nějak jsem se zamotal do tvorby senzorů pro měření energie na mém EASUN 8kW
našla by se dobrá duše co by mi pomohla rozklíčovat co mám špatně napsané?
celková spotřeba mi funguje, u energie do a z baterie to tam nejsem schopen dostat
jednotlivé senzory se mi zobrazují, ale do Energy panelu je nedostanu - vždy nějaká chyba
sensor:
- platform: integration
source: sensor.pipsolar_ac_output_active_power_2
method: left
unit_prefix: k
source: sensor.battery_charge_power_actual
method: left
unit_prefix: k
source: sensor.battery_discharge_power_actual
method: left
unit_prefix: k
template:
- sensor:
############Součet obou PV vstupu#######################
- name: "PV input total"
state: >-
{{ states('sensor.pipsolar_pv1_charging_power') | int + states('sensor.pipsolar_pv2_charging_power') | int }}
unit_of_measurement: "W"
device_class: energy
#############Nabíjecí výkon okamžitý####################
- name: "Battery charge power actual"
state: >-
{{ (states('sensor.pipsolar_battery_charging_current') | float * states('sensor.pipsolar_battery_voltage') | float) | round(2)}}
#device_class: energy
#state_class: total_increasing
#############Vybíjecí výkon okamžitý###################
- name: "Battery discharge power actual"
state: >-
{{ (states('sensor.pipsolar_battery_discharge_current') | float * states('sensor.pipsolar_battery_voltage') | float) | round(2)}}
- name: "Battery charge power total"
state: >-
{{ (states('sensor.pipsolar_battery_charging_current') | float * states('sensor.pipsolar_battery_voltage') | float) / 1000 | round (1) }}
unit_of_measurement: "kWh"
- name: "Battery discharge power total"
state: >-
{{ (states('sensor.pipsolar_battery_discharge_current') | float * states('sensor.pipsolar_battery_voltage') | float) / 1000 | round(1)}}
utility_meter:
pipsolar_ac_output_active_power_2_consumption_hourly:
cycle: hourly
battery_charge_power_total_consumption_hourly:
cycle: hourly
battery_discharge_power_total_consumption_hourly:
cycle: hourly
