Raspberry Pi + Thermocam + GetThermal
Pro detekci teploty baterie na Raspberry Pi s Armbianem je potřeba nainstalovat GetThermal a Thermocam. Problémem je starší verze QT5 5.1, která nevyhovuje požadavku na verzi 5.7 a vyšší, což komplikuje konfiguraci a běh aplikace.
rottenkiwi
Reputace:287
Lokalita: SO, SK
Lokalita:SO, SK
Potrebujem na detekciu teploty baterky naištalovať na Armbian toto:
https://github.com/groupgets/GetThermal
Lenže tam mám QT5 5.1 a potrebujem 5.7+.
.configure mi píše:
cd qtbase/ && ( test -e Makefile || /usr/lib/arm-linux-gnueabihf/qt5/bin/qmake /home/pavol/qt-everywhere-opensource-src-5.7.0/qtbase/qtbase.pro -o Makefile ) && make -f Makefile
make[1]: Entering directory '/home/pavol/qt-everywhere-opensource-src-5.7.0/qtbase'
cd src/ && ( test -e Makefile || /usr/lib/arm-linux-gnueabihf/qt5/bin/qmake /home/pavol/qt-everywhere-opensource-src-5.7.0/qtbase/src/src.pro -o Makefile ) && make -f Makefile
make[2]: Entering directory '/home/pavol/qt-everywhere-opensource-src-5.7.0/qtbase/src'
cd tools/bootstrap/ && ( test -e Makefile || /usr/lib/arm-linux-gnueabihf/qt5/bin/qmake /home/pavol/qt-everywhere-opensource-src-5.7.0/qtbase/src/tools/bootstrap/bootstrap.pro -o Makefile ) && make -f Makefile
make[3]: Entering directory '/home/pavol/qt-everywhere-opensource-src-5.7.0/qtbase/src/tools/bootstrap'
g++ -c -g -O2 -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -ffunction-sections -O2 -fPIC -std=c++11 -std=c++11 -fno-exceptions -Wall -W -D_REENTRANT -DQT_NO_TSLIB -DQT_BOOTSTRAPPED -DQT_LITE_UNICODE -DQT_NO_CAST_TO_ASCII -DQT_NO_CODECS -DQT_NO_DATASTREAM -DQT_NO_LIBRARY -DQT_NO_QOBJECT -DQT_NO_SYSTEMLOCALE -DQT_NO_THREAD -DQT_NO_UNICODETABLES -DQT_NO_USING_NAMESPACE -DQT_NO_DEPRECATED -DQT_NO_TRANSLATION -DQT_CRYPTOGRAPHICHASH_ONLY_SHA1 -DQT_NO_FOREACH -DQT_NO_CAST_FROM_ASCII -DQT_BUILD_BOOTSTRAP_LIB -DQT_BUILDING_QT -DQT_ASCII_CAST_WARNINGS -DQT_MOC_COMPAT -DQT_USE_QSTRINGBUILDER -DQT_DEPRECATED_WARNINGS -DQT_DISABLE_DEPRECATED_BEFORE=0x050000 -DQT_NO_EXCEPTIONS -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE -DQT_NO_DEBUG -I. -I../../../include -I../../../include/QtCore -I../../../include/QtCore/5.7.0 -I../../../include/QtCore/5.7.0/QtCore -I../../../include/QtXml -I../../../include/QtXml/5.7.0 -I../../../include/QtXml/5.7.0/QtXml -I../../../mkspecs/linux-g++ -o .obj/qlatincodec.o ../../corelib/codecs/qlatincodec.cpp
Makefile:668: recipe for target '.obj/qlatincodec.o' failed
make[3]: Leaving directory '/home/pavol/qt-everywhere-opensource-src-5.7.0/qtbase/src/tools/bootstrap'
Makefile:63: recipe for target 'sub-bootstrap-make_first' failed
make[2]: Leaving directory '/home/pavol/qt-everywhere-opensource-src-5.7.0/qtbase/src'
Makefile:45: recipe for target 'sub-src-make_first' failed
make[1]: Leaving directory '/home/pavol/qt-everywhere-opensource-src-5.7.0/qtbase'
Makefile:77: recipe for target 'module-qtbase-make_first' failed
