Fórum | MyPower.CZ | Obnovitelné zdroje energie - energetická soběstačnost | Poslední návštěva: stř led 20, 2021 11:34 am
#include <ESP8266WiFi.h>
#include <PubSubClient.h>
#define wifi_ssid "guest"
#define wifi_password "kiwi1234"
#define mqtt_server "192.168.1.27"
#define mqtt_port 1883
#define mqtt_user "light"
#define mqtt_password "12345"
#define in_topic "/light/LED"
#define out_topic "/light/BUTTON"
#define in_led 4
int counter = 0;
WiFiClient espClient;
PubSubClient client;
void setup() {
Serial.begin(9600);
setup_wifi();
client.setClient(espClient);
client.setServer(mqtt_server, mqtt_port);
client.setCallback(callback);
// initialize digital pin LED_BUILTIN as an output.
pinMode(in_led, OUTPUT);
digitalWrite(in_led, HIGH);
void setup_wifi() {
delay(10);
// We start by connecting to a WiFi network
Serial.println();
Serial.print("Connecting to ");
Serial.println(wifi_ssid);
WiFi.begin(wifi_ssid, wifi_password);
while (WiFi.status() != WL_CONNECTED) {
delay(500);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
Serial.println("IP address: ");
Serial.println(WiFi.localIP());
void reconnect() {
// Loop until we're reconnected
while (!client.connected()) {
Serial.print("Attempting MQTT connection...");
// Attempt to connect
// If you do not want to use a username and password, change next line to
// if (client.connect("ESP8266Client")) {
if (client.connect("ESP8266Client", mqtt_user, mqtt_password)) {
Serial.println("connected");
} else {
Serial.print("failed, rc=");
Serial.print(client.state());
Serial.println(" try again in 5 seconds");
// Wait 2 seconds before retrying
delay(2000);
void callback(char* topic, byte* payload, unsigned int length) {
Serial.print("Message arrived [");
Serial.print(topic);
Serial.print("] ");
for (int i = 0; i < length; i++) {
char receivedChar = (char)payload[i];
Serial.print(receivedChar);
if (receivedChar == '0')
digitalWrite(in_led, LOW);
if (receivedChar == '1')
Serial.println();
void loop() {
if (!client.connected()) {
reconnect();
client.loop();
// Publishes a random 0 and 1 like someone switching off and on randomly (random(2))
if ((counter % 20 ) == 0)
client.publish(out_topic, String(random(2)).c_str(), true);
delay(100);
counter++;
client.subscribe(in_topic);
delay (100);
rottenkiwi píše:Niečo na hranie s RPI 4
https://qengineering.eu/install-tensorf ... 64-os.html
rottenkiwi píše:Idem najprv rozchodiť grafy v Grafane z FVE a potom toto.
https://www.youtube.com/watch?v=TiOKvOrYNII
