DIY: Pulsní výstup u mechanického elektroměru.
Napsal: čtv kvě 01, 2014 12:09 pm
Zdroj: první příspěvek v diskuzi pod článkem na webu http://www.instructables.com/id/NanosG20-Debian-board-99EUR-Linux-webcam-and-data/Thank you for your instructable. My electricity meter readout system works pretty good now.
List of used parts:
+ IR reflection light sensor MRL601
+ transistor 2N2222
+ breadboard, some resistors, LED, clamps, wires, ...
+ mini WLAN router T-Link TL-MR3020
+ USB hub with integrated micro SD card reader
+ micro SD memory card
The CNY70 light sensor couldn't recognise the red mark on the wheel. Although expensive the MRL601 sensor does this very well if it is mounted in a certain angle. I copied the OpenWrt installation to the SD card (extroot) to have more available memory. My code is written in python. I dropped the debounce check which seems not to be necessary here. RRDtool rocks!
