Arduino Pachube client
Pokud byste chtěli experimentovat s Pachube (pachube.com), ujistěte se, že použijete arduino IDE 1.0, nebo alespoň 1.0~beta1+dfsg-1 (debian unstable/experimental), starší verze se tvářily, že fungují, ale spojení neprocházelo. Nyní funguje standardní pachube example přímo z IDE. ušetříte si... cca jeden večer
Re: Arduino Pachube client
release early, release often
První testovací verze pachube upload clienta pro arduino uno s ethernet shield a 16x4 displejem.
co dělá: odesílá jednu proměnou (V) na pachube feed. vypisuje stav na displej.
co chybí: spousta. zatím testuji pouze s potenciomentrem na pin5, ne na bateriích.
závislosti: pachube účet a vytvořený feed.
#include <LiquidCrystal.h>
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = {
0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED};
// initialize the library instance:
Client client;
Simple Solar Battery Monitor
The circuit:
Volts ( pin0) scaled input from 24vdc battery to max 5v for digitize
Amps (pin1) input for hall effect current sensor 0 amps ~ 3.5v
Output to 16x4 LCD display
created Aug 2010 for Battery Monitor
by Jerry Jeffress
Adopted Dec 2011 by Petr Vanek
- 16x4 display
- pot for display blight and led light instead of contrast/blight pins
- upload to Pachube
- remove dependencies on Metro and Streaming
- DHCP
const int voltsInPin = 5; //voltage sensor for 24V system
const int ampsInPin = 1;
//const int backLitePin = 5; //not used
//const int contrastPin = 6; //not used
const float batterySize = 9.48; //Battery capacity in KwHrs
const float chargeEff = 0.85; //Approx Amount of power into a lead acid battery that is stored
long lastConnectionTime = 0; // last time you connected to the server, in milliseconds
long lastLCDTime = 0;
const int postingInterval = 10000; //delay between updates to Pachube.com
const int LCDInterval = 1000; //delay between updates to Pachube.com
boolean lastConnected = false; // state of the connection last time through the main loop
//Metro oneSecond = Metro(1000); // Instantiate an one timer
int aSecond;
int blinkit;
int bStatus; //Battery status, 0-6 states
float absorbCtr, chargeCtr, disChargeCtr, eqCtr;
float absorbTimeOut = 60*60*3.0;//3 hours in seconds
float eqTimeOut = 60*60*3.0; //3 Hours in seconds
float tenHours = 60*60*10.0;
float sec2Hr = 1.0/(1000 * 3600.0); //Convert watt-sec to kwHrs
float volts, amps, power;
float bCharge; //This is power monitor variable total effective charge to and from the battery
float bLow; //low battery value
// initialize the LCD library with the numbers of the interface pins
LiquidCrystal lcd(9, 8, 5, 4, 3, 2);
void setup(){
Serial.begin(9600); // Start the Serial communication for debug mainly
//analogWrite(backLitePin, 64); //LCD backlite 1/4 full 20.6 ma on battery pack
//analogWrite(contrastPin, 80); //Set LCD contrast
aSecond = 0;
blinkit = 0;
bCharge = batterySize * 0.95; //init charge 95% full battery
absorbCtr = 0;
eqCtr = 0;
chargeCtr = 60*9;
disChargeCtr = 0;
bLow = 0.5; //Low battery warning when hattery 50% charged
bStatus = 7;//This a an error value must be updated in Calculate bStatus
// set up the LCD's number of rows and columns:
lcd.begin(16, 4);
lcd.print("Init.....");
if (Ethernet.begin(mac) == 0) {
Serial.println("Failed to configure Ethernet using DHCP");
// lcd.setCursor(0,0);
// lcd.print("Failed to configure Ethernet using DHCP");
// no point in carrying on, so do nothing forevermore:
for(;;)
// give the ethernet module time to boot up:
delay(1000);
void loop(){
if (millis() - lastLCDTime > LCDInterval) { // check if the metro has passed it's interval .
//sample volt and amps from the battery
sampleVoltsAmps();
/* // Output serial time volts amps as to display
Serial << aHour << _BYTE(58) << aMinute << _BYTE(58) <<
aSecond << _BYTE(9) << volts << _BYTE(9) << amps << _BYTE(9) << bCharge << _BYTE(9) <<
(batteryStatus
) << endl;
//Update LCD display each second
calcPower();
calcbStatus();
newDay();
//if(aSecond % 6 < 3)
displayStatus();
//else
//displayCtr();
//aSecond = aSecond++;
//if (aSecond >= 60)
// aSecond = 0;
// ((blinkit = blinkit++;
//if (blinkit > 1)
// blinkit = 0;
lastLCDTime = millis();
if (millis() - lastConnectionTime > postingInterval){
// if there's incoming data from the net connection.
