Victron VRM API
Home Assistant, Arduino, SDS, Raspberry, Linux, vzdálený dohled, automatizace, měření, opensource, closedsource, hotová řešení, DIY, stavebnice, komponenty, software, postupy, návody, schémata, rady, zkušenosti ...
Victron VRM API
Pouzivate niekto toto VRM API ?
https://vrm-api-docs.victronenergy.com/#/
Nejako mi nejde sa tam lognut ani s "bearer" ani s "token" tokenom.
Re: Victron VRM API
Tak uz som to pochopil:
Najprv musite pomocou emailu a passwordu poslat:
Ziskate long-lived-token a mozete si ho pozriet na:
https://jwt.io/
Pomocou bearer tokenu vygenerujete token:
A pre vas user_id si vypisete vsetky vase installations:
A pre kazdu installation ziskate instalovane devices:
200 OK
Kód: Vybrat vše
curl --request POST \
--url https://vrmapi.victronenergy.com/v2/auth/login \
--header 'Content-Type: application/json' \
--data '{
"username": "john@example.com",
"password": "somepassword",
"remember_me": "true"
https://jwt.io/
Kód: Vybrat vše
--url https://vrmapi.victronenergy.com/v2/users/<vas_user_id>/accesstokens/create \
--header 'x-authorization: Bearer <vas bearer token>' \
--data '{
"name": "MyNewToken"
Kód: Vybrat vše
curl --request GET \
--url https://vrmapi.victronenergy.com/v2/installations/<install_id>/system-overview \
--header 'x-authorization: Bearer <vas_bearer_token>'
Kód: Vybrat vše
Kód: Vybrat vše
"success": true,
"records": {
"devices": [
"name": "Gateway",
"customName": null,
"productCode": "",
"idSite": xxxxx,
"productName": "Generic Venus Device (rpi or other)",
"firmwareVersion": "vx.xx",
"remoteOnLan": "192.xx.xx.yy",
"autoUpdate": "On",
"updateTo": "Official release",
"lastConnection": 1672501009,
"class": "device-gateway device-icon-generic-venus-device--rpi-or-other-",
"loggingInterval": 60,
"identifier": "xxxxxxxxxx",
"lastPowerUpOrRestart": 1618280821,
"vncSshAuth": true,
"vncStatus": "Enabled",
"vncPort": 0,
"twoWayCommunication": true,
"remoteSupportEnabled": false,
"remoteSupportPort": xxxxx,
"remoteSupportIp": "xx.xx.xx.xx",
"remoteSupport": "disabled",
"machineSerialNumber": null,
"settings": []
"name": "VE.Bus System",
"customName": null,
"productCode": "",
"idSite": xxxxx,
"productName": "MultiPlus-II 48/3000/35-32 (50A ext sensor)",
"firmwareVersion": "xxx",
"class": "device-ve-bus device-icon-multiplus-ii-48-3000-35-32--50a-ext-sensor-",
"productId": "xxxx",
"vmc": "VE.Bus",
"vid": {
"enumValue": "Single unit",
"devicesPerPhase": {
"L1": 1,
"L2": 0,
"L3": 0
"instance": xxx,
"idDeviceType": 1,
"settings": []
"name": "Solar Charger",
"customName": "",
"productCode": "",
"idSite": yyyyy,
"productName": "BlueSolar Charger MPPT 150/60",
"class": "device-solar-charger device-icon-bluesolar-charger-mppt-150-60",
"machineSerialNumber": "H56456456456456",
"instance": xxx,
"idDeviceType": 4,
"settings": []
"unconfigured_devices": []
Naposledy upravil(a) rottenkiwi dne sob pro 31, 2022 4:50 pm, celkem upraveno 1 x.
