Axpert VM 24V 3000W Plus PF1
Populární hybridní měniče značky Axpert (např. Axpert King, VMIII). Konfigurace, monitoring, firmware, chyby a rozšíření o BMS, LiFePO4, atd.
- Reputace: 287
Re: Axpert VM 24V 3000W Plus PF1
No oni píšu:
nsp = 1, potom Ir = / 1- 1 / x hocičo = 0 A.
nsp = 2, potom Ir = / 2 - 1 / x Isc = 1 x Isc A.
nsp = 2, potom Ir = / 3 - 1 / x Isc = 2 x Isc A.
Takže vidno, že niekedy je istenie zbyťočné.
The short-circuit current of solar cells, PV modules and
strings is only slightly higher than the operating current.
An overcurrent protective device designed for the shortcircuit current of a string will therefore hardly trip in the
event of a simple short-circuit in the string. A particularly
fast trip is also not desirable as higher currents can
How does a reverse current occur – and what are the
dangers?
A reverse current can be caused by short-circuit or an earth
fault over one or more modules in a string of a PV system.
This can occur i.a. in the event of damage to the insulation
or in case of a short-circuit in the module or lines and can
damage other modules installed in the string.
flow briefly due i.a. to cloud enhancements or increased
irradiation intensity due to reflection of the solar radiation.
The danger for the modules installed in the strings is
created by the reverse currents fro
Takže, ak:Where strings are connected in parallel, the reverse current
in the defective string is the aggregated current of the other
strings:
Ir = (nsp – 1) × Isc
Where: Ir Maximum reverse current
nsp Number of strings connected in parallel
Isc Short-circuit current of a solar module/string
- mati
- Reputace: 29
Z mojí zkušenosti je každá "přítomná" kuna agresivní! Vždy si vybere k likvidaci , co tě nejvíc na.ere!kodl69 píše:takže zvlšť pozor na kuny agresivní povahy, před tím norma varuje![]()
Jen ta co koupila šipku mezi oči a soused profesionálně vyčinil kožich slouží prospěšně na ledvinách - ale těch slepic co to stálo..
Pajavk
- Reputace: 24
tak už jsem konečně fixnul ty problémy s panelama
když se podíváte dnes na průběhy napětí a proudu jak se vám to jeví ?
od rána do jedenácti jel bulk potom do dvou absorbce a pak float. Ty doby těhle fází je to takhle optimální pro 575Ah baterii ?
nicméně poslední věc, přepnutí na grid mám na 24V a zpět na batt na 25V, teď večer to po chvilkovém zatížení přeplo na síť ale zpátky už se to na baterku nevrátilo i když je napětí na baterce 25,2V i když jsem to snížil na 24V stejně to už na baterku nepřepne, proč
http://89.248.244.138/dashboard/view?id=1
- JonasPP
- Reputace: 150
No axpert ma svoj rozum a keď povie nie,tak nie. Ja som to riešil zhodenim DS na vstupe do axperta a opätovnym nahodem ističa.
24v-PJ 5kW;NiCd -10kWh
12v-10A MPPT;sin~300W;PB 4kWh
Pajavk
- Reputace: 24
no to je dementní
vysledoval jsem, že se tak děje ve chvíli kdy není na vstupu ze soláru žádné napětí = noc, na baterku se přepne ráno po páté hodině jak se objeví první volty z panelů
chová se vám to taky tak ?
Prackov
- Reputace: 15
- Lokalita: Turnov
- Výkon panelů [Wp]: 5000
- Kapacita baterie [kWh]: 10000
Mám sice jen 2400w.
Ale chová se úplně stejně.
A ještě taky rád když je více zatížen...1500w
A nabíhá lednice nebo mrazák tak se rád hodí po lehkém přetížení do bypassu.
Ale když nevidí na vstupu síť....
Vše dá levou zadní.
Jen si pípne a pokračuje ve své práci.
Už se také povedlo docela veliké přetížení když běžel vařič a vedoucí kuchyně pustila mikrovlnku.
Na chudákovi který řval a řval bylo 2850w.
Vše dá levou zadní.
24v 700Ah. Lifepo4 .
12v 750Ah olovo....
Smartshunt, cerbo
Victron smart 100/20
Victron Smart. 100/50
Victron smart 150/45
Victron smart 150/70
Epsolar 40A na 12v
12v 750Ah olovo....
Smartshunt, cerbo
Epsolar 40A na 12v
dumi
- Reputace: 157
podle manualu se doctete ze do 105% drzi trvale, mezi 105-neco asi 15 vterin a nad 150 asi 3 vteriny.
to prepinani do bypasu pri pretizeni se da vypnout v menu.
nebo tim ze se odpoji DS. (mnam ji trvale odpojenou a pripinam jen kdyz to vyzaduji.
Pajavk
- Reputace: 24
jo to je v pohodě to funguje ale problém nastane večer když se zatíží chvilkově napětí padne pod 24V přepne na DS odběr ustane, baterka se vrátí na 25V ale zůstane to viset na DS až do rána. Ve chvíli kdy se objeví nějaké napětí na panelech tak přepne na baterku. Prakticky tedy celou noc jedu z DS i když je baterka nabitá...
dumi
- Reputace: 157
tak tu DS odpoj nebo nastav nizsi napeti pro prechod znova na baterie.