// send it out the serial port. This is for debugging
// purposes only:
if (client.available()) {
char c = client.read();
Serial.print(c);
// if there's no net connection, but there was one last time
// through the loop, then stop the client:
// if (!client.connected() && lastConnected) {
// Serial.println();
// Serial.println("disconnecting.");
// client.stop();
// if you're not connected, and ten seconds have passed since
// your last connection, then connect again and send data:
if(!client.connected()) {
Serial.println("sending");
sendData(); //data sending happens here
// store the state of the connection for next time through
// the loop:
lastConnected = client.connected();
void sampleVoltsAmps() {
int voltSum = 0.0;
float ampSum = 0.0;
// loop 10 time over one 50hz cycle to smooth
for (int i = 0; i < 10; i++){
volts = map(analogRead(voltsInPin), 0, 1023, 0, 3309); //adjust for your sensor
voltSum = voltSum + volts;
amps = map(analogRead(ampsInPin), 0, 1023, -806, 217); //adjust for your sensor
ampSum = ampSum + amps;
delay(2);
}//end smooth loop
//Get 10 sample average
volts = voltSum /1000.0; //Factor to scale to volts
amps = ampSum * 0.015; //Factor to scale to Amps
//Calc power
void calcPower(){
power = volts * amps; //Units are watt-seconds
if (power <= 0){
bCharge = bCharge +(power * sec2Hr);
else {
bCharge = bCharge + (power * sec2Hr * chargeEff);
//Calculate bStatus
void calcbStatus(){
bStatus = 0; //This charge/discharge
if(amps >= 0)
chargeCtr = chargeCtr +1;
if(amps < 0){
disChargeCtr = disChargeCtr + 1;
//if(volts < 28.3)
//absorbCtr = absorbCtr -1; //debug only commint
if(absorbCtr < 0)
absorbCtr = 0;
if(volts > 28.3){
bStatus = 1;
absorbCtr = absorbCtr + 1;
if(volts > 27.3 && absorbCtr > absorbTimeOut)
bStatus = 2;
// New Day
void newDay(){
if(disChargeCtr == tenHours) //10 hours
chargeCtr = 0;
if(chargeCtr > 60*10 && disChargeCtr > tenHours){
//Serial << "Debug trap new day" << _BYTE(9) << disChargeCtr <<endl;
disChargeCtr = 0;
absorbCtr = 0;
eqCtr = 0;
//Other saves for a New Day
//update LCD Display
void displayStatus(){
// Print volts to LCD.
lcd.setCursor(0,0);
lcd.print("BAT ");
lcd.print(volts, 1); //display volts to one decimal place
lcd.print("V ");
// Print % full to display
if(bCharge < batterySize){
lcd.print(100 * bCharge/batterySize,1);
lcd.print("%");
else{
lcd.print("Full ");
bCharge = batterySize;
//Print Battery Status to Display
lcd.setCursor(0, 1);
switch(bStatus){
case 0:
if(amps >= 0)
lcd.print("Charge ");
else
lcd.print("Discharge ");
break;
case 1:
lcd.print("Absorb ");
break;
case 2:
lcd.print("Float ");
break;
default:
lcd.print("Error ");
if(bCharge < bCharge * bLow){//Battery Low blink
if(blinkit==0)
lcd.print("Low ");
else
lcd.print(" Low");
if(volts > 29.2 && eqCtr < eqTimeOut){
lcd.print("Equalize ");
eqCtr =eqCtr + 1;
//Print Amps to display right justified
if(amps<0){ //All negative
if(amps<-9.9){
lcd.print(amps,1);
else{
lcd.print(" ");
lcd.print(amps,1);
else { //all positive or zero
if(amps>9.9){
lcd.print("+");
lcd.print(amps,1);
else{
lcd.print(" +");
lcd.print(amps,1);
lcd.print("A");
//Counter page
//void displayCtr(){
//lcd.clear();
lcd.setCursor(0, 2);
lcd.print("Chr ");
lcd.print(chargeCtr/60,0);
lcd.print(" Dis ");
lcd.print(disChargeCtr/60,0
lcd.setCursor(0,3);
lcd.print("Abs ");
lcd.print(absorbCtr/60,0);
lcd.print(" eq ");
lcd.print(eqCtr/60,0);
// this method makes a HTTP connection to the server:
void sendData() {
// if there's a successful connection:
if (client.connect("www.pachube.com", 80)) {
Serial.println("connecting...");
// send the HTTP PUT request.
