DIY 3kW Arduino MPPT Solar Charge Controller ESP32
rottenkiwi
Reputace: 287
Lokalita: SO, SK
Re: DIY 3kW Arduino MPPT Solar Charge Controller ESP32
Nestoji, stoji od 9 do 18 €.
https://sk.farnell.com/adafruit/642/hig ... dp/2816441
https://sk.farnell.com/dfrobot/dfr0198/ ... dp/3517904
Do BMS 24 + 16 + 16, na kazdy clanok jedno
Do MPPT 2 + 2 + 2 + 2 , ambient, toroidy, FET-y, kondy
Na 23 panelov, 3 na panel, kazde miesto panelu sa inac hreje.
HOrny roh, stred a dolny roh maju rozdiely aj 5 - 6 *C
A su rozne druhy:
Family B: reserved bytes in scratchpad register can be overwritten (by following instructions in the datasheet)
Family C: the sensor is fixed in 12-bit mode (i.e., byte 4 of the scratchpad register is always 0x7f)
Family C: the number of EEPROM write cycles is very small (order of 10 rather than >50k)
Family B1, D1: ROM can be changed in software, i.e. it is not lasered
Family A2, B2, D: significant number of sensors with offsets outside the ±0.5 C range at 0 °C
Family D: sensor does not respond in parasitic mode (applies to most sensors of Family D)
Family D: the temperature reading right after power-up is 25 rather than 85 °C
Family D: sensor does not perform low-resolution temperature conversions faster
Family D: reserved bytes 5 and 7 of the scratchpad register are not 0xff and 0x10, respectively
Family D1: retains temperature measurements during power cycles
11 ms: Family D1
28-30 ms: Family C
325-505 ms: Family A2
460-525 ms: Family D2
580-615 ms: Family A1
585-730 ms: Family B
Charlie_XZ
Reputace: 9
Nový příspěvek od Charlie_XZ »
Taková knížecí rada, co začít používat nějaký normální teploměry, buď analogový (10k NTC třeba..) nebo nějaký I2C. Jako chápu že dallas běhá po 2 drátech, ale v prostředí kde je rušení to stejně není žádná sláva ...
Naposledy upravil(a) Charlie_XZ dne ned kvě 21, 2023 3:05 pm, celkem upraveno 1 x.
tomas
Reputace: 242
Nový příspěvek od tomas »
Jo s těmi čidly Dallas jsem si také užil. Nejvíc mně štvalo že někomu to funguje přes celou zahradu zvonkovým drátem a jako druhý pól používá Zem a já jsem dal stíněné kabely pro 4 čidla vedle sebe, napájení a data zvlášť, je to na jedné akumulační nádrži a na Unipi nic, nekomunikuje. Pouze samostatně jedno po druhém a společně ani ťuk. Tak to teď dávám přes převodníky např. https://www.aliexpress.com/item/1005003 ... 18020IcjSS
ale občas také z některých čidel posílá stále 0°C i když to tam není. Takže jsem tam naprogramoval restart převodníku pokud je teplota v nesmyslných mezích.
rottenkiwi
Reputace: 287
Lokalita: SO, SK
Tak mne ide o to, aby to bolo dobre zaizolovane proti napatiu, lebo clovek ked mera
a ma malo cidiel a dava to na rozne miesta MPPT, tak o nieco skrtne
a uz som si tak 2x odpalil ESP32 + IR2104, a vidim, ze tie izolovane su drahe
a vonku pod panely tiez len izolovane.
Pri tych 10 k NTC, tak tam zas ked je to dlhsie, tak uz spocitat presne teplotu
sa asi ani neda, neda rovnaku tep., ten co je 5 cm a co 40 cm daleko.
LUT pre NTC:
Kód: Vybrat vše
double R1 = 10000.0; // voltage divider resistor value
double Beta = 3977.0; // Beta value
double To = 298.15; // Temperature in Kelvin for 25 degree Celsius
double Ro = 10000.0; // Resistance of Thermistor at 25 degree Celsius
const float ADC_LUT[4096] PROGMEM = { 0,
7.4000,17.0000,18.8000,20.8000,22.8000,24.8000,26.6000,28.6000,30.4000,32.2000,33.6000,34.8000,36.0000,37.2000,38.6000,
39.8000,41.0000,42.2000,43.8000,44.8000,46.0000,47.2000,48.6000,49.6000,50.6000,51.6000,52.4000,53.4000,54.4000,55.4000,
56.4000,57.2000,58.2000,59.2000,60.2000,61.2000,62.2000,63.0000,64.0000,65.2000,66.6000,67.8000,68.8000,69.8000,71.0000,
72.0000,73.0000,74.2000,75.4000,76.6000,77.8000,78.8000,80.0000,81.0000,82.4000,83.8000,85.0000,86.2000,87.6000,88.8000,
90.0000,91.4000,92.8000,94.0000,95.0000,96.4000,97.2000,98.0000,99.0000,99.8000,100.8000,101.8000,102.6000,103.4000,104.0000,
105.0000,106.0000,106.8000,107.8000,108.8000,109.6000,110.4000,111.0000,112.0000,113.4000,114.8000,116.0000,117.2000,118.8000,120.0000,
121.2000,122.8000,124.0000,125.2000,126.8000,128.0000,129.0000,130.0000,131.0000,132.0000,133.2000,134.4000,135.4000,136.6000,137.8000,
138.8000,139.8000,140.8000,141.8000,143.0000,144.0000,145.0000,146.6000,147.8000,149.0000,150.6000,151.8000,153.0000,154.4000,155.8000,
157.0000,158.2000,159.8000,160.8000,161.4000,162.0000,163.0000,163.8000,164.6000,165.0000,166.0000,166.8000,167.6000,168.2000,169.0000,
169.8000,170.8000,171.2000,172.0000,172.8000,173.8000,174.4000,175.0000,175.8000,177.0000,178.0000,179.2000,180.6000,181.8000,182.8000,
184.0000,185.0000,186.4000,187.8000,188.8000,190.0000,191.0000,192.2000,193.2000,194.2000,195.4000,196.4000,197.4000,198.4000,199.4000,
200.6000,201.6000,202.6000,203.6000,204.8000,205.8000,206.8000,207.8000,208.8000,209.8000,210.8000,211.8000,212.8000,214.0000,215.0000,
216.0000,217.0000,218.0000,219.0000,220.0000,221.2000,222.2000,223.4000,224.4000,225.8000,226.8000,228.0000,229.0000,230.2000,231.4000,
232.8000,233.8000,235.0000,236.0000,237.2000,238.6000,239.8000,241.0000,242.6000,244.0000,245.8000,247.0000,248.8000,250.2000,251.8000,
253.2000,254.8000,256.2000,257.2000,258.2000,259.0000,260.0000,261.0000,262.0000,263.0000,264.0000,265.0000,266.0000,267.0000,267.8000,
268.8000,269.8000,270.8000,271.8000,272.6000,273.0000,273.8000,274.6000,275.0000,275.8000,276.6000,277.0000,277.8000,278.4000,279.0000,
279.8000,280.4000,281.0000,281.8000,282.2000,283.0000,283.8000,284.2000,285.0000,285.8000,286.2000,287.0000,287.8000,288.0000,291.0000,
293.8000,296.4000,299.0000,301.8000,304.2000,305.2000,306.2000,307.2000,308.2000,309.2000,310.0000,311.0000,312.0000,313.0000,314.0000,
315.0000,316.0000,317.0000,318.0000,319.0000,320.0000,321.0000,322.2000,323.6000,324.8000,325.8000,326.8000,328.0000,329.0000,330.0000,
331.4000,332.6000,333.8000,334.8000,335.8000,336.8000,337.8000,338.8000,339.8000,340.6000,341.4000,342.2000,343.2000,344.0000,345.0000,
346.0000,347.0000,347.8000,348.8000,349.8000,350.8000,351.6000,352.4000,353.2000,354.0000,355.0000,356.0000,357.0000,357.8000,358.8000,
359.8000,360.8000,361.6000,362.4000,363.2000,364.0000,365.0000,366.0000,367.0000,367.8000,369.0000,370.4000,371.8000,373.0000,374.8000,