Re: Victron VRM API
A este diagnostika:
Kód: Vybrat vše
--url 'https://vrmapi.victronenergy.com/v2/installations/<vase_is>/diagnostics?count=10&page=10' \
--header 'x-authorization: Bearer '
Kód: Vybrat vše
"success": true,
"records": [
"idSite": xxxxx,
"timestamp": 1672501489,
"Device": "VE.Bus System",
"instance": 289,
"idDataAttribute": 325,
"description": "Inverter To AcOut",
"formatWithUnit": "%.2F kWh",
"dbusServiceType": "vebus",
"dbusPath": "/Energy/InverterToAcOut",
"code": "t9",
"bitmask": 0,
"formattedValue": "6.37 kWh",
"rawValue": "6.37",
"id": 1
"idSite": xxxxxx,
"instance": 289,
"idDataAttribute": 326,
"description": "AcOut to Inverter",
"dbusPath": "/Energy/OutToInverter",
"code": "t10",
"bitmask": 0,
"formattedValue": "0.04 kWh",
"rawValue": "0.04",
"id": 2
"idSite": xxxxx,
"timestamp": 1672135580,
"instance": 289,
"idDataAttribute": 357,
"description": "Device 0 assistant list",
"formatWithUnit": "%s",
"dbusServiceType": null,
"dbusPath": null,
"code": "asT0",
"bitmask": 0,
"formattedValue": "",
"rawValue": "",
"id": 3
"idSite": xxxxxx,
"instance": 289,
"idDataAttribute": 523,
"description": "High DC Ripple",
"dbusPath": "/Alarms/Ripple",
"code": "eR",
"bitmask": 0,
"formattedValue": "Ok",
"rawValue": 0,
"dataAttributeEnumValues": [
"nameEnum": "Ok",
"valueEnum": 0
"nameEnum": "Warning",
"valueEnum": 1
"nameEnum": "Alarm",
"valueEnum": 2
"id": 4
"idSite": xxxxxx,
"instance": 289,
"idDataAttribute": 344,
"description": "Temperature L1",
"dbusPath": null,
"code": "eT1",
"bitmask": 0,
"rawValue": 0,
"nameEnum": "Ok",
"valueEnum": 0
"valueEnum": 1
"valueEnum": 2
"id": 5
"idSite": xxxxx,
"instance": 289,
"idDataAttribute": 345,
"description": "Low battery L1",
"dbusPath": null,
"code": "eL1",
"bitmask": 0,
"rawValue": 0,
"nameEnum": "Ok",
"valueEnum": 0
"valueEnum": 1
"valueEnum": 2
"id": 6
"idSite": xxxxxx,
"instance": 289,
"idDataAttribute": 346,
"description": "Overload L1",
"dbusPath": null,
"code": "eO1",
"bitmask": 0,
"rawValue": 0,
"nameEnum": "Ok",
"valueEnum": 0
"valueEnum": 1
"valueEnum": 2
"id": 7
"idSite": xxxxxx,
"instance": 289,
"idDataAttribute": 347,
"description": "High DC Ripple L1",
"dbusPath": null,
"code": "eR1",
"bitmask": 0,
"rawValue": 0,
"nameEnum": "Ok",
"valueEnum": 0
"valueEnum": 1
"valueEnum": 2
"id": 8
"idSite": xxxxxx,
"instance": 289,
"idDataAttribute": 348,
"description": "Temperature L2",
"dbusPath": null,
"code": "eT2",
"bitmask": 0,
"rawValue": 0,
"nameEnum": "Ok",
"valueEnum": 0
"valueEnum": 1
"valueEnum": 2
"id": 9
"idSite": xxxxxx,
"instance": 289,
"idDataAttribute": 349,
"description": "Low battery L2",
"dbusPath": null,
"code": "eL2",
"bitmask": 0,
"rawValue": 0,
"nameEnum": "Ok",
"valueEnum": 0
"valueEnum": 1
"valueEnum": 2
"id": 10
"num_records": 163
Victron system 2,5kW + 4x 110Ah Victron baterie, prosim pomo
od badumi1 » » v Hybridní elektrárny
- 20 Odpovědi
- 2475 Zobrazení
- 3 Odpovědi
- 1246 Zobrazení
Poslední příspěvek od FRSO
- 22 Odpovědi
- 1816 Zobrazení
Poslední příspěvek od 1lubos1
- 55 Odpovědi
- 3323 Zobrazení