// fill in your feed address here:
client.print("PUT /api/41032.csv HTTP/1.1\n");
client.print("Host: http://www.pachube.com\n");
// fill in your Pachube API key here:
client.print("X-PachubeApiKey: XXXXXXXXXXXX\n");
client.print("Content-Length: ");
//int thisData = analogRead(5);
float thisData = volts;
int thisLength = getLength(thisData);
// calculate the length of the sensor reading in bytes:
client.println(thisLength + 3, DEC);
Serial.print("length: ");
Serial.print(thisLength);
// last pieces of the HTTP PUT request:
client.print("Content-Type: text/csv\n");
client.println("Connection: close\n");
// here's the actual content of the PUT request:
//client.print("1, ");
client.println(thisData, DEC);
//Serial.print("sending volts: ");
//Serial.println(thisData);
//Serial.print("was volts: ");
//Serial.println(volts);
// note the time that the connection was made:
lastConnectionTime = millis();
Serial.println();
client.stop();
else {
// if you couldn't make a connection:
Serial.println("connection failed");
// This method calculates the number of digits in the
// sensor reading. Since each digit of the ASCII decimal
// representation is a byte, the number of digits equals
// the number of bytes:
int getLength(int someValue) {
// there's at least one byte:
int digits = 1;
// continually divide the value by ten,
// adding one to the digit count for each
// time you divide, until you're at 0:
int dividend = someValue /10;
while (dividend > 0) {
dividend = dividend /10;
digits++;
// return the number of digits:
return digits;
Pokud budete chtít nahrávat program do arduina UNO připojeného přes USB k linuxové mašině z dálky, z konzole to jde lehce (v linuxu):
na mašinu s připojeným arduinem není potřeba celé arduino ide (arduino, arduino-cor) ale stačí nainstalovat avrdude:
na místní mašině, kde vyvíjíte, se po kompilaci v arduino ide vytvoří .hex někde v tempu, třeba takto:
tak si to pošlete na ten comp s arduinem, třeba takto:
ssh-čkujte se do té vzdálené mašiny a nahrajte do arduino takto:
šlo by to spustit i přes ssh, třeba takto:
A nemusíte do mrazu, pokud to máte přes dvůr
Kód: Vybrat vše
apt-get -u install avrdude
Kód: Vybrat vše
/tmp/build5976941872115855353.tmp/solar.cpp.hex
Kód: Vybrat vše
scp /tmp/build5976941872115855353.tmp/solar.cpp.hex root@192.168.3.4:/tmp/
Kód: Vybrat vše
avrdude -F -v -v -v -pm328p -cstk500v1 -P/dev/ttyACM0 -D -Uflash:w:/tmp/solar.cpp.hex
Kód: Vybrat vše
ssh -C -v root@192.168.3.4 avrdude -F -v -v -v -pm328p -cstk500v1 -P/dev/ttyACM0 -D -Uflash:w:/tmp/solar.cpp.hex
Založil jsem projekt na googlecode, viz tento oznam: https://plus.google.com/u/0/10575124820 ... Xbdij58UT8 , mimo jiné obsahuje vyčítání komunikace ze sínového Měniče MeanWell TS-1500-224B 1500W.
doplnil jsem vzdálené vypínání/zapínaní měniče pomocí elegantního vypínače, viz příklad (ne můj měnič ): http://apps.pachube.com/dashboard/11475 ... 5oXCerjDig
Hledám I2C multirelé board, něco jako toto, nevíte o nečem?
http://www.robot-electronics.co.uk/cgi- ... %23a54#a54
Vše funguje jak má, ale ethernet shield evidentně není bez chyby a pokud data posílám i přijímám tak se to umí seknout a pomůže až reset. Trochu pomohlo snížení frekvence odesílání, ale úplně pomohlo pouze odesílat a nestahovat... toš tak...
nebylo to ethshieldem, ale displejem - po jeho odebrání hw i z kódu mám nelimitovaný uptime...vanous píše:Vše funguje jak má, ale ethernet shield evidentně není bez chyby a pokud data posílám i přijímám tak se to umí seknout a pomůže až reset. Trochu pomohlo snížení frekvence odesílání, ale úplně pomohlo pouze odesílat a nestahovat... toš tak...
HELP s aplikací Smart Client Solar (k wifi modulu od MUST)
od fremma » » v mivvy ENERGY
- 18 Odpovědi
- 591 Zobrazení
Poslední příspěvek od Soban
- 3 Odpovědi
- 1547 Zobrazení
Poslední příspěvek od jan.westhuserlt
- 25 Odpovědi
- 4785 Zobrazení
Poslední příspěvek od 250w_gridfree
- 3 Odpovědi
- 756 Zobrazení
Poslední příspěvek od rottenkiwi
- 25 Odpovědi
- 1397 Zobrazení
Poslední příspěvek od cipis
