panelů [Wp]: 8550
Re: Arduino Termostat + Lcd Nokia 3310
V cem je problem ? Pouzij google
... nahore pridat ...
v setupu pridat ...
A kod by mel byt ...
... s tim, ze na PINu 13 tezko neco das, je tam natvrdo LEDka (vetsinou) ... takze pouzit 13 jako indikaci sepnuti rele ... a na sepnuti rele pouzit jiny pin, napsano je to pro pin 10.
A pro uplnost tady mas navod jak pripojit 5V rele k arduinu ... Tim rele muzes ovladat treba stykac a tak ...
http://www.glacialwanderer.com/hobbyrobotics/?p=9
Rele - napriklad ...
http://sk.farnell.com/omron-electronic- ... dp/1231978
(na civce chce cca. < 200mA)
... ja bych tedy pouzil napriklad nize uvedene pro ovladani hned 4 rele ...
http://sk.farnell.com/national-semicond ... dp/1468983
... snad sem pomohl ...
Kód: Vybrat vše
const int LED = 13;
const int RELE = 10;
Kód: Vybrat vše
pinMode(RELE, OUTPUT);
Kód: Vybrat vše
if ((tempC > 60.00) && (deviceAddress == "insideThermometer")) // podmienka na zopnutie rele
digitalWrite(RELE, HIGH);
else
digitalWrite(RELE, LOW);
Dakujem.Preberal som to aj na inom fore a spravil som to takto.Teraz riesim grafiku na lcd.Nechce mi to zobrazit na cely lcd aj ked mam nastavene 84x48 rozlisenie.Vedel by mi niekdo poradit?
Kód: Vybrat vše
delay(500);
if (sensors.getTempC(insideThermometer)>70.0 && sensors.getTempC(outsideThermometer)<75.0) digitalWrite(cerpadlo, HIGH);
if (sensors.getTempC(insideThermometer)<60.0 || sensors.getTempC(outsideThermometer)>75.0) digitalWrite(cerpadlo, LOW);
neznám ten nokia LCD, ale někdy je potřeba buďto v parametru volání knihovny zadat ty, nebo rozlišení, nebo to případně upravit v knihovně (já si musím upravovat nastavení z 2x16 na 4x20 display...)Karya píše:Dakujem.Preberal som to aj na inom fore a spravil som to takto.Teraz riesim grafiku na lcd.Nechce mi to zobrazit na cely lcd aj ked mam nastavene 84x48 rozlisenie.Vedel by mi niekdo poradit?
Tu je ta knihovna.Hladal som co by sa v nej malo zmenit ale nenasiel som.Vedel by si sa mi nato pozriet?Ked som skusal tento program tak to fungovalo na celom.Pridavam odkaz.
http://www.roboti.4fan.cz/vyuka/profesi ... 10-z-nokie
http://www.ulozto.cz/x8zt5AS/lcd-7z
- 18 Odpovědi
- 2293 Zobrazení
Poslední příspěvek od rva
DARUJI: Bezdrátový termostat pro Fibaro
od youda » » v Daruji
- 8 Odpovědi
- 790 Zobrazení
Poslední příspěvek od youda
Zdarma: bezdrátový Z-WAVE Termostat, nutný reflash
- 5 Odpovědi
- 916 Zobrazení
- 9 Odpovědi
- 3411 Zobrazení
Poslední příspěvek od kodl69
- 15 Odpovědi
- 4208 Zobrazení
Poslední příspěvek od proasnet
