Arduino monitoring pre smartphony
ixo
Příspěvek od ixo »
Ahojte,
tymto sa pridavam k bastlicom v Arduine a s radostou vam ponukam svoje minidielko. Umožňuje zobrazovať v smartphone aktualne napatie baterii a zaznamenane minimalne a maximalne napatie v ramci dna, aj s uvedenim casu. Cas sa natiahne z NTP servera pri starte arduina. Realizacia celeho riesenia vyzera v telefone takto:
Obrázek
Samotna Android appka, ktora zabezpecuje zobrazenie HTML arduinom generovanej stranky v automaticky refreshovanom widgete sa da stiahnut tu:
https://play.google.com/store/apps/deta ... S53ZzAxIl0.
Tu je arduino kod:
Kód: Vybrat vše
#include <Time.h>
#include <Ethernet.h>
#include <EthernetUdp.h>
#include <SPI.h>
//TCP/IP konfiguracia
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(192,168,2,177);
EthernetServer server(80);
EthernetClient client02;
// NTP konfiguracia
IPAddress timeServer(132, 163, 4, 101); // time-a.timefreq.bldrdoc.gov
const int timeZone = 2;
EthernetUDP Udp;
unsigned int localPort = 8888;  // local port to listen for UDP packets
const int NTP_PACKET_SIZE = 48; // NTP time is in the first 48 bytes of message
byte packetBuffer[NTP_PACKET_SIZE]; //buffer to hold incoming & outgoing packets
// Premenne widgetu
float maximum = 0;
int max_hod;
int max_min;
float minimum = 100;
int min_hod;
int min_min;
int den = 0;
float napatie;
// Setup
void setup() {
  Serial.begin(9600);
  Ethernet.begin(mac, ip);
  server.begin();
  Udp.begin(localPort);
  setSyncProvider(getNtpTime);
//A rob dokola
void loop() {
  EthernetClient client = server.available();
  if (client) {
//    Serial.println("Novy klient");
    boolean currentLineIsBlank = true;
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        if (c == '\n' && currentLineIsBlank) {
          client.println("HTTP/1.1 200 OK");
          client.println("Content-Type: text/html");
          client.println("Connection: close");
          client.println();
          client.println("<!DOCTYPE HTML>");
          client.println("<html>");
          client.println("<head>");
          client.println("</head>");
          client.println("<body style='background-color:#FFEBD7;'>");
          int scitavane = 0;
          for (int a = 1; a<=20; a++) {
            int sensorReading = analogRead(3);
            delay(100);
            scitavane = scitavane + sensorReading;
          client.print("<div><span style='font:100px arial,sans-serif;'>");
          float napatie = (float)(round((((float)scitavane/(float)20)) * (float)0.03193172626682720 * (float)10)/(float)10);
          client.println((float)napatie,1);
          client.println("V</span>");
          // Ak je aktualne cislo mensie ako minimum, updatni minimum
          if ((float)napatie < (float)minimum) {
            minimum = (float)napatie;
            min_hod = (int)hour();
            min_min = (int)minute();
            Serial.print("Preniesol som nacitane: ");
            Serial.println(min_min);
          // Ak je aktualne cislo vacsie ako maximum, updatni maximum
          if ((float)napatie > (float)maximum) {
            maximum = (float)napatie;
            max_hod = (int)hour();
            max_min = (int)minute();
          client.print("<br>");
          client.print("<span style='font:16px arial,sans-serif; width:200px;padding-left:10px;'>");
          client.println("Min: <b>");
          client.print(minimum,1); client.print("V</b> ");
          client.print((min_hod));client.print(":");
          if (min_min < 10) {client.print("0");}
          client.print((min_min));
          client.print(";    ");
          client.println("Max: <b>");
          client.print(maximum,1);client.print("V</b> ");
          client.print(max_hod);client.print(":");
          if (max_min < 10) {client.print("0");}
          client.print(max_min);
          client.println("</span></div>");
          // Ak sa zmenilo cislo dna, nuluj
          if ((int)den != (int)day()) {
            minimum = 100;
            maximum = 0;
            den = (int)day();
          client.println("</body>");
          client.println("</html>");
          break;
        if (c == '\n') {
        else if (c != '\r') {
          currentLineIsBlank = false;
    // Dajme browseru trochu casu
    delay(1);
    client.stop();
//    Serial.println("client disonnected");
time_t getNtpTime()
  while (Udp.parsePacket() > 0) ; // discard any previously received packets
  Serial.println("Transmit NTP Request");
  sendNTPpacket(timeServer);
  uint32_t beginWait = millis();
  while (millis() - beginWait < 1500) {
    int size = Udp.parsePacket();
    if (size >= NTP_PACKET_SIZE) {
      Serial.println("Receive NTP Response");
