2xbutton-2xrelay help
Napsal: stř črc 17, 2013 4:16 pm
zdravim mam problem z programom
mam 2 tlacitka a 2rele s casovanim 18 sekund
tlacitko-1 aktivuje rele-1 na 18 sekund
tlacitko-2 aktivuje rele-2 na 18 sekund
problem je ked aktivujem hoci ktore tlacitko to druhe je po dobu 18sekund nefunkcne a naopak ja by som potreboval aby boli na sebe nazavisle vie my niekdo upravit program lebo sa s tym uz tyzden hrajkam a bez uspechu
dakujem
dakujem
Kód: Vybrat vše
int buttonState = 0;
const int buttonPin1 = 9; // Tlacitko casovania PIN 9
// Button 10K
// +5 o---0__0---.--/\/\/---o GND
// Pin 9 o----------- :
const int buttonPin2 = 10; // Tlacitko casovania PIN 10
// PhotoR 10K
// Pin 10 o----------- :
#define RELAY_PIN_3 6 // Reley-3 casovac PIN 6:
// 6 o---------| / | Rele-3
// -0V o---------| |
#define RELAY_PIN_4 7 // Reley-4 casovac PIN 7:
// 7 o---------| / | Rele-4
void setup()
pinMode(buttonPin1, INPUT); // Tlacitko casovania VSTUP:
pinMode(buttonPin2, INPUT); // Tlacitko casovania VSTUP:
pinMode(RELAY_PIN_3, OUTPUT); // Reley-3 casovac VYSTUP:
pinMode(RELAY_PIN_4, OUTPUT); // Reley-4 casovac VYSTUP:
Serial.begin(9600);
void loop()
buttonState = digitalRead(buttonPin1);
if (buttonState == LOW) { // ked je LOW:
digitalWrite(RELAY_PIN_3, HIGH); // RELEY-3 on:
else { // inokedy HIGHT:
digitalWrite(RELAY_PIN_3, LOW); // RELEY-3 off:
delay(3600); // (ms)
buttonState = digitalRead(buttonPin2);
digitalWrite(RELAY_PIN_4, HIGH); // RELEY-4 on:
digitalWrite(RELAY_PIN_4, LOW); // RELEY-4 off:
delay(18000); // (ms)