376.0000,377.4000,378.8000,380.0000,381.8000,383.0000,384.4000,386.0000,387.8000,389.0000,390.8000,392.2000,393.8000,395.4000,397.0000,
398.8000,400.0000,401.6000,402.8000,404.0000,405.4000,406.8000,408.0000,409.2000,410.8000,411.8000,413.0000,414.6000,415.8000,417.0000,
418.0000,419.0000,420.2000,421.4000,422.6000,423.8000,424.8000,425.8000,427.0000,428.0000,429.0000,430.2000,431.4000,432.4000,433.0000,
434.0000,434.8000,435.6000,436.2000,437.0000,437.8000,438.8000,439.4000,440.0000,441.0000,441.8000,442.6000,443.2000,444.0000,444.8000,
445.8000,446.4000,447.0000,448.0000,448.8000,449.8000,450.8000,451.6000,452.4000,453.2000,454.0000,455.0000,456.0000,456.8000,457.8000,
458.8000,459.8000,460.6000,461.4000,462.2000,463.0000,464.0000,465.6000,467.0000,468.8000,470.2000,472.0000,473.6000,475.0000,476.8000,
478.2000,479.8000,480.8000,481.8000,482.6000,483.2000,484.0000,485.0000,485.8000,486.8000,487.4000,488.0000,489.0000,489.8000,490.8000,
491.6000,492.4000,493.0000,494.0000,494.8000,495.8000,496.8000,498.2000,499.8000,501.4000,503.0000,504.8000,506.0000,507.8000,509.4000,
511.0000,512.4000,513.8000,514.8000,516.0000,517.0000,518.0000,519.4000,520.6000,521.8000,522.8000,524.0000,525.0000,526.2000,527.6000,
528.6000,529.4000,530.2000,531.0000,532.0000,533.0000,534.0000,534.8000,535.8000,536.8000,537.8000,538.6000,539.4000,540.2000,541.0000,
542.0000,543.0000,544.0000,545.4000,547.0000,548.8000,550.6000,552.2000,554.0000,555.8000,557.6000,559.0000,560.8000,561.8000,562.8000,
563.6000,564.6000,565.6000,566.6000,567.4000,568.4000,569.4000,570.4000,571.2000,572.2000,573.2000,574.2000,575.0000,576.0000,576.8000,
577.4000,578.0000,578.6000,579.0000,579.8000,580.2000,580.8000,581.4000,582.0000,582.8000,583.0000,583.8000,584.2000,585.0000,585.6000,
586.0000,586.8000,587.2000,587.8000,588.4000,589.0000,589.8000,590.0000,590.8000,591.2000,592.0000,593.0000,594.8000,596.6000,598.0000,
599.8000,601.8000,603.2000,605.0000,606.8000,608.2000,609.2000,610.0000,611.0000,612.0000,613.0000,614.0000,615.0000,615.8000,616.8000,
617.8000,618.8000,619.8000,620.6000,621.6000,622.4000,623.4000,624.2000,625.2000,626.2000,627.4000,628.4000,629.4000,630.4000,631.6000,
632.6000,633.6000,634.6000,635.8000,636.8000,637.8000,638.8000,639.8000,640.8000,641.8000,642.8000,643.8000,644.8000,645.8000,646.8000,
647.8000,648.8000,649.8000,650.8000,651.8000,652.8000,653.8000,654.8000,655.8000,657.0000,658.8000,660.2000,662.0000,663.8000,665.2000,
667.0000,668.6000,670.0000,671.8000,673.0000,674.0000,675.4000,676.6000,677.8000,678.8000,680.0000,681.0000,682.0000,683.2000,684.6000,
685.8000,686.8000,688.0000,689.0000,690.2000,691.6000,692.8000,693.8000,695.0000,696.2000,697.6000,698.8000,700.0000,701.0000,702.2000,
703.6000,704.8000,705.8000,706.8000,707.8000,708.8000,709.8000,710.8000,712.0000,713.0000,714.0000,715.0000,716.0000,717.0000,718.0000,
719.0000,720.0000,721.2000,722.2000,723.4000,724.4000,725.6000,726.6000,727.8000,728.8000,729.8000,730.8000,731.8000,732.8000,733.8000,
735.0000,736.0000,737.0000,738.0000,739.2000,740.4000,741.8000,742.8000,743.8000,745.0000,746.0000,747.0000,748.2000,749.4000,750.6000,
751.8000,752.8000,753.4000,754.0000,755.0000,755.8000,756.6000,757.2000,758.0000,758.8000,759.8000,760.4000,761.0000,762.0000,762.8000,
763.6000,764.2000,765.0000,765.8000,766.8000,767.4000,768.0000,774.0000,780.8000,784.8000,785.8000,786.6000,787.4000,788.4000,789.2000,
790.2000,791.0000,792.0000,793.0000,794.0000,795.0000,795.8000,796.8000,797.8000,798.8000,799.8000,800.8000,801.6000,802.4000,803.2000,
804.0000,805.0000,806.0000,806.8000,807.8000,808.8000,809.6000,810.4000,811.2000,812.0000,813.0000,814.0000,814.8000,815.8000,816.8000,
818.0000,819.0000,820.4000,821.8000,822.8000,824.0000,825.2000,826.6000,827.8000,829.0000,830.0000,831.2000,832.4000,833.0000,834.0000,
834.8000,835.8000,836.4000,837.0000,838.0000,838.8000,839.8000,840.4000,841.0000,842.0000,842.8000,843.8000,844.4000,845.0000,846.0000,
846.8000,847.6000,848.4000,849.8000,850.8000,852.0000,853.2000,854.8000,855.8000,857.0000,858.2000,859.6000,860.8000,862.0000,863.0000,
864.4000,865.4000,866.4000,867.4000,868.4000,869.4000,870.4000,871.4000,872.2000,873.2000,874.2000,875.2000,876.2000,877.2000,878.2000,
879.2000,880.2000,881.8000,882.8000,884.0000,885.2000,886.6000,887.8000,889.0000,890.0000,891.4000,892.8000,893.8000,895.0000,896.2000,
897.2000,898.2000,899.2000,900.2000,901.2000,902.0000,903.0000,904.0000,905.0000,906.0000,907.0000,908.0000,909.0000,910.0000,911.0000,
912.0000,913.4000,914.8000,916.0000,917.0000,918.6000,919.8000,921.0000,922.2000,923.8000,924.8000,926.0000,927.6000,928.6000,929.4000,
930.0000,931.0000,931.8000,932.8000,933.6000,934.2000,935.0000,936.0000,936.8000,937.8000,938.6000,939.2000,940.0000,941.0000,941.8000,
942.8000,943.6000,944.2000,945.4000,946.6000,947.8000,948.8000,949.8000,950.8000,952.0000,953.0000,954.0000,955.2000,956.4000,957.6000,
958.8000,959.8000,960.8000,962.0000,963.0000,964.2000,965.6000,966.8000,967.8000,969.0000,970.0000,971.4000,972.8000,973.8000,975.0000,
976.0000,977.2000,978.4000,979.8000,980.8000,982.0000,983.0000,984.2000,985.6000,986.8000,987.8000,989.0000,990.0000,991.2000,992.4000,
993.0000,993.8000,994.6000,995.0000,995.8000,996.8000,997.2000,998.0000,998.8000,999.4000,1000.0000,1000.8000,1001.6000,1002.0000,1003.0000,
1003.8000,1004.2000,1005.0000,1005.8000,1006.4000,1007.0000,1007.8000,1008.8000,1010.0000,1011.2000,1012.8000,1013.8000,1015.0000,1016.2000,1017.8000,
1018.8000,1020.0000,1021.2000,1022.8000,1023.8000,1025.0000,1026.0000,1027.0000,1028.0000,1029.0000,1030.2000,1031.4000,1032.4000,1033.6000,1034.8000,
1035.8000,1036.8000,1037.8000,1038.8000,1040.0000,1041.2000,1042.8000,1044.0000,1045.8000,1047.0000,1048.8000,1050.0000,1051.6000,1053.0000,1054.6000,
1056.0000,1057.0000,1057.8000,1058.8000,1059.6000,1060.4000,1061.2000,1062.0000,1063.0000,1064.0000,1064.8000,1065.8000,1066.6000,1067.4000,1068.2000,
1069.0000,1070.0000,1071.0000,1071.8000,1072.8000,1073.8000,1074.8000,1075.6000,1076.6000,1077.4000,1078.4000,1079.2000,1080.2000,1081.0000,1082.0000,
1083.0000,1084.0000,1085.0000,1086.0000,1086.8000,1087.8000,1088.8000,1090.0000,1091.0000,1092.0000,1093.2000,1094.4000,1095.6000,1096.8000,1097.8000,