Pajavk
- Reputace: 24
už jsem to tu psal, bez napětí ze solaru se na baterku nepřepne i když tam nastavím cokoli a odpojovat DS to bych musel běhat k jističi furt, proto sem doufal, žetohle bude za mě dělat ten axpertdumi píše:tak tu DS odpoj nebo nastav nizsi napeti pro prechod znova na baterie.
dumi
- Reputace: 157
no pokud mas proste resim SUB, a napeti klesne pod prepinaci tak to padne na DS, zpet se to dostane pouze v pripade, ze napeti baterie preleze precinaci napeti.
mas tyto moznosti:
1] nastavit nizky prepinaci napeti smerem na baterii -> to muze mit zase jine neduhy v jinych pripadech, ale to zalezi od toho jak to pouzivas
2] nejakou chytrloou logikou vycitat, ze je axpert prepnut na DS a na par vterin mu tu DS odpojit.
mas tyto moznosti:
- Reputace: 239
Napěťové relé kde si můžeš nastavit napětí při kterém se odpojí ds a kdy se připojí sice to dubluje funkci conuz má axpert ale ten bohužel má priority dane výrobcem takže ti úplně nesplňuje co by jsi očekával.
matobabetak
- Reputace: 28
pozeram ze mas skoro 600ah baterku, to nevydrzi ked z nej tahas 100A?Pajavk píše:jo to je v pohodě to funguje ale problém nastane večer když se zatíží chvilkově napětí padne pod 24V přepne na DS odběr ustane, baterka se vrátí na 25V ale zůstane to viset na DS až do rána. Ve chvíli kdy se objeví nějaké napětí na panelech tak přepne na baterku. Prakticky tedy celou noc jedu z DS i když je baterka nabitá...
oscar
- Reputace: 22
u mojej 48V verzie to funguje tak, ze odpojenie je sice na 48V, ale znova vratenie sa k baterke je pri 48V+2V podla manualu = 50V, skus to prestudovat u Teba ci nie je tam podobne pripadne posli config a porovnam s mojim...Pajavk píše:jo to je v pohodě to funguje ale problém nastane večer když se zatíží chvilkově napětí padne pod 24V přepne na DS odběr ustane, baterka se vrátí na 25V ale zůstane to viset na DS až do rána. Ve chvíli kdy se objeví nějaké napětí na panelech tak přepne na baterku. Prakticky tedy celou noc jedu z DS i když je baterka nabitá...
cz7jfm
- Reputace: 2
Mas tam nastavenou prioritu SBU?
To je divny to musi prepnou zpět na baterku.
Jake to jsou presne polozky v menu Axperta o kterych pises (24V a 25V)?
PS: ted ctu co pise oscar a asi ma pravdu tam myslim musi byt rozdil minimalne 2V
moje nastaveni:
http://cz0njf.dreamsys.cz/m/mobile.htm (tl. AXP)
moje nastaveni:
Pajavk píše:tak už jsem konečně fixnul ty problémy s panelama![]()
nicméně poslední věc, přepnutí na grid mám na 24V a zpět na batt na 25V, teď večer to po chvilkovém zatížení přeplo na síť ale zpátky už se to na baterku nevrátilo i když je napětí na baterce 25,2V i když jsem to snížil na 24V stejně to už na baterku nepřepne, proč![]()
FVP 2,4kWp, EPSolar 4215BN, BMV 700, Epever 3000SHI, Axpert msxe, BMZ Li-Ion 8,1kWh@24V
Pajavk
- Reputace: 24
nastavení
01 SBU
12 24V
13 25V
zkusil sem ho ještě úplně vypnout odpojením od všeho aby se restartoval tak uvidíme večer jestli to pomohlo
01 SBU
12 24V
13 25V
oscar
- Reputace: 22
ked nestaci, skus dat 13 na 24.5V.
Co mas pri 29? 24V tiez?
01,12 je podla mna OK
Pajavk
- Reputace: 24
tak to vypadá, že ten restart celého axpertu zabral, asi to bylo v nějakém divnostavu, nicméně teď už to pracuje jak má. Díky za rady
mám ještě řešit upgrade firmware nebo to nic nepřinese a radši na to nešahat ?
- shuty
- Reputace: 56
takze staci rozdiel 1v?Pajavk píše:tak to vypadá, že ten restart celého axpertu zabral, asi to bylo v nějakém divnostavu, nicméně teď už to pracuje jak má. Díky za rady
prepnut na ds mas pri 24v a spat na baterku pri 25v?
Pajavk
- Reputace: 24
ten graf je jen výstup z axperta a ten posílá 0 nebo 1 podle toho zda jede z DS nebo BATT, nastaveno mám 24 vypni a 25 zapni. Bohužel je tam ta nedokonalost, že když ho zatížíš a jde to pod 24 tak přepíná jak vzteklej na DS s tím bohužel nic asi neudělám.shuty píše:takze staci rozdiel 1v?Pajavk píše:tak to vypadá, že ten restart celého axpertu zabral, asi to bylo v nějakém divnostavu, nicméně teď už to pracuje jak má. Díky za rady
