Fórum | MyPower.CZ | Obnovitelné zdroje energie - energetická soběstačnost | Poslední návštěva: čtv čer 01, 2023 5:06 pm
Lubo99 píše:Aliexpres ....epever wifi RJ45D
void loop()
uint8_t resultMain;
resultMain = node.readInputRegisters(0x3100, 16);
if (resultMain == node.ku8MBSuccess)
Serial.println(" - - - - - - - - - - - - - - ");
pn=node.getResponseBuffer(0x00)/ 100.0f;
Serial.print("Panely napeti: " );
Serial.println(pn);
pp=node.getResponseBuffer(0x01)/ 100.0f;
Serial.print("Panely proud: ");
Serial.println(pp);
pv=(node.getResponseBuffer(0x02) | node.getResponseBuffer(0x03) << 16)/ 100.0f;
Serial.print("Panely vykon: ");
Serial.println(pv);
bn=node.getResponseBuffer(0x04)/ 100.0f;
Serial.print("Baterie napeti: ");
Serial.println(bn);
bp=node.getResponseBuffer(0x05)/ 100.0f;
Serial.print("Baterie proud: ");
Serial.println(bp);
bv=(node.getResponseBuffer(0x06) | node.getResponseBuffer(0x07) << 16)/ 100.0f;
Serial.print("Baterie vykon: ");
Serial.println(bv);
bstatus=node.getResponseBuffer(0x00);
Serial.print("Batery stav: ");
Serial.println(bstatus);
bmax=node.getResponseBuffer(0x02)/ 100.0f;
Serial.print("Baterie max: ");
Serial.println(bmax);
bmin=node.getResponseBuffer(0x03)/ 100.0f;
Serial.print("Baterie min: ");
Serial.println(bmin);
btemp=node.getResponseBuffer(0x0)/ 100.0f;
Serial.print("Baterie teplota: ");
Serial.println(dtemp);
dtemp=node.getResponseBuffer(0x1)/ 100.0f;
Serial.print("Teplota zarízeni: ");
Serial.println(btemp);
bsoc=node.getResponseBuffer(0xa)/ 100.0f;
Serial.print("Baterie soc: ");
Serial.println(bsoc);
ednes=(node.getResponseBuffer(0x00) | node.getResponseBuffer(0x01) << 16)/ 100.0f;
Serial.print("Baterie - energie dnes: ");
Serial.println(ednes);
Serial.print("Baterie - energie mesic: ");
emesic=(node.getResponseBuffer(0x02) | node.getResponseBuffer(0x03) << 16)/ 100.0f;
Serial.println(emesic);
erok=(node.getResponseBuffer(0x04) | node.getResponseBuffer(0x05) << 16)/ 100.0f;
Serial.print("Baterie - energie rok: ");
Serial.println(erok);
etotal=(node.getResponseBuffer(0x06) | node.getResponseBuffer(0x07) << 16)/ 100.0f;
Serial.print("Baterie - energie celkem: ");
Serial.println(etotal);
cstatus=node.getResponseBuffer(0x01);
Serial.print("Stav nabijeni: ");
Serial.println(cstatus);
dstatus=node.getResponseBuffer(0x02);
Serial.print("Stav zarizeni: ");
Serial.println(dstatus);
sestávající z až 32 zařízení a možností komunikace na vzdálenost až 1 200 m
BigSandy píše:Zdar.
Najde se tu někdo, kdo poradí?
Strana 3 - skopec tu dal zdrojak D34_fve.ino
Jen jsem to ořezal ale adresy zustali puvodní.
Fungovat to funguje, ale je to nějak poplantane.
- Kód: Vybrat vše
void loop()
uint8_t resultMain;
Serial.println(pn);
Serial.println(pp);
Serial.println(pv);
Serial.println(bn);
Serial.println(bp);
Serial.println(bv);
Batery stav: 6771.00
Baterie max: 97.62
Baterie teplota: 1.38
BigSandy píše:https://cs.wikipedia.org/wiki/RS-485sestávající z až 32 zařízení a možností komunikace na vzdálenost až 1 200 m
Kabl je kabl.
Ja mam Epever v garaži a kabl 20 metru k počitači.
wimpi píše:BigSandy píše:https://cs.wikipedia.org/wiki/RS-485sestávající z až 32 zařízení a možností komunikace na vzdálenost až 1 200 m
Kabl je kabl.
Tomu se chci vyhnout. Drátů už je všude dost. Vrtat do zdi se mi nechce, nevede tam totiž žádný husí krk.
wimpi píše:Ano, to je pravda. Regulátory mám ale dva, takže dva kabely….jak je ale potom připojit oba do jednoho PC?