1098.8000,1099.8000,1101.0000,1102.0000,1103.0000,1104.0000,1105.0000,1105.8000,1106.8000,1107.6000,1108.2000,1109.0000,1109.8000,1110.8000,1111.6000,
1112.2000,1113.0000,1114.0000,1114.8000,1115.8000,1116.4000,1117.0000,1118.0000,1118.8000,1119.8000,1120.6000,1121.6000,1122.8000,1123.8000,1124.8000,
1125.8000,1126.8000,1127.8000,1128.8000,1129.8000,1130.8000,1131.8000,1132.8000,1134.0000,1135.0000,1136.0000,1137.0000,1138.0000,1139.0000,1140.0000,
1141.0000,1142.0000,1143.0000,1144.0000,1145.0000,1146.0000,1146.8000,1147.8000,1148.8000,1149.8000,1150.8000,1151.8000,1153.0000,1154.4000,1155.8000,
1157.0000,1158.8000,1160.0000,1161.2000,1162.8000,1164.0000,1165.4000,1166.8000,1168.0000,1169.0000,1169.8000,1170.6000,1171.2000,1172.0000,1172.8000,
1173.8000,1174.6000,1175.2000,1176.0000,1176.8000,1177.8000,1178.4000,1179.0000,1180.0000,1180.8000,1181.8000,1182.4000,1183.0000,1184.0000,1185.6000,
1187.2000,1189.0000,1191.0000,1192.8000,1194.8000,1196.8000,1198.4000,1200.0000,1201.2000,1202.2000,1203.4000,1204.4000,1205.6000,1206.6000,1207.8000,
1208.8000,1209.8000,1210.8000,1211.8000,1212.8000,1213.8000,1215.0000,1216.0000,1217.0000,1218.0000,1218.8000,1219.8000,1220.8000,1221.8000,1222.8000,
1223.8000,1224.8000,1225.8000,1226.8000,1227.6000,1228.6000,1229.6000,1230.4000,1231.4000,1232.2000,1233.0000,1234.0000,1234.8000,1235.6000,1236.2000,
1237.0000,1237.8000,1238.8000,1239.4000,1240.0000,1241.0000,1241.8000,1242.8000,1243.4000,1244.0000,1245.0000,1245.8000,1246.8000,1247.4000,1248.0000,
1249.8000,1251.8000,1253.2000,1255.0000,1256.8000,1258.8000,1260.2000,1262.0000,1263.8000,1265.0000,1266.0000,1267.2000,1268.2000,1269.4000,1270.6000,
1271.8000,1272.8000,1273.8000,1275.0000,1276.0000,1277.0000,1278.0000,1279.2000,1280.2000,1281.0000,1282.0000,1283.0000,1284.0000,1284.8000,1285.8000,
1286.8000,1287.8000,1288.6000,1289.4000,1290.2000,1291.0000,1292.0000,1293.0000,1294.0000,1294.8000,1295.8000,1296.8000,1297.8000,1298.6000,1299.6000,
1300.4000,1301.2000,1302.0000,1303.0000,1304.0000,1305.0000,1306.0000,1306.8000,1307.8000,1308.8000,1309.8000,1310.8000,1311.6000,1312.8000,1314.8000,
1316.8000,1318.8000,1320.6000,1322.6000,1324.4000,1326.4000,1328.2000,1329.8000,1331.0000,1332.2000,1333.8000,1335.0000,1336.2000,1337.8000,1339.0000,
1340.2000,1341.8000,1343.0000,1344.0000,1345.0000,1346.0000,1347.0000,1348.0000,1349.0000,1349.8000,1350.8000,1351.8000,1352.8000,1353.8000,1354.6000,
1355.4000,1356.4000,1357.2000,1358.0000,1359.0000,1360.0000,1360.8000,1361.8000,1362.4000,1363.0000,1363.8000,1364.8000,1365.4000,1366.0000,1367.0000,
1367.8000,1368.4000,1369.0000,1370.0000,1370.8000,1371.4000,1372.0000,1373.0000,1373.8000,1374.6000,1375.0000,1376.0000,1377.0000,1378.4000,1379.8000,
1381.0000,1382.2000,1383.8000,1385.0000,1386.0000,1387.6000,1388.8000,1390.0000,1391.4000,1392.8000,1393.6000,1394.4000,1395.2000,1396.2000,1397.0000,
1398.0000,1399.0000,1400.0000,1400.8000,1401.8000,1402.8000,1403.8000,1404.8000,1405.6000,1406.4000,1407.4000,1408.6000,1411.0000,1413.8000,1416.4000,
1419.0000,1421.8000,1424.0000,1424.8000,1425.6000,1426.0000,1426.8000,1427.4000,1428.0000,1428.8000,1429.2000,1430.0000,1430.8000,1431.0000,1431.8000,
1432.6000,1433.0000,1433.8000,1434.4000,1435.0000,1435.8000,1436.2000,1436.8000,1437.6000,1438.0000,1438.8000,1439.4000,1440.0000,1441.2000,1442.8000,
1444.0000,1445.8000,1447.0000,1448.6000,1450.0000,1451.4000,1452.8000,1454.2000,1455.8000,1456.8000,1457.8000,1458.8000,1459.8000,1460.6000,1461.4000,
1462.2000,1463.0000,1464.0000,1465.0000,1466.0000,1466.8000,1467.8000,1468.8000,1469.8000,1470.6000,1471.4000,1472.4000,1473.8000,1475.0000,1476.6000,
1477.8000,1479.0000,1480.8000,1482.0000,1483.4000,1484.8000,1486.0000,1487.6000,1488.8000,1489.8000,1490.8000,1491.8000,1492.8000,1493.8000,1494.8000,
1495.8000,1496.8000,1497.8000,1498.8000,1499.8000,1500.8000,1501.8000,1502.8000,1503.8000,1504.8000,1505.8000,1506.6000,1507.4000,1508.2000,1509.0000,
1510.0000,1510.8000,1511.8000,1512.8000,1513.6000,1514.4000,1515.0000,1516.0000,1517.0000,1517.8000,1518.8000,1519.8000,1520.8000,1522.4000,1524.0000,
1525.8000,1527.8000,1529.2000,1531.0000,1532.8000,1534.6000,1536.0000,1537.0000,1538.0000,1539.0000,1540.0000,1540.8000,1541.8000,1542.8000,1543.8000,
1544.8000,1545.8000,1546.6000,1547.4000,1548.4000,1549.2000,1550.0000,1551.0000,1552.0000,1553.6000,1555.0000,1556.4000,1557.8000,1559.2000,1560.8000,
1562.0000,1563.8000,1565.0000,1566.8000,1568.0000,1569.0000,1569.8000,1570.8000,1571.4000,1572.0000,1573.0000,1573.8000,1574.8000,1575.6000,1576.2000,
1577.0000,1578.0000,1578.8000,1579.8000,1580.4000,1581.0000,1582.0000,1582.8000,1583.8000,1584.8000,1585.8000,1586.8000,1587.8000,1588.8000,1589.8000,
1590.8000,1591.8000,1592.8000,1593.8000,1594.8000,1595.8000,1596.8000,1597.8000,1598.8000,1599.8000,1600.8000,1601.8000,1602.4000,1603.0000,1604.0000,
1605.0000,1605.8000,1606.8000,1607.4000,1608.2000,1609.0000,1610.0000,1610.8000,1611.8000,1612.6000,1613.2000,1614.0000,1615.0000,1615.8000,1617.0000,
1618.2000,1619.8000,1621.0000,1622.4000,1623.8000,1625.0000,1626.6000,1627.8000,1629.0000,1630.6000,1631.8000,1633.0000,1634.2000,1635.6000,1636.8000,
1638.0000,1639.0000,1640.2000,1641.6000,1642.8000,1644.0000,1645.0000,1646.2000,1647.6000,1648.8000,1649.6000,1650.4000,1651.2000,1652.0000,1653.0000,
1654.0000,1654.8000,1655.8000,1656.8000,1657.6000,1658.4000,1659.2000,1660.0000,1661.0000,1662.0000,1662.8000,1663.8000,1664.8000,1665.8000,1666.8000,
1668.0000,1669.0000,1670.0000,1671.0000,1672.0000,1673.0000,1674.2000,1675.4000,1676.4000,1677.6000,1678.6000,1679.8000,1680.8000,1681.4000,1682.2000,
1683.0000,1684.0000,1684.8000,1685.8000,1686.8000,1687.4000,1688.2000,1689.0000,1690.0000,1690.8000,1691.8000,1692.6000,1693.4000,1694.0000,1695.0000,
1696.0000,1697.4000,1699.0000,1700.8000,1702.8000,1704.2000,1706.0000,1707.8000,1709.6000,1711.2000,1712.8000,1713.4000,1714.0000,1715.0000,1715.8000,
1716.6000,1717.2000,1718.0000,1718.8000,1719.8000,1720.6000,1721.0000,1722.0000,1722.8000,1723.8000,1724.4000,1725.0000,1726.0000,1726.8000,1727.8000,
1728.4000,1729.6000,1730.8000,1731.8000,1732.8000,1733.8000,1735.0000,1736.0000,1737.0000,1738.0000,1739.0000,1740.2000,1741.4000,1742.6000,1743.8000,
1744.8000,1745.8000,1746.8000,1748.0000,1749.0000,1750.0000,1751.0000,1752.2000,1753.4000,1754.6000,1755.8000,1756.8000,1757.8000,1758.8000,1760.0000,