      Udp.read(packetBuffer, NTP_PACKET_SIZE);  // read packet into the buffer
      unsigned long secsSince1900;
      // convert four bytes starting at location 40 to a long integer
      secsSince1900 =  (unsigned long)packetBuffer[40] << 24;
      secsSince1900 |= (unsigned long)packetBuffer[41] << 16;
      secsSince1900 |= (unsigned long)packetBuffer[42] << 8;
      secsSince1900 |= (unsigned long)packetBuffer[43];
      return secsSince1900 - 2208988800UL + timeZone * SECS_PER_HOUR;
  Serial.println("No NTP Response :-(");
  return 0; // return 0 if unable to get the time
// send an NTP request to the time server at the given address
void sendNTPpacket(IPAddress &address)
  // set all bytes in the buffer to 0
  memset(packetBuffer, 0, NTP_PACKET_SIZE);
  // Initialize values needed to form NTP request
  // (see URL above for details on the packets)
  packetBuffer[0] = 0b11100011;   // LI, Version, Mode
  packetBuffer[1] = 0;     // Stratum, or type of clock
  packetBuffer[2] = 6;     // Polling Interval
  packetBuffer[3] = 0xEC;  // Peer Clock Precision
  // 8 bytes of zero for Root Delay & Root Dispersion
  packetBuffer[12]  = 49;
  packetBuffer[13]  = 0x4E;
  packetBuffer[14]  = 49;
  packetBuffer[15]  = 52;
  // all NTP fields have been given values, now
  // you can send a packet requesting a timestamp:
  Udp.beginPacket(address, 123); //NTP requests are to port 123
  Udp.write(packetBuffer, NTP_PACKET_SIZE);
  Udp.endPacket();
V kode je na prepocet hodnot z A/D prevodnika pouzita konstanta 0.03193172626682720, bude potrebne si ju upravit v zavislosti od konfiguracie vasho napatoveho delica. Napatie mi prepocitava bud presne na desatinu volta, pripadne o jednu desatinu volta viac (len preto, ze som nemal presny multimeter pri vypocte konstanty). S kodom si samozrejme robte, co len chcete, za pripadne skody samozrejme nerucim. :)
A treba mat samozrejme od internet providera verejnu IP a know-how, ako si ju preroutovat na IP arduina. Komu sa casto meni verejna IP, moze si zriadit ucet na no-ip.com a pristupovat k arduinu cez domenovy nazov, napriklad (nejakynazov.no-ip.info).
Este fotka nasho hi-tech satnika:
Obrázek
Zlava hore doprava dole:
Skatulka, v ktorej je skryte Arduino. Ma vetracie otvory, vobec sa neprehrieva. Hrubsi cierny kabel v sebe skryva napatovy delic;
PWM regulator;
Hasiaci pristroj; :)
Mechanicky prepinac siete;
Elektromer solarneho okruhu;
Zasuvka "silna" - vzdy je v nej prud z verejnej siete;
Zasuvka prepinana - bud prepnuta verejna siet, alebo solarna;
Napajanie arduina;
WiFi repeater - don je kablom pripojene Arduino.
Lokalita: Žabčice
Výkon panelů [Wp]: 29139
Kapacita baterie [kWh]: 12
Chci prodávat energii: ANO
Re: Arduino monitoring pre smartphony
Příspěvek od PavelR »
Tak toto je naprosto fenomenalni....
007ToMMaS
Příspěvek od 007ToMMaS »
Vynikajúce. Vidím v tom využitie a uplatnenie keď sa raz pustím do urobenia akejsi stanice o informácii o mojej FVE. Kde sa budú zobrazovať data na displej, mobile, a možno aj na webe. Dúfam to bude čoskoro. Teraz riešim bezdrátový prenos pomocou 433mhz a arduina mini. Len akosi keď to zavriem v rozvádzači tak signál je fuč. Jedno arduino mega bude akási ústredňa a arduino mini pro(tých bude asi aj viac) bude odosielať na megu.
3,2kWp REC320NP - juh
střídač
Příspěvek od střídač »
007ToMMaS píše: Len akosi keď to zavriem v rozvádzači tak signál je fuč
Vypadá to tak, že "Faradayova klec" a tím i fyzikální zákony, vskutku fungují.
007ToMMaS
Tak tak. Čo človek zavre do plechového rozvádzača a potrebuje to signál tak je to nereálne. Problém vyviesť nejakú anténku von neni problém .
Lokalita: Žabčice
Zdravim.
Nevite nekdo kde by sly stahnout ty soubory time.h a ethernetudp.h ? Nejak se mi nedari najit funkcni download ....
Frenky
Lokalita: Doubravička
Výkon panelů [Wp]: 8700
Kapacita baterie [kWh]: 25
Příspěvek od Frenky »
Lokalita: Žabčice
Dekuji
Lokalita: Žabčice
Zkousel to nekdo? funguje vam to nastaveni casu?
me to porad pise toto
No NTP Response :-(
Solarnoob
Lokalita: Kadaň
Výkon panelů [Wp]: 1680
Příspěvek od Solarnoob »
ixo píše: Komu sa casto meni verejna IP, moze si zriadit ucet na no-ip.com a pristupovat k arduinu cez domenovy nazov, napriklad (nejakynazov.no-ip.info).
Pokud někdo používá "Mobilní internet" LTE od operátorů a funguje mu to, at mi rekne jak na to. Mě to u Vodafonu nefunguje :-) A podle toho co jsem zjistil asi fungovat nemůže.
6x 280 Wp AmeriSolar| Axpert King I 5000-48V | 4x Sonnenschein SRP 12V 175 A RAIL
soami
Lokalita: Posázaví
Příspěvek od soami »
Na to bys potřeboval veřejnou IP nebo vlastní VPN. Teď jsi za NAT operátora, což je na druhou stranu i trochu výhoda v bezpečnosti.
