Čez HDO
- Reputace: 93
Čez HDO
Takto čez od 28 března spíní a odpíná HDO.Třeba i 60x za den.
2016-03-28 15:49:16 - Nizky tarif.
2016-03-28 16:07:21 - Vysoky tarif.
2016-03-28 16:07:26 - Nizky tarif.
2016-03-28 16:09:06 - Vysoky tarif.
2016-03-28 16:09:11 - Nizky tarif.
2016-03-28 16:12:21 - Vysoky tarif.
2016-03-28 16:12:26 - Nizky tarif.
2016-03-28 16:22:52 - Vysoky tarif.
2016-03-28 16:22:57 - Nizky tarif.
2016-03-28 16:23:42 - Vysoky tarif.
2016-03-28 16:23:47 - Nizky tarif.
2016-03-28 16:29:42 - Vysoky tarif.
2016-03-28 16:29:47 - Nizky tarif.
2016-03-28 16:31:17 - Vysoky tarif.
2016-03-28 16:31:22 - Nizky tarif.
2016-03-28 17:15:02 - Vysoky tarif.
2016-03-28 17:15:07 - Nizky tarif.
2016-03-28 17:16:07 - Vysoky tarif.
2016-03-28 17:16:12 - Nizky tarif.
2016-03-28 17:30:57 - Vysoky tarif.
2016-03-28 17:31:02 - Nizky tarif.
2016-03-28 17:31:07 - Vysoky tarif.
2016-03-28 17:31:12 - Nizky tarif.
2016-03-28 17:33:32 - Vysoky tarif.
2016-03-28 17:33:37 - Nizky tarif.
2016-03-28 17:36:27 - Vysoky tarif.
2016-03-28 17:36:32 - Nizky tarif.
2016-03-28 17:36:42 - Vysoky tarif.
2016-03-28 17:36:47 - Nizky tarif.
2016-03-28 17:43:42 - Vysoky tarif.
2016-03-28 17:43:47 - Nizky tarif.
2016-03-28 17:48:22 - Vysoky tarif.
2016-03-28 17:48:27 - Nizky tarif.
2016-03-28 17:54:17 - Vysoky tarif.
2016-03-28 17:54:22 - Nizky tarif.
2016-03-28 17:57:02 - Vysoky tarif.
2016-03-28 21:06:13 - Nizky tarif.
2016-03-28 21:18:43 - Vysoky tarif.
2016-03-28 21:18:48 - Nizky tarif.
2016-03-28 21:23:03 - Vysoky tarif.
2016-03-28 21:23:08 - Nizky tarif.
2016-03-28 21:41:48 - Vysoky tarif.
2016-03-28 21:41:53 - Nizky tarif.
2016-03-28 22:05:34 - Vysoky tarif.
2016-03-28 22:05:39 - Nizky tarif.
2016-03-28 22:18:49 - Vysoky tarif.
2016-03-28 22:18:54 - Nizky tarif.
2016-03-28 22:25:59 - Vysoky tarif.
2016-03-28 22:26:04 - Nizky tarif.
2016-03-28 22:44:19 - Vysoky tarif.
2016-03-28 22:44:29 - Nizky tarif.
2016-03-28 22:45:24 - Vysoky tarif.
2016-03-28 22:45:34 - Nizky tarif.
2016-03-28 22:48:24 - Vysoky tarif.
2016-03-28 22:48:29 - Nizky tarif.
2016-03-28 23:14:04 - Vysoky tarif.
2016-03-28 23:14:09 - Nizky tarif.
2016-03-28 23:20:24 - Vysoky tarif.
2016-03-28 23:20:29 - Nizky tarif.
2016-03-28 23:37:09 - Vysoky tarif
- tarif.docx
- Hdo
- (11.11 KiB) Staženo 129 x
SOLINTEG MHT-50K-100, východ střecha 14,5Kwp,jižní stěna 6,3 Kwp,západ střecha 15,5Kwp, chalupa Majda 7,6 Kwp. Baterie 6x Soluna HV PACK 10K ,optimizéry Tigo.