1761.0000,1762.0000,1763.0000,1764.0000,1765.0000,1766.0000,1767.0000,1768.0000,1769.0000,1770.0000,1771.2000,1772.2000,1773.2000,1774.2000,1775.4000,
1776.4000,1777.8000,1779.0000,1780.4000,1781.8000,1783.0000,1784.4000,1785.8000,1787.0000,1788.4000,1789.8000,1791.0000,1792.4000,1793.8000,1795.0000,
1796.4000,1797.8000,1799.0000,1800.4000,1801.8000,1803.0000,1804.6000,1805.8000,1807.0000,1808.4000,1809.4000,1810.2000,1811.2000,1812.0000,1813.0000,
1814.0000,1815.0000,1816.0000,1817.0000,1818.0000,1819.0000,1819.8000,1820.8000,1821.8000,1822.8000,1823.8000,1824.8000,1825.6000,1826.4000,1827.2000,
1828.0000,1829.0000,1830.0000,1831.0000,1831.8000,1832.8000,1833.8000,1834.6000,1835.4000,1836.2000,1837.0000,1838.0000,1839.0000,1839.8000,1841.0000,
1842.2000,1843.8000,1844.8000,1846.0000,1847.2000,1848.8000,1849.8000,1851.0000,1852.4000,1853.8000,1855.0000,1856.0000,1857.0000,1858.0000,1858.8000,
1859.8000,1860.8000,1861.6000,1862.4000,1863.2000,1864.0000,1865.0000,1866.0000,1866.8000,1867.8000,1868.8000,1869.8000,1870.4000,1871.2000,1872.0000,
1873.6000,1874.8000,1876.0000,1877.2000,1878.8000,1879.8000,1881.0000,1882.4000,1883.8000,1885.0000,1886.0000,1887.6000,1888.8000,1890.0000,1891.4000,
1892.8000,1894.0000,1895.4000,1896.8000,1898.0000,1899.4000,1900.8000,1902.0000,1903.2000,1904.8000,1905.8000,1906.8000,1907.8000,1909.0000,1910.0000,
1911.0000,1912.0000,1913.2000,1914.4000,1915.6000,1916.8000,1917.8000,1918.8000,1919.8000,1920.8000,1921.6000,1922.0000,1923.0000,1923.8000,1924.6000,
1925.0000,1926.0000,1926.8000,1927.4000,1928.0000,1929.0000,1929.8000,1930.4000,1931.0000,1932.0000,1932.8000,1933.4000,1934.0000,1934.8000,1935.8000,
1936.6000,1937.8000,1938.8000,1939.8000,1941.0000,1942.0000,1943.0000,1944.2000,1945.4000,1946.6000,1947.8000,1948.8000,1950.0000,1951.0000,1952.0000,
1953.2000,1954.6000,1955.8000,1956.8000,1958.0000,1959.0000,1960.4000,1961.8000,1962.8000,1964.0000,1965.0000,1966.2000,1967.6000,1968.8000,1970.4000,
1972.0000,1973.4000,1975.0000,1976.6000,1978.0000,1979.8000,1981.0000,1982.8000,1984.0000,1985.0000,1985.8000,1986.8000,1987.6000,1988.2000,1989.0000,
1990.0000,1990.8000,1991.6000,1992.4000,1993.0000,1994.0000,1994.8000,1995.8000,1996.4000,1997.2000,1998.0000,1999.0000,1999.8000,2000.8000,2001.8000,
2002.8000,2003.8000,2004.8000,2005.8000,2006.8000,2007.8000,2008.8000,2009.8000,2010.8000,2011.8000,2012.8000,2013.8000,2014.8000,2015.8000,2017.0000,
2018.6000,2019.8000,2021.0000,2022.6000,2023.8000,2025.0000,2026.6000,2027.8000,2029.0000,2030.6000,2031.8000,2032.6000,2033.0000,2033.4000,2033.8000,
2034.2000,2034.8000,2035.0000,2035.8000,2036.0000,2036.6000,2037.0000,2037.4000,2037.8000,2038.2000,2038.8000,2039.0000,2039.8000,2040.0000,2040.6000,
2041.0000,2041.4000,2041.8000,2042.0000,2042.8000,2043.0000,2043.8000,2044.0000,2044.4000,2044.8000,2045.2000,2045.8000,2046.0000,2046.8000,2047.0000,
2047.6000,2048.0000,2048.8000,2050.0000,2051.2000,2052.6001,2053.8000,2055.0000,2056.0000,2057.3999,2058.8000,2060.0000,2061.0000,2062.3999,2063.8000,
2064.8000,2065.8000,2066.8000,2067.8000,2068.8000,2069.8000,2070.8000,2071.8000,2072.8000,2073.8000,2074.8000,2075.8000,2076.8000,2077.6001,2078.6001,
2079.6001,2080.8000,2081.8000,2083.0000,2084.2000,2085.6001,2086.8000,2088.0000,2089.0000,2090.3999,2091.8000,2092.8000,2094.0000,2095.2000,2096.3999,
2097.0000,2098.0000,2098.8000,2099.6001,2100.2000,2101.0000,2101.8000,2102.8000,2103.3999,2104.0000,2105.0000,2105.8000,2106.6001,2107.2000,2108.0000,
2108.8000,2109.8000,2110.3999,2111.0000,2112.0000,2113.0000,2114.3999,2115.8000,2117.0000,2118.3999,2119.8000,2121.0000,2122.3999,2123.8000,2125.0000,
2126.3999,2127.8000,2129.0000,2130.8000,2132.0000,2133.8000,2135.2000,2136.8000,2138.2000,2139.8000,2141.2000,2142.8000,2144.2000,2145.3999,2146.6001,
2147.8000,2148.8000,2149.8000,2151.0000,2152.0000,2153.0000,2154.2000,2155.3999,2156.6001,2157.8000,2158.8000,2159.8000,2160.8000,2161.6001,2162.2000,
2163.0000,2164.0000,2164.8000,2165.8000,2166.3999,2167.0000,2168.0000,2168.8000,2169.8000,2170.3999,2171.0000,2172.0000,2172.8000,2173.8000,2174.3999,
2175.0000,2176.0000,2177.0000,2178.0000,2179.0000,2179.8000,2180.8000,2181.8000,2182.8000,2183.8000,2184.8000,2185.8000,2186.8000,2187.8000,2188.8000,
2189.8000,2190.8000,2191.8000,2192.8000,2193.8000,2194.8000,2195.8000,2196.8000,2197.8000,2199.0000,2200.0000,2201.0000,2202.0000,2203.0000,2204.0000,
2205.0000,2206.0000,2207.0000,2208.0000,2209.0000,2209.8000,2210.8000,2211.8000,2212.8000,2213.6001,2214.3999,2215.2000,2216.0000,2217.0000,2218.0000,
2219.0000,2219.8000,2220.8000,2221.8000,2222.6001,2223.3999,2224.3999,2225.3999,2226.3999,2227.6001,2228.6001,2229.6001,2230.8000,2231.8000,2232.8000,
2233.8000,2234.8000,2235.8000,2236.8000,2237.8000,2238.8000,2240.0000,2241.8000,2243.6001,2245.6001,2247.3999,2249.2000,2251.2000,2253.0000,2255.0000,
2256.8000,2257.3999,2258.0000,2259.0000,2259.8000,2260.6001,2261.2000,2262.0000,2262.8000,2263.8000,2264.6001,2265.2000,2266.0000,2266.8000,2267.8000,
2268.3999,2269.0000,2270.0000,2270.8000,2271.8000,2272.3999,2273.2000,2274.0000,2275.0000,2276.0000,2277.0000,2277.8000,2278.8000,2279.8000,2280.8000,
2281.6001,2282.3999,2283.2000,2284.0000,2285.0000,2286.0000,2287.0000,2287.8000,2289.0000,2290.3999,2291.8000,2293.0000,2294.6001,2295.8000,2297.0000,
2298.8000,2300.0000,2301.3999,2302.8000,2304.0000,2305.3999,2306.8000,2308.0000,2309.0000,2310.6001,2311.8000,2313.0000,2314.2000,2315.8000,2316.8000,
2318.0000,2319.3999,2320.8000,2321.8000,2322.8000,2323.8000,2324.8000,2325.8000,2326.8000,2327.8000,2329.0000,2330.0000,2331.0000,2332.0000,2333.0000,
2334.0000,2335.0000,2336.0000,2337.3999,2338.8000,2339.8000,2341.0000,2342.2000,2343.6001,2344.8000,2346.0000,2347.0000,2348.3999,2349.8000,2350.8000,
2352.0000,2353.2000,2354.8000,2356.0000,2357.2000,2358.8000,2360.0000,2361.2000,2362.8000,2364.0000,2365.2000,2366.8000,2368.0000,2368.8000,2369.8000,
2370.3999,2371.0000,2372.0000,2372.8000,2373.8000,2374.2000,2375.0000,2376.0000,2376.8000,2377.6001,2378.2000,2379.0000,2379.8000,2380.8000,2381.3999,
2382.0000,2383.0000,2383.8000,2385.0000,2387.0000,2389.0000,2391.0000,2393.0000,2395.0000,2397.0000,2399.0000,2400.8000,2401.2000,2402.0000,2402.8000,
2403.8000,2404.3999,2405.0000,2406.0000,2406.8000,2407.6001,2408.2000,2409.0000,2409.8000,2410.8000,2411.2000,2412.0000,2412.8000,2413.8000,2414.3999,
2415.0000,2416.0000,2417.0000,2418.3999,2419.8000,2421.0000,2422.2000,2423.8000,2425.0000,2426.0000,2427.6001,2428.8000,2430.0000,2431.6001,2432.8000,
2433.6001,2434.3999,2435.2000,2436.0000,2437.0000,2438.0000,2439.0000,2439.8000,2440.8000,2441.8000,2442.8000,2443.6001,2444.3999,2445.2000,2446.0000,
2447.0000,2448.0000,2449.0000,2450.2000,2451.6001,2452.8000,2453.8000,2455.0000,2456.2000,2457.3999,2458.8000,2459.8000,2461.0000,2462.0000,2463.3999,
2464.6001,2465.2000,2466.0000,2467.0000,2468.0000,2468.8000,2469.8000,2470.8000,2471.6001,2472.3999,2473.2000,2474.0000,2475.0000,2476.0000,2476.8000,
2477.8000,2478.8000,2479.6001,2480.6001,2481.8000,2482.8000,2484.0000,2485.2000,2486.6001,2487.8000,2489.0000,2490.0000,2491.2000,2492.6001,2493.8000,
2495.0000,2496.0000,2497.0000,2498.2000,2499.2000,2500.3999,2501.3999,2502.6001,2503.8000,2504.8000,2505.8000,2506.8000,2507.8000,2508.8000,2509.8000,
2511.0000,2512.0000,2513.0000,2514.2000,2515.3999,2516.8000,2517.8000,2518.8000,2520.0000,2521.0000,2522.2000,2523.6001,2524.8000,2525.8000,2527.0000,
2528.0000,2529.6001,2531.0000,2532.6001,2534.0000,2535.6001,2537.0000,2538.6001,2540.0000,2541.6001,2543.0000,2544.6001,2546.0000,2547.8000,2549.0000,
2550.8000,2552.2000,2553.8000,2555.3999,2557.0000,2558.8000,2560.0000,2561.0000,2561.8000,2562.6001,2563.0000,2564.0000,2564.8000,2565.8000,2566.2000,
2567.0000,2567.8000,2568.8000,2569.3999,2570.0000,2571.0000,2571.8000,2572.6001,2573.2000,2574.0000,2574.8000,2575.8000,2576.3999,2577.8000,2578.8000,
2579.8000,2581.0000,2582.0000,2583.2000,2584.6001,2585.8000,2586.8000,2588.0000,2589.0000,2590.0000,2591.3999,2592.6001,2593.3999,2594.3999,2595.2000,
2596.0000,2597.0000,2598.0000,2599.0000,2600.0000,2601.0000,2601.8000,2602.8000,2603.8000,2604.8000,2605.8000,2606.8000,2607.6001,2608.6001,2609.8000,
2611.0000,2612.0000,2613.6001,2614.8000,2616.0000,2617.0000,2618.3999,2619.8000,2620.8000,2622.0000,2623.2000,2624.6001,2625.3999,2626.3999,2627.2000,
2628.0000,2629.0000,2630.0000,2631.0000,2632.0000,2633.0000,2633.8000,2634.8000,2635.8000,2636.8000,2637.8000,2638.6001,2639.6001,2640.3999,2641.6001,
2642.6001,2643.8000,2644.8000,2645.8000,2646.8000,2647.8000,2648.8000,2649.8000,2651.0000,2652.0000,2653.0000,2654.0000,2655.0000,2656.0000,2657.2000,
2658.3999,2659.6001,2660.8000,2661.8000,2663.0000,2664.0000,2665.0000,2666.2000,2667.3999,2668.6001,2669.8000,2670.8000,2672.0000,2673.0000,2674.0000,
2675.0000,2676.0000,2677.0000,2678.0000,2679.0000,2680.0000,2681.0000,2682.0000,2683.0000,2684.0000,2685.0000,2686.0000,2687.0000,2688.0000,2689.0000,
2690.0000,2691.3999,2692.6001,2693.8000,2694.8000,2695.8000,2697.0000,2698.0000,2699.0000,2700.0000,2701.3999,2702.6001,2703.8000,2704.8000,2705.8000,
2706.8000,2707.8000,2708.8000,2709.8000,2710.6001,2711.6001,2712.6001,2713.6001,2714.6001,2715.6001,2716.3999,2717.3999,2718.3999,2719.3999,2720.8000,
2722.8000,2725.0000,2727.0000,2729.3999,2731.6001,2733.8000,2736.0000,2737.0000,2737.8000,2738.8000,2739.6001,2740.3999,2741.0000,2742.0000,2743.0000,
2743.8000,2744.8000,2745.6001,2746.2000,2747.0000,2748.0000,2748.8000,2749.8000,2750.8000,2751.6001,2752.2000,2753.0000,2753.8000,2754.0000,2754.8000,
2755.6001,2756.0000,2756.8000,2757.3999,2758.0000,2758.8000,2759.3999,2760.0000,2760.8000,2761.2000,2762.0000,2762.8000,2763.0000,2763.8000,2764.6001,
2765.0000,2765.8000,2766.3999,2767.0000,2767.8000,2768.6001,2769.8000,2771.0000,2772.0000,2773.3999,2774.8000,2775.8000,2777.0000,2778.2000,2779.6001,
2780.8000,2782.0000,2783.0000,2784.2000,2785.0000,2786.0000,2787.0000,2787.8000,2788.8000,2789.8000,2790.6001,2791.3999,2792.0000,2793.0000,2794.0000,
2794.8000,2795.8000,2796.8000,2797.6001,2798.3999,2799.2000,2800.0000,2801.8000,2803.0000,2804.6001,2805.8000,2807.2000,2808.8000,2810.0000,2811.8000,
2813.0000,2814.3999,2815.8000,2817.3999,2819.0000,2820.6001,2822.0000,2823.8000,2825.0000,2826.8000,2828.3999,2830.0000,2831.6001,2832.8000,2833.8000,
2834.6001,2835.2000,2836.0000,2837.0000,2838.0000,2838.8000,2839.8000,2840.8000,2841.6001,2842.3999,2843.2000,2844.0000,2845.0000,2845.8000,2846.8000,
2847.8000,2848.8000,2849.8000,2851.0000,2852.2000,2853.8000,2854.8000,2856.0000,2857.0000,2858.6001,2859.8000,2861.0000,2862.0000,2863.3999,2864.6001,
2865.2000,2866.0000,2867.0000,2867.8000,2868.8000,2869.6001,2870.3999,2871.0000,2872.0000,2873.0000,2873.8000,2874.8000,2875.3999,2876.2000,2877.0000,
2878.0000,2878.8000,2879.8000,2880.6001,2881.6001,2882.6001,2883.6001,2884.6001,2885.3999,2886.3999,2887.3999,2888.3999,2889.3999,2890.2000,2891.2000,
2892.2000,2893.2000,2894.0000,2895.0000,2896.0000,2898.0000,2900.0000,2902.0000,2904.0000,2906.0000,2908.0000,2910.0000,2912.0000,2913.0000,2914.0000,
2915.0000,2916.0000,2917.0000,2918.0000,2919.0000,2920.0000,2921.0000,2922.0000,2923.0000,2924.0000,2925.0000,2926.0000,2927.0000,2928.0000,2928.8000,
2929.8000,2930.8000,2931.3999,2932.2000,2933.0000,2934.0000,2935.0000,2935.8000,2936.8000,2937.8000,2938.3999,2939.2000,2940.0000,2941.0000,2942.0000,
2942.8000,2943.8000,2944.6001,2945.3999,2946.2000,2947.0000,2948.0000,2949.0000,2950.0000,2950.8000,2951.8000,2952.8000,2953.6001,2954.3999,2955.2000,
2956.0000,2957.0000,2958.0000,2958.8000,2959.8000,2960.8000,2961.8000,2962.8000,2963.6001,2964.6001,2965.3999,2966.3999,2967.2000,2968.2000,2969.0000,
2970.0000,2971.0000,2972.0000,2973.0000,2974.0000,2974.8000,2975.8000,2977.0000,2978.8000,2980.0000,2981.8000,2983.0000,2984.6001,2986.0000,2987.6001,
2989.0000,2990.3999,2992.0000,2993.0000,2994.0000,2995.0000,2996.0000,2997.0000,2998.0000,2999.0000,3000.0000,3001.0000,3002.0000,3003.0000,3004.0000,
3005.0000,3006.0000,3007.0000,3008.0000,3009.0000,3010.8000,3012.0000,3013.6001,3015.0000,3016.3999,3017.8000,3019.2000,3020.8000,3022.0000,3023.8000,
3024.8000,3025.8000,3026.6001,3027.3999,3028.2000,3029.0000,3030.0000,3031.0000,3032.0000,3032.8000,3033.8000,3034.8000,3035.6001,3036.3999,3037.2000,
3038.0000,3039.0000,3040.0000,3040.8000,3041.6001,3042.2000,3043.0000,3043.8000,3044.3999,3045.0000,3046.0000,3046.8000,3047.3999,3048.0000,3048.8000,