- Reputace: 6
Re: Čez HDO
To se mi moc nezdá. Ja mam CEZ, oblast Morava. Používám SDS a na grafech pŕesně vidím, kdy se tarify pŕepínají. Jedou dle harmonogramu. Nebude to spíš vadný přijímač HDO? Mně už ho měnili dvakrát.
- Reputace: 258
Re: Čez HDO
Toto Dreamboxi odporuje PPDS nebokdejetodefinovanesitednepamatuji. Problém bude v elektrorozvodné síti. Něco sakra ruší. Prvně bych být Tebou zjišťoval u sebe a paralelně bych jim tento LOG zaslal jako reklamaci. S tím, že Tvůj spínací prvek (stykač) je nadměrně opotřebováván a že pracuješ na ověřitelném zdokumentování poruchového stavu. Jaké měřicí přístroje byly použity a jejich ověření že jim sdělíš v protokolu jenž bude přílohou vyčíslení případné škody. Na podobné formulace oni slyší a kupodivu budou i akční.
edit: "Tyto časy mohou být ze strany distributora měněny, jakákoliv změna však musí být zveřejněna minimálně s týdenním předstihem."
Naposledy upravil(a) brumlaj dne sob dub 02, 2016 9:26 am, celkem upraveno 2 x.
- tomas
- Reputace: 242
Re: Čez HDO
A co máš za tarif? Nedávno jsem řešil něco podobného a nakonec to byl vadný stykač vedle 4Q elektroměru. Nějak jsem nepochopil proč mezi 4Q elektroměr a stykač ovládající spotřebiče začali dávat ještě jeden stykač když už je v tom elektroměru bezpotenciálové relé k tomuto účelu navržené. Když je tam nedávali tak to bylo spolehlivější, teď se ten další stykač umístěný často venku v elektroměrovém pilíři (zima, teplo, vysoká vlhkost) dost kazí. Ten stykač není stavěný na takové prostředí. Kontakty oxidují a kotva cívky a celý mechanizmus zreziví a nefunguje to dobře.
Myslím že HDO není tak rychlé aby během 4 sekund dokázali vyslat signál na další změnu tarifu.
- Reputace: 258
Re: Čez HDO
Když mi montovali 4Q technik se zajímal o spotřebu stykače, který mám pro spínání. To v elektroměru totiž nejsou mechanické kontakty ale optočlen s definovaným max. napětím a proudem. No a pokud nejsi doma, tak místo aby zjistili ampérmetrem jak se věci mají, tak jednoduše na místo prijímače HDO šoupnou relé a lipa. Ze strany zákazníka je to dobré řešení, protože kdyby jsi si v bytovém rozvaděči škrtnul vypadnutým vodičem o jinou fázi, tak platíš celý 4Q, takhle maximálně pouze relé za pár stovek. Bohužel je to jak píšeš další kurvítko v cestě.tomas píše:......... Nějak jsem nepochopil proč mezi 4Q elektroměr a stykač ovládající spotřebiče začali dávat ještě jeden stykač když už je v tom elektroměru bezpotenciálové relé k tomuto účelu navržené. ...........
- Reputace: 93
Re: Čez HDO
Před tímto datumem to bylo normální a HDO je furt stejné,mám toto .
2016-03-01 02:01:10 - Nizky tarif.
2016-03-01 05:34:02 - Vysoky tarif.
2016-03-01 14:33:02 - Nizky tarif.
2016-03-01 16:20:19 - Vysoky tarif.
2016-03-01 16:20:24 - Nizky tarif.
2016-03-01 16:32:29 - Vysoky tarif.
2016-03-01 21:21:07 - Nizky tarif.
2016-03-01 23:52:09 - Vysoky tarif.
- Reputace: 18
Re: Čez HDO
Letos v zimě jsem zpozoroval (a zdokumnetoval) jinou anomálii HDO, ke které snad dříve nedocházelo. ČEZ po několik minutách aktivovaného NT pomocí HDO zruší nízký tarif a za chvíli NT znovu obnoví. Vypadá to jako by při aktivaci NT zjistil, že na požadovaný výkon nemá zdroje a tak na chvíli shodí zvýšený odběr, zdroje spustí a pak znovu obnoví NT. Viz graf. Naposledy to bylo 24.2.