3049.8000,3050.2000,3051.0000,3051.8000,3052.6001,3053.0000,3054.0000,3054.8000,3055.3999,3056.0000,3057.0000,3058.0000,3059.0000,3060.0000,3061.0000,
3062.0000,3063.0000,3064.0000,3065.0000,3066.0000,3067.0000,3067.8000,3068.8000,3069.8000,3070.8000,3071.8000,3073.0000,3074.6001,3075.8000,3077.0000,
3078.8000,3080.0000,3081.3999,3082.8000,3084.0000,3085.6001,3087.0000,3088.2000,3089.0000,3089.8000,3090.8000,3091.6001,3092.2000,3093.0000,3094.0000,
3094.8000,3095.6001,3096.2000,3097.0000,3098.0000,3098.8000,3099.8000,3100.3999,3101.0000,3102.0000,3102.8000,3103.8000,3104.6001,3105.8000,3106.8000,
3107.8000,3108.8000,3110.0000,3111.0000,3112.0000,3113.0000,3114.2000,3115.2000,3116.3999,3117.6001,3118.8000,3119.8000,3120.8000,3122.0000,3123.2000,
3124.6001,3125.8000,3127.0000,3128.0000,3129.3999,3130.8000,3131.8000,3133.0000,3134.3999,3135.8000,3136.8000,3138.0000,3139.2000,3140.6001,3141.8000,
3143.0000,3144.0000,3145.6001,3146.8000,3148.0000,3149.0000,3150.3999,3151.8000,3152.8000,3153.8000,3154.8000,3155.8000,3156.8000,3157.8000,3158.8000,
3159.8000,3160.8000,3161.8000,3162.8000,3163.8000,3164.8000,3165.8000,3166.8000,3168.0000,3168.8000,3169.8000,3170.3999,3171.0000,3172.0000,3172.8000,
3173.8000,3174.6001,3175.2000,3176.0000,3176.8000,3177.8000,3178.6001,3179.2000,3180.0000,3181.0000,3181.8000,3182.8000,3183.3999,3184.0000,3185.0000,
3185.8000,3186.8000,3187.8000,3188.3999,3189.0000,3190.0000,3190.8000,3191.8000,3192.8000,3193.3999,3194.0000,3195.0000,3196.0000,3196.8000,3197.8000,
3198.3999,3199.2000,3200.0000,3201.8000,3203.8000,3205.2000,3207.0000,3209.0000,3210.8000,3212.6001,3214.2000,3216.0000,3217.0000,3217.8000,3218.8000,
3219.3999,3220.0000,3221.0000,3221.8000,3222.8000,3223.3999,3224.0000,3225.0000,3225.8000,3226.8000,3227.3999,3228.0000,3229.0000,3229.8000,3230.8000,
3231.3999,3232.2000,3233.3999,3234.8000,3235.8000,3237.0000,3238.0000,3239.2000,3240.3999,3241.8000,3242.8000,3244.0000,3245.0000,3246.0000,3247.3999,
3248.8000,3249.8000,3251.0000,3252.0000,3253.6001,3254.8000,3256.0000,3257.0000,3258.3999,3259.8000,3260.8000,3262.0000,3263.0000,3264.2000,3264.8000,
3265.2000,3265.8000,3266.0000,3266.8000,3267.0000,3267.8000,3268.0000,3268.8000,3269.0000,3269.8000,3270.0000,3270.8000,3271.0000,3271.8000,3272.0000,
3272.8000,3273.0000,3273.6001,3274.0000,3274.6001,3275.0000,3275.6001,3276.0000,3276.3999,3277.0000,3277.3999,3277.8000,3278.3999,3278.8000,3279.2000,
3279.8000,3280.8000,3282.0000,3283.6001,3285.0000,3286.3999,3287.8000,3289.2000,3290.8000,3292.0000,3293.8000,3295.0000,3296.6001,3297.6001,3298.6001,
3299.6001,3300.6001,3301.8000,3302.8000,3303.8000,3304.8000,3305.8000,3306.8000,3307.8000,3308.8000,3309.8000,3310.8000,3311.8000,3312.8000,3313.8000,
3314.8000,3315.8000,3317.0000,3318.0000,3319.0000,3320.0000,3321.0000,3322.0000,3323.0000,3324.0000,3325.0000,3326.2000,3327.2000,3328.2000,3329.0000,
3329.8000,3330.3999,3331.0000,3331.8000,3332.6001,3333.0000,3334.0000,3334.8000,3335.2000,3336.0000,3336.8000,3337.6001,3338.0000,3338.8000,3339.8000,
3340.2000,3341.0000,3341.8000,3342.3999,3343.0000,3343.8000,3344.6001,3345.2000,3346.0000,3347.0000,3347.8000,3348.8000,3349.3999,3350.0000,3351.0000,
3351.8000,3352.8000,3353.3999,3354.0000,3355.0000,3355.8000,3356.8000,3357.6001,3358.2000,3359.0000,3359.8000,3361.0000,3362.8000,3364.0000,3365.8000,
3367.0000,3368.8000,3370.0000,3371.8000,3373.2000,3374.8000,3376.0000,3377.0000,3377.8000,3378.2000,3379.0000,3379.8000,3380.3999,3381.0000,3381.8000,
3382.6001,3383.0000,3384.0000,3384.8000,3385.2000,3386.0000,3386.8000,3387.3999,3388.0000,3388.8000,3389.6001,3390.0000,3391.0000,3391.8000,3392.3999,
3393.2000,3394.2000,3395.0000,3396.0000,3397.0000,3398.0000,3399.0000,3400.0000,3401.0000,3401.8000,3402.8000,3403.8000,3404.8000,3405.8000,3406.8000,
3407.6001,3408.6001,3409.2000,3410.0000,3411.0000,3411.8000,3412.8000,3413.6001,3414.3999,3415.0000,3416.0000,3417.0000,3417.8000,3418.8000,3419.6001,
3420.2000,3421.0000,3422.0000,3422.8000,3423.8000,3424.8000,3426.0000,3427.6001,3428.8000,3430.0000,3431.6001,3433.0000,3434.2000,3435.8000,3437.0000,
3438.3999,3439.8000,3440.8000,3441.6001,3442.0000,3443.0000,3443.8000,3444.6001,3445.2000,3446.0000,3446.8000,3447.8000,3448.2000,3449.0000,3449.8000,
3450.8000,3451.3999,3452.0000,3453.0000,3453.8000,3454.6001,3455.0000,3456.0000,3456.8000,3457.8000,3458.3999,3459.0000,3460.0000,3460.8000,3461.8000,
3462.3999,3463.0000,3464.0000,3464.8000,3465.6001,3466.2000,3467.0000,3468.0000,3468.8000,3469.6001,3470.2000,3471.0000,3471.8000,3472.8000,3473.8000,
3474.8000,3475.8000,3476.8000,3477.8000,3478.8000,3479.8000,3480.8000,3481.8000,3482.8000,3483.8000,3484.8000,3485.8000,3486.8000,3487.8000,3488.8000,
3489.6001,3490.3999,3491.0000,3492.0000,3493.0000,3493.8000,3494.8000,3495.8000,3496.6001,3497.2000,3498.0000,3499.0000,3500.0000,3500.8000,3501.8000,
3502.8000,3503.3999,3504.2000,3505.0000,3505.8000,3506.0000,3506.8000,3507.6001,3508.0000,3508.8000,3509.6001,3510.0000,3510.8000,3511.3999,3512.0000,
3512.8000,3513.3999,3514.0000,3514.8000,3515.2000,3516.0000,3516.8000,3517.2000,3518.0000,3518.8000,3519.0000,3519.8000,3520.8000,3521.2000,3522.0000,
3522.8000,3523.8000,3524.2000,3525.0000,3525.8000,3526.8000,3527.2000,3528.0000,3528.8000,3529.8000,3530.2000,3531.0000,3531.8000,3532.6001,3533.2000,
3534.0000,3534.8000,3535.6001,3536.2000,3537.2000,3538.3999,3539.3999,3540.6001,3541.6001,3542.8000,3543.8000,3544.8000,3545.8000,3546.8000,3547.8000,
3548.8000,3549.8000,3550.8000,3552.0000,3552.8000,3553.8000,3554.2000,3555.0000,3556.0000,3556.8000,3557.6001,3558.0000,3559.0000,3559.8000,3560.8000,
3561.3999,3562.0000,3563.0000,3563.8000,3564.6001,3565.2000,3566.0000,3566.8000,3567.8000,3568.3999,3569.3999,3570.3999,3571.2000,3572.2000,3573.2000,
3574.0000,3575.0000,3576.0000,3577.0000,3578.0000,3579.0000,3580.0000,3581.0000,3582.0000,3583.0000,3584.0000,3584.8000,3585.2000,3586.0000,3586.8000,
3587.2000,3588.0000,3588.8000,3589.0000,3589.8000,3590.6001,3591.0000,3591.8000,3592.6001,3593.0000,3593.8000,3594.3999,3595.0000,3595.8000,3596.2000,
3597.0000,3597.8000,3598.2000,3599.0000,3599.8000,3600.2000,3601.0000,3602.0000,3603.0000,3603.8000,3604.8000,3605.8000,3606.8000,3607.6001,3608.3999,
3609.2000,3610.0000,3611.0000,3612.0000,3612.8000,3613.8000,3614.8000,3615.8000,3616.3999,3617.0000,3617.8000,3618.2000,3619.0000,3619.8000,3620.0000,