18x 550Wp, 16xLiFePO 780Ah (stáří 0, 1, 2, 10 let), STUDER: 3x MPPT VT65; 3x Xtender 4000-48. PLC TECO2091
- Reputace: 258
Re: Čez HDO
Tak jsem strhaný jako borůvka, tedy čas na (mo)mentální činnost..... Je to už starší text ale když si v letošním cenovém rozhodnutí ERÚ najdeš příslušnou pasáž(strana 23 bod č.3), tak bych jim pohrozil opravou bojleru jenž jako tepelný zdroj užívá tepelné čerpadlo. Tam zapínání a vypínání obvykle vede k vyššímu opotřebení. A u ceny 55 litrů jistě začnou uspokojovat svou nekrofilní zoofilii (hledat kde je zakopaný pes).
- Reputace: 93
Re: Čez HDO
Tak už mě volal technik Čezu že přišel na opravu.Bohužel jsem nebyl doma tak příjde v pondělí.Určitě vymění HDO a uvidíme.
- Reputace: 246
- Kapacita baterie [kWh]: 36
Re: Čez HDO
Já su jen blbej slaboproudar a elektrárny jsme ve škole nebraly. Jak jako nemá výkon ? A za chvilu zase ma ?nemáme snad dvě jaderný plus další elektrárny a snad jsem zaslechl ze vyvazime salinu... At jdou do riti.honzaL píše:Letos v zimě jsem zpozoroval (a zdokumnetoval) jinou anomálii HDO, ke které snad dříve nedocházelo. ČEZ po několik minutách aktivovaného NT pomocí HDO zruší nízký tarif a za chvíli NT znovu obnoví. Vypadá to jako by při aktivaci NT zjistil, že na požadovaný výkon nemá zdroje a tak na chvíli shodí zvýšený odběr, zdroje spustí a pak znovu obnoví NT. Viz graf. Naposledy to bylo 24.2.
Proč zdroje nespusti před sepnutim NT? Je to nějaký divný.
Zlatý spínací hodiny a bylo to bez dohadů.
- Reputace: 33
Re: Čez HDO
Výkonu je dost, ovšem nutno si uvědomit, že NT slouží k efektivnímu "vytěžování" sítě v době, kdy je výkonu přebytek a není efektivní snižovat výrobu.
Bojlery a akumulačky zapojené na dvojsazbu slouží elektrické síti úplně lautr stejně, jako wattrouter pro fotovoltaiku - spotřebovávají přebytečný výkon.
Nevýhodou HDO v dnešní podobě je to, že DS nemá žádnou zpětnou vazbu, kolik je zrovna vychlazených bojlerů, jediné číslo, které má v ruce je to, co občan napsal do "přihlášky", plus empiricky nasbírané zkušenosti že "v oblasti x je na daném povelu k dispozici Y megawattů"
Každopádně, nějaké cyklování HDO je porucha, NT musí vždycky trvat nejméně dvě(?) hodiny. HDO jedou na frekvencích 166,6 Hz, 216 Hz a další neharmonické frekvence (záleží na oblasti) a stačí připojit šikovný zdroj rušení. Přenos kódu je sichrován pouze opakovaným vysíláním, žádný handshake se nekoná.
http://honzasl.blogspot.cz/
- Lokalita: Jablonec n.N.
- Výkon panelů [Wp]: cca 500 W
- Kapacita baterie [kWh]: cca 240 Ah
Re: Čez HDO
Zdravím, kdysi jsem to tady řešil v jiném tématu, např. Grid Free a pod .. tak to dávám sem jenom jako připomínku, jak HDO funguje někde na vesnicích, kde je na jednom vedení připojeno několik domů s boilery a s akumulačkami případně .. tak tam je HDO nastaveno časem a to tak, aby se všechny boilery a akumulačky nezapínaly najednou a vedení neshořelo a nebo aby nelehla pojistka .. takže proto se to spíná časově a v každém baráku trošku jinak ...
Uživatelé prohlížející si toto fórum: Claudebot [Bot], GPTBot a 0 hostů