3620.8000,3621.6001,3622.0000,3622.8000,3623.3999,3624.0000,3624.8000,3625.2000,3625.8000,3626.6001,3627.0000,3627.8000,3628.3999,3629.0000,3629.8000,
3630.2000,3631.0000,3631.8000,3632.0000,3633.0000,3633.8000,3634.2000,3635.0000,3635.8000,3636.2000,3637.0000,3637.8000,3638.2000,3639.0000,3639.8000,
3640.3999,3641.0000,3641.8000,3642.3999,3643.0000,3643.8000,3644.3999,3645.0000,3645.8000,3646.6001,3647.0000,3647.8000,3648.8000,3649.6001,3650.3999,
3651.2000,3652.0000,3653.0000,3654.0000,3654.8000,3655.8000,3656.8000,3657.6001,3658.3999,3659.0000,3660.0000,3661.0000,3662.0000,3662.8000,3663.8000,
3664.3999,3665.0000,3665.6001,3666.0000,3666.8000,3667.0000,3667.8000,3668.2000,3668.8000,3669.3999,3670.0000,3670.6001,3671.0000,3671.8000,3672.0000,
3672.8000,3673.0000,3673.8000,3674.2000,3674.8000,3675.3999,3676.0000,3676.6001,3677.0000,3677.8000,3678.0000,3678.8000,3679.2000,3679.8000,3680.6001,
3681.6001,3682.3999,3683.3999,3684.2000,3685.0000,3686.0000,3687.0000,3688.0000,3689.0000,3690.0000,3690.8000,3691.8000,3692.8000,3693.8000,3694.8000,
3695.8000,3696.3999,3696.8000,3697.2000,3697.8000,3698.0000,3698.8000,3699.0000,3699.8000,3700.0000,3700.8000,3701.0000,3701.6001,3702.0000,3702.3999,
3702.8000,3703.3999,3703.8000,3704.2000,3704.8000,3705.0000,3705.8000,3706.0000,3706.8000,3707.0000,3707.8000,3708.0000,3708.6001,3709.0000,3709.3999,
3710.0000,3710.3999,3710.8000,3711.2000,3711.8000,3712.2000,3713.3999,3714.6001,3715.8000,3716.8000,3718.0000,3719.0000,3720.0000,3721.2000,3722.3999,
3723.6001,3724.8000,3725.8000,3726.8000,3728.0000,3728.6001,3729.0000,3729.2000,3729.8000,3730.0000,3730.6001,3730.8000,3731.2000,3731.8000,3732.0000,
3732.6001,3732.8000,3733.0000,3733.8000,3734.0000,3734.3999,3734.8000,3735.0000,3735.8000,3736.0000,3736.3999,3736.8000,3737.0000,3737.8000,3738.0000,
3738.3999,3738.8000,3739.0000,3739.8000,3740.0000,3740.2000,3740.8000,3741.0000,3741.6001,3742.0000,3742.2000,3742.8000,3743.0000,3743.6001,3744.0000,
3744.8000,3746.0000,3747.8000,3749.2000,3751.0000,3752.6001,3754.0000,3755.8000,3757.0000,3758.8000,3760.2000,3761.0000,3761.8000,3762.6001,3763.2000,
3764.0000,3764.8000,3765.6001,3766.2000,3767.0000,3767.8000,3768.6001,3769.0000,3770.0000,3770.8000,3771.6001,3772.0000,3773.0000,3773.8000,3774.6001,
3775.0000,3776.0000,3776.8000,3777.0000,3777.8000,3778.2000,3778.8000,3779.3999,3780.0000,3780.6001,3781.0000,3781.8000,3782.0000,3782.8000,3783.2000,
3783.8000,3784.6001,3785.0000,3785.8000,3786.0000,3786.8000,3787.2000,3787.8000,3788.3999,3789.0000,3789.6001,3790.0000,3790.8000,3791.0000,3791.8000,
3792.2000,3792.8000,3793.3999,3794.0000,3794.6001,3795.0000,3795.6001,3796.0000,3796.8000,3797.0000,3797.8000,3798.0000,3798.8000,3799.2000,3799.8000,
3800.2000,3800.8000,3801.3999,3802.0000,3802.6001,3803.0000,3803.8000,3804.0000,3804.8000,3805.0000,3805.8000,3806.0000,3806.8000,3807.2000,3807.8000,
3808.3999,3809.0000,3809.8000,3810.2000,3810.8000,3811.6001,3812.0000,3812.8000,3813.3999,3814.0000,3814.8000,3815.0000,3815.8000,3816.6001,3817.0000,
3817.8000,3818.3999,3819.0000,3819.8000,3820.0000,3820.8000,3821.6001,3822.0000,3822.8000,3823.2000,3824.0000,3825.0000,3826.8000,3828.0000,3829.6001,
3831.0000,3832.6001,3834.0000,3835.3999,3836.8000,3838.3999,3839.8000,3840.8000,3841.0000,3841.8000,3842.0000,3842.8000,3843.0000,3843.8000,3844.0000,
3844.8000,3845.2000,3845.8000,3846.2000,3846.8000,3847.3999,3847.8000,3848.3999,3849.0000,3849.3999,3850.0000,3850.6001,3851.0000,3851.6001,3852.0000,
3852.8000,3853.0000,3853.8000,3854.0000,3854.8000,3855.0000,3855.8000,3856.0000,3856.8000,3857.0000,3857.8000,3858.0000,3858.8000,3859.0000,3859.6001,
3860.0000,3860.6001,3861.0000,3861.3999,3862.0000,3862.3999,3862.8000,3863.2000,3863.8000,3864.2000,3864.8000,3865.2000,3865.8000,3866.0000,3866.8000,
3867.0000,3867.8000,3868.0000,3868.8000,3869.0000,3869.6001,3870.0000,3870.6001,3871.0000,3871.3999,3872.0000,3872.6001,3873.0000,3873.8000,3874.6001,
3875.0000,3875.8000,3876.6001,3877.0000,3877.8000,3878.6001,3879.0000,3879.8000,3880.6001,3881.0000,3881.8000,3882.6001,3883.0000,3883.8000,3884.6001,
3885.0000,3885.8000,3886.6001,3887.0000,3887.8000,3888.6001,3889.0000,3889.8000,3890.2000,3890.8000,3891.3999,3892.0000,3892.8000,3893.0000,3893.8000,
3894.3999,3895.0000,3895.8000,3896.0000,3896.8000,3897.3999,3898.0000,3898.8000,3899.0000,3899.8000,3900.3999,3901.0000,3901.6001,3902.0000,3902.8000,
3903.2000,3904.0000,3904.6001,3905.0000,3905.8000,3906.0000,3906.8000,3907.2000,3908.0000,3908.6001,3909.0000,3909.8000,3910.0000,3910.8000,3911.2000,
3912.0000,3912.6001,3913.0000,3913.8000,3914.0000,3914.8000,3915.2000,3915.8000,3916.6001,3917.0000,3917.8000,3918.0000,3918.8000,3919.2000,3919.8000,
3920.6001,3921.0000,3921.6001,3922.0000,3922.8000,3923.0000,3923.8000,3924.2000,3924.8000,3925.3999,3926.0000,3926.6001,3927.0000,3927.8000,3928.0000,
3928.8000,3929.0000,3929.8000,3930.2000,3930.8000,3931.3999,3932.0000,3932.6001,3933.0000,3933.8000,3934.0000,3934.8000,3935.0000,3935.8000,3936.2000,
3937.0000,3937.8000,3938.2000,3939.0000,3939.8000,3940.0000,3940.8000,3941.6001,3942.0000,3942.8000,3943.6001,3944.0000,3944.8000,3945.3999,3946.0000,
3946.8000,3947.3999,3948.0000,3948.8000,3949.3999,3950.0000,3950.8000,3951.2000,3952.0000,3952.8000,3953.2000,3954.0000,3954.8000,3955.2000,3956.0000,
3956.8000,3957.2000,3958.0000,3958.8000,3959.2000,3960.0000,3960.8000,3961.2000,3962.0000,3962.8000,3963.3999,3964.0000,3964.8000,3965.3999,3966.0000,
3966.8000,3967.3999,3968.0000,3968.8000,3969.2000,3969.8000,3970.6001,3971.0000,3971.8000,3972.2000,3973.0000,3973.6001,3974.0000,3974.8000,3975.3999,
3976.0000,3976.8000,3977.0000,3977.8000,3978.3999,3979.0000,3979.8000,3980.0000,3980.8000,3981.3999,3982.0000,3982.8000,3983.2000,3983.8000,3984.6001,
3985.0000,3986.0000,3986.8000,3987.3999,3988.0000,3988.8000,3989.6001,3990.0000,3991.0000,3991.8000,3992.3999,3993.0000,3993.8000,3994.6001,3995.0000,
3996.0000,3996.8000,3997.3999,3998.0000,3998.8000,3999.6001,4000.0000,4002.6001,4004.8000,4007.0000,4009.3999,4011.8000,4014.0000,4016.2000,4026.80
jannecz
Reputace: 7
Nový příspěvek od jannecz »
rottenkiwi píše:
LUT pre NTC:
Kód: Vybrat vše
Když vidím to pole hodnot musím se smát.
Jeden čas jsem si s NTC taky hrál a dotáhl jsem to tak daleko, že jsem si na papír zapisoval naměřené hodnoty při určité teplotě, abych mohl vytvořit přesně toto pole a pak to jen přiřadit.
S NTC je strašná práce. Existují na to i složitý vzorce, ale né.
tomas: když už je to na větší vzdálenost, k čidlu bych dal třeba atmegu8 a po 232 si to posílal kam potřebuju. Stačí na to kabel ETH, po kterým jde poslat i napájení.
A takhle bych to udělal i s těma čidlama u stringů rottenkiwi, jinak se z toho káblování zblázníš...
rottenkiwi
Reputace: 287
Lokalita: SO, SK
No ja uvazujem jedno ESP + 3 Dallas === 1 WiFI modul + ESP NOW + MQTT + logging
na tie stringy, o chvilu dokoncim meranie a dam to sem, mozno nieco vymyslime.
Tym by mal MPPT dalsie data a vedel napr. riadit chladenie panelov.
jannecz
Reputace: 7
Co když bude string z wifi dosahu mastera?
Čím se to u toho stringu bude napájet?
Jak je vymyšlené chlazení? Třeba když to leží na střeše nad rozpálenýma taškama...
rottenkiwi
Reputace: 287
Lokalita: SO, SK
Dnes bolo cely den uplne jasno, hoci z grafu teplot panelov to zjavne nie je.
Tie dipy / poklesy / 11:15 11:45 13:15 nie su sposobene mrakmi, ale vetrom.
A ten velky pokles okolo 15:00 je sposobeny ochladenim panelov vodou
z potoka, a vykon poskocil z 1881 na 1969 W.
Ja nemam z dovodu poziaru panely na streche, ale dole, a mozem ich
natacat v azimute aj menit inklinaciu. V zime su za 4 - 6 min ometene.
Tiez ich mozem pohodlne chladit vodou, rozprasovacom alebo silnym ventilatorom.
jannecz
Reputace: 7
Já si to zase představil jako hotový produkt pro potencionálního zákazníka... to by bylo zložitější, že?
Plně souhlasím s panelama mimo hlavní střechu baráku, pokud to jde a je místo samozřejmě...
V tvým případě, když to máš tak vymazlený, bych neřešil chlazení, ale vypočtený stráty bych kompenzoval dalšíma panelama, na zimu by se ti stejně hodily, nemyslíš?
Stejně když to budeš chladit vodou automatem, něco výkonu přibude, ale čerpadlo stejně něco sežere...
rottenkiwi
Reputace: 287
Lokalita: SO, SK
Z mojho prijmu sa neda nic kupit, ani jeden panel. Ja nemam narok na to,
na co mam pravo, lebo nemam na pravnika a dlhy pravny spor s poistovnou,
ktora nerespektuje nazor znalcov.
Cerpadlo netreba, staci o 2 metre vyssie, na 2 m stojane 200 l sud vody.
Problem je, ze musi byt chladna, lebo s 30 *C vodou sa chladit neda.
CIm chladnejsia, 6 - 8 kg ladu do nej, tym menej jej treba.
Ale problem je ju zrecyklovat, ak uz potok bude v lete suchy.
jannecz
Reputace: 7
Hele, já bych se musel rozčílit, kdyby ses rozepsal... proto ani nesleduju zprávy... :x
Hlavní je, že máš vlastní bydlení a dokážeš se o sebe z toho co je postarat a nevzdáváš to!
Peníze z nás tahat chtějí, ale když se člověk dostane do nesnází, jako by tu nebyli...
A jsme u toho. Lepší by byla nádrž ve sklepě, nebo v zemi, ušetřilo by se na ledu, ale potřeba to čerpadlo...
Reputace: 968
DS18b20 chyby 125°C a 85°C jsem kdysi řešil taky, mám všechny z číny, a když mám timeout požadavek/ čtení 0.8s, tak ty chyby nechodí. provozuju to s ESP8266 v množství větším než malém. A poslední pokus s ESPHOME: tam už se nic neprogramuje, stačí zadat na kterej pin a co to měří...
rottenkiwi
Reputace: 287
Lokalita: SO, SK
Nadrze v zemi mam tri, jednu 1.5 x 1 x 3 m, druhu 4 * 3 * 1.5 m
a tretiu 12 x 3.5 x 1.6 m, niekedy som tam plaval kazdy den, 365 dni v roku,
ale ked ma obabrali a namiesto 300 € mi dali 135 € dochodok, tak som prestal
aj polievat aj plavat, 40000 l vody nemozem z toho zaplatit.
Uvazoval som o plavajucich paneloch na 4 x 5 x 0.5 m vody, aby som sa vyhol
tienom rano aj vecer a mohol panely tahat po vode jednym prstom,
ale zase to chce investiciu asi 50 - 100 € a ja na to nemam.
Tie Dallas pouzivam od r .2007 a nikdy som nemal problem s originalnymi,
ani na Arduine ani na ESP8266 ani dalsich ESP32, problem mam len s tym
jednym, co nechce ist nikde, na ziadnom napati so ziadnym odporom.
Proste, kto na to ma, neriesi FAKE a kupi si 50 za 8 - 17 € izolovanych.
Reputace: 304
Lokalita: okolí Mělníka
Výkon panelů [Wp]: 13000
Kapacita baterie [kWh]: 15
Nový příspěvek od glottis »
Si je udělej. Nerez jímku co je na těch hotových koupíš levně v Číně. Čidlo jak jsem psal, kabel, smrstovacka a zalijes to. Funguje dobře i jen čidlo do černý smrstovacka s lepidlem
rottenkiwi
Reputace: 287
Lokalita: SO, SK
ROzmyslam ako z tohoto urobim BOOST-MPPT, s loggerom napati, prudov
a teploty, ktore bude napajane z panelov 22 - 120 V a urobi na vystupe,
z 1 - 4 panelov 30 - 120 V / 50 A IN, napr. 150 - 350 V OUT, ktore rozsekam
na nejaku mod. sinusovku a budem tym napajat spiralu 220 V / 1xxx W,
ktora bude zohrievat vodu vo foliovniku.
Vystup dat, JSON / XML / CSV-. / CSV-, / MQTT / BLE - a na druhom ESP32 + I2C OLED + BLE
s nastavovanim cez WEB rozhranie na LAN, s WiFi antenou na ESP32.
jannecz
Reputace: 7
To je pěkné, že se pouštíš do dalšího vývoje, ale proč nedodělat Arduino MPPT Solar Charge?
Nezapomeň co jsi psal: "Chcel som postupne prepojit MPPT a BMS a potom k tomu dorobit vlastny menic, LF"...
Cizí prodat, mít všechno vlastní, pak si to jenom pěkně ladit...
Pustil bych se třeba do toho LF meniče, tak jako kodl69, byla tu někde myslím i ta BMSka.
rottenkiwi
Reputace: 287
Lokalita: SO, SK
NO zatial som si urobil prenosnu pajkovaciu stanicu na 4 x 100 Ah LFP
s osvetlenim + Victron 1600 + YiHUA 8508.
To MPPT je uz OK, na 250 V nemam FET-y, nemam osciloskop a nemam Dallas,
takze musim cakat.
Sucastou BMS budu BUCK aj BOOST menice, tak sa idem ucit robit HW aj SW
pre BOOST menic, ak mam funkcny HW, dorobit SW aby to komunikovalo
s MPPT a menicom je otazka 2 - 3 hodin kodovania.
Dallas sondy to su 2 mesiace sporenia, 4 fety, to su dalsie 2 mesaice sporenia
a 2 x EPS32 to je mesiac sporenia. Takze o 5 mesiacov zacnem pajkovat HW.
rottenkiwi
Reputace: 287
Lokalita: SO, SK
A teraz musim pochopit, ako pomocou signalov 3.3 GND RX TX RTS a DTR
z tychto dvoch chipov, nahrat do ESP32 program.
Reputace: 968
proč máš propojený CH340s CP2102? to jako komunikuješ USB - UART-USB do dalšího PC? snad stačí jeden převodník USB/UART, nebo ne? Obě verze se nachází na kdejaké ESP vývojové desce a normálně se do toho nahrává program z pc, netuším, co hledáš za problém.
jannecz
Reputace: 7
A pomůže ti k pochopení tohle?
https://pcbartists.com/design/embedded/ ... schematic/
CP2102 a jeho automatický reset DTR pro nahrání programu mě nikdy nefungoval.
